Pagina 22 di 65 primaprima ... 12202122232432 ... ultimoultimo
Visualizzazione dei risultati da 211 a 220 su 641
[Huawei Ascend P1][ROM] AP_V9 by Mcdonald
  1. #211
    Mar 2014
    Quote Originariamente inviato da Mcdonald Visualizza il messaggio
    Hi, this kernel is not available for the swap but i create one script that bypass the problem.....Attention......this is only an internal fix that isn't viewed from the system.
    So this mean that I can use 4pda method with AP8?
    1. Making swap partition on the SD Card;
    2. Put their script in init.d folder.. ?
    Androidiano VIP L'avatar di Mcdonald
    CE
    Mediapad - Honor 6 - Wiko Feve
    Ringraziato 734 volte in 507 Posts
    Quote Originariamente inviato da bmas Visualizza il messaggio
    Sorry,can you make me read the 4pda method please? I'll don't want tell things wrong.
    ok, but have you a cm11 problem for swap?
    Ultima modifica di Mcdonald; 26-09-14 alle 14:57
  4. #213
    Mar 2014
    I dont have KitKat on my device right now. After few days of testing different KitKat builds, I found that your AP8 is better in any aspect .. than any KitKat.. I didnt feel even one advantage of using KitKat.. over AP8..
    What is the problem with SWAP there.. ?
  5. #214
    CE
    ok, my response here: others kernels, including AP8's kernel, doesn't support init.d folder. Fix the swap i have based my build using official build stock for fixing kernel problem. CM o others roms are not including this because was build in a different method. If you want swap or use my AP or AP light o last, only last, cm11.
    I hope that i was clear.
  6. Il seguente Utente ha ringraziato Mcdonald per il post:
    bmas (26-09-14)
  7. #215
    Sep 2014
    Scusate se mi introduco....leggendo il problema dell'amico straniero mi è venuto un dubbio: con la AP_8 per impostare la sd come primary bisogna applicare lo script per forza?
  8. #216
    CE
    Quote Originariamente inviato da Nutkurt Visualizza il messaggio
    Allora lo swap sd che ho creato serve ad unire le memorie quindi avrai ancora lo spazio fisico della sd ext ma realmente va tutto unito con la interna. se non si flasha lo swap, potresti invertire le memorie mediante le impostazioni ma non saranno unite....
  9. #217
    Sep 2014
    Ahhh okok pensavo cge le impostazioni che vedevo non erano effettive! Io preferisco lasciarle separate...forse. In realta non lo so... per quale motivo, vantaggio/i, tenerle unite??
  10. #218
    Mar 2014
    I install AP8.2 update over AP8 (wipe cache/dalvik cache), but after that EmuiCamera disappear ... I try to install EmuiPack.. but after install it bring me back to AP8 ..
    So how can I update to AP8.2 with EmuiCamera .. ?
  11. #219
    CE
    No problem, only old script for Emui PAck, nothing more. When you install update pack, only flash and no wipe. it'ok? Bye
    @Nutkurt-vantaggi??? personalmente potrebbe essere leggermente più veloce.....ma non ci credo. Resta una cosa molto personale, qualcuno lo fa anche per una gestione migliore di archiviazione....Esempio la cartella DCIM che contiene le foto che scatttiamo, vengono costruite due ma poi ne funziona solo una.
    Ultima modifica di Mcdonald; 29-09-14 alle 11:26
  12. #220
    Mar 2014
    I had got AP8 installed already. Then I wipe cache/dalvik cache and install AP8.2 update.. After that .. emui camera disappear .. Then I install and EmuiPack 2.0 .. but still have not got EmuiCamera..
