Pagina 201 di 262 primaprima ... 101151191199200201202203211251 ... ultimoultimo
Visualizzazione dei risultati da 2,001 a 2,010 su 2613
[ROM][MM 6.0.x] Stock modded by BB72 per LeTV Le1 [X600]
  1. #2001
    Apr 2016
    Question
    Delete default APN settings from Android 6.0
    Hello BB72
    Is thee a way how to safely delete default APN settings from EUI 5.8 ROM? You know, the ones provided as default for our local provider (Orange Slovakia) and possibly others are obsolete and causing connection dropouts and not working MMS.
    In 013S ROM I used /system/app mover app to make APN Backup & Restore a system app and than delete default APNs. After that I recreated them manually. However, on my friends X620 with your latest 015S mod it is not possible, and I'm worried it would be he same with X600 015S.
    Quote Originariamente inviato da Nathancs Visualizza il messaggio
    I did test out all the different Dolby settings. So I probably did select game and thus the crashing. Thanks so much for your help! I will play around and attempt your fix/suggestions after work.
    Update:
    I tried your suggestions and Dolby is still crashing. I used ES file explorer to delete the two folders with dolby in their names. I may have to reinstall the ROM. I found a Dolby Atmos install zip file on the XDA forums last night and tried installing that then uninstalling it in an attempt to fix the crashing app by myself before posting here. Maybe that messed up my install.
    You don't have to install other Dolby atomos...that's the reason... Just reinstall rom with wipe data and dalvik and cache
    ** Segui gli aggiornamenti modding delle ROM Cuoco92&BB72 sul canale Telegram https://telegram.me/BB72CUOCO92 **
  4. #2003
    Jan 2016
    Ukraine
    LeTV One x600
    Do you know that you can remove the launcher Chinese page simply by long press on one of the launcher page and select the little eye on top?..... I do not really see the reason to use a Modded launcher....
    Yes, i know. The main reason to use modded launcher is not a disabled Chinese pages, but is replaced binding from LIVE app to Google Now for unremovable central button at the dock line of apps.
    Ultima modifica di dilnix; 21-07-16 alle 07:13
  5. #2004
    Quote Originariamente inviato da dilnix Visualizza il messaggio
    On my Modded launcher I have live button addressing to Google search and swipe up to directly address to dialer....
  6. Il seguente Utente ha ringraziato BB72 per il post:
    frasergi (21-07-16)
  7. #2005
    Jul 2016
    Reinstalled the rom and Dolby Atmos is working again. Question: Am I able to edit the two custom dolby options? They don't seem to do anything as is...
    Also - I tried playing around with permission on the RedFlagDeals app (https://play.google.com/store/apps/d....ypg.rfd&hl=en) I mentioned before, but didn't get it to work without crashing. I was able to install an older version of the same app and it works just fine. So I have a fix for now.
    So thank you for your help and great ROM. If anyone feels like trying to get the RFD app to work, I provided a link to it on the play store.
    Cheers,
  8. #2006
    Cheers,
    Thanks for the feedback...
    Actually I didn't play a lot into Dolby Atmos but I guess you can crate sort of custom profile
  9. #2007
    Jan 2016
    @Madinboyz Installa questo fix da recovery senza wipes X600_5.8.015S_BB72_FIX1.zip
    Hi, i have the same problem, but this link doesnt work, and i cant download the fix. Can you upload it once more please?
    Ultima modifica di NiloGlock; 23-07-16 alle 11:08 - Motivo: Quote sistemati
  10. #2008
    Quote Originariamente inviato da Venkoff Visualizza il messaggio
    Which problems are you referring to? Did you install r3 version? It already includes fix
  11. Il seguente Utente ha ringraziato BB72 per il post:
    frasergi (23-07-16)
  12. #2009
    Jan 2016
    I have no access to the battery parameters. When I open battery menu automaticly stop work.
    Ultima modifica di NiloGlock; 23-07-16 alle 11:09 - Motivo: Quote sistemati
  13. #2010
    Androidiano L'avatar di frasergi
    Mar 2014
    Ringraziato 54 volte in 42 Posts
    L'installazione è facilissima, l'unica condizione è avere la TWRP 3.0 il link da MEGA si scarica senza problemi.....se avete problemi VOI con i Vs mastruzzi, non stressate BB72 che già ha fatto tanto e di più...inoltre tutto è spiegato e chiarito nelle pagine precedenti con tanta pazienza...diventa anche noioso leggere sempre le stesse cose...reinstallate e riprovate! FUNZIONA TUTTO ALLA GRANDE!
    Ultima modifica di NiloGlock; 23-07-16 alle 11:10 - Motivo: Quote sistemati
  14. I seguenti 2 Utenti hanno ringraziato frasergi per il post:
    BB72 (23-07-16),lappaz (23-07-16)
