Pagina 204 di 262 primaprima ... 104154194202203204205206214254 ... ultimoultimo
Visualizzazione dei risultati da 2,031 a 2,040 su 2613
[ROM][MM 6.0.x] Stock modded by BB72 per LeTV Le1 [X600]
  1. #2031
    Quote Originariamente inviato da inhalt Visualizza il messaggio
    Hi, @BB72! I wanted to thank you for your amazing roms for the LeTV phones. I've been using them in every LeTV phone I've had, making them run flawlessly.
    Right now I'm using your r3 for the X600, including the fixes for the tap to sleep and remote brands. All is working great so far, but I just noticed that the remote can't be configured to control any air conditioning machine... Nothing happens whenever I tap on any of the AA brands, I can't get through to the next step. Could this be fixed too?
    Aside of that, this is a really great rom. Thanks again and keep up the good work
    Thanks for the feedback...
    Actually never went through the air conditioning iR...don't you have the selection "more brands" as for the TV?
    Anyway you can always configure iR by using the universal approach and acquiring each button with actual signal
    ** Segui gli aggiornamenti modding delle ROM Cuoco92&BB72 sul canale Telegram https://telegram.me/BB72CUOCO92 **
    Jul 2016
    Yes, I have the "more brands" selection available. Actually I managed to configure it for LG, but I just realized it will only let me configure a few brands like LG, TCL and Xiaomi. It won't let me get through when pressing any other brand, either for TV or AC devices... Weird.
    I will try to use the universal approach then Thanks for your help!
  4. Il seguente Utente ha ringraziato inhalt per il post:
    BB72 (23-07-16)
  5. #2033
    Quote Originariamente inviato da Venkoff Visualizza il messaggio
    I'm using BB72 rom s015 and i have not problem when i use my phone in us english, but i'm from Bulgaria and when i swich language to bulgarian i cant open battery menu. I tried to download fix from MEGA but cant download it because file missing. If is not problem for you, can you send me new link to download this fix. Thanks
    This should fix your problem
    https://mega.nz/#!pII2mRKR!APHV_hM-Z...rexbUlEk8DqwZ0
  6. #2034
    Apr 2016
    Hello BB72, can you please look at the issue mentioned in my post #2001? I'm dealing with the issue on both X600 and X620.
  7. #2035
    Quote Originariamente inviato da longo213 Visualizza il messaggio
    You can simply extract the apn config xml file under system/etc with a root Explorer, then edit the apn you want end copy back in the same location wit rw-r-r permission....then you need to do wipe data and cache / dalvik...after this you should see the modified apn
  8. #2036
    Jan 2016
    Thank you very mutch, great job.
  9. Il seguente Utente ha ringraziato Venkoff per il post:
    BB72 (25-07-16)
  10. #2037
    Mar 2016
    forse non è la sezione giuta, ma il telefono funziona bene con la scheda wind, vorrei fare un passaggio e non so se va o no. Grazie
  11. #2038
    Jul 2016
    Salve ragazzi, avrei bisogno del vostro aiuto e sono sicuro di trovarmi nel posto giusto. Posseggo un X600 con ROM 15s BB72 , il quale ringrazio seriamente per il lavoro svolto, la passione e il tempo messoci a disposizione. Ho soltanto un piccolo problema: nel mio paese dimenticato da Dio la rete che la fa da padrone è la ormai desueta Edge. Nelle primissime versioni delle ROM (7s se non sbaglio) era possibile "switchare" sul 2G cosa ora non più fattibile. Volevo sapere se c'era la possibilità, anche tramite MobileUncleTools in engineer mode, di ovviare alla mancanza. Sempre se possibile ovviamente. Vi ringrazio anticipatamente e vi auguro una buona giornata!
    Inviato dal mio x600 usando Androidiani App
  12. Il seguente Utente ha ringraziato Rico85 per il post:
    DanieleGS (27-07-16)
  13. #2039
    Androidiano VIP L'avatar di DanieleGS
    Mar 2015
    SHENZEN
    Xiaomi Mi Note 3 Black 6/128
    Ringraziato 1,981 volte in 1,060 Posts
    Quote Originariamente inviato da Rico85 Visualizza il messaggio
    dove abiti? 0o
  14. #2040
    Jul 2016
    Provincia di Viterbo, il segnale oscilla in continuazione tra 3G e 2G. Il 3G però è debole e in automatico rimane sull' HSPA+ con scarsissimi risultati. In città torno nuovamente in 4G a 2600 MHz, il problema però ritorna quando sono in paese.
