Pagina 38 di 93 primaprima ... 2836373839404888 ... ultimoultimo
Visualizzazione dei risultati da 371 a 380 su 926
[Rom] LeTv X800 4/64 Versione USA ovvero Le1pro_US marchiato CE
  1. #371
    Jun 2016
    Quote Originariamente inviato da maremosso74 Visualizza il messaggio
    Hi there polish friend!
    I've solved for first this problem..
    I can't understood why some phones do this, but they need to be reebooted connected to Pc.
    Pls, remember to shutdown phone first!
    PLEASE NOTE: This mode will be present also after flashing (TWRP and Cuoco92's ROW, that i suggest to you..). I think it'is a bug for some phone sold randomly (a lot of phones from various sellers)
    please, let us to know if it works on your device... Tnx
    Thank you for trying to help me, but your advices don't change nothing;/
    Restarted PC. Turned off phone. Pressing vol down + power. Pinguin appears. Few seconds and phone starts to system
    2nd Try.
    Restarted PC. Plugged Phone. Opened Shell. exe. Typed ADB reboot bootloader. Phone restarts, penguin appears. 3 seconds and phone starts to system.
    I really do not know what to do. I have modded many phones and i really thank that I know how to do it. Untill now.
    I hope our players will do better their jobs on EURO 2016 than me with x800 Forza Italia! Dawać Polacy! : Laughing:
    Jun 2016
    Ringraziato 18 volte in 12 Posts
    Try to download adb drivers
    Restart pc.
    Plug device to pc
    Turn it off
    Try vol- + on
    Or
    Lunch adb command to reboot in fastreboot mode with phone turned off
  4. #373
    Buongiorno a tutti. Anche io ho lo stesso problema del signore straniero.
    Ho provato ad avviare in modalità fastboot sia tramite shell, sia con vol- + on, ma niente, rimane lì per pochi secondi per poi riavviarsi.
    Ho anche provato a riavviare il pc, collegare il cellulare, spegnerlo e riaccenderlo con la combinazione di tasti, ma sempre il solito problema.
    C'è qualcuno che mi può aiutare? Grazie infinite
  5. #374
    Mar 2016
    Le Max2, xiaomi RMN3 pro
    Ringraziato 65 volte in 60 Posts
    Ma se colleghi il letv la PC ti viene riconosciuto come le1pro-US? Se si in teoria come lo mandi manualmemente in modalità fastboot e lo colleghi al PC entro 4 secondi non dovrebbe riavviarsi
    Inviato dal mio Le 1 Pro usando Androidiani App
  6. #375
    Galaxy s6
    Dove si può trovare il changelog della 11s 44?
    Inviato con Tapatalk
  7. #376
    Quote Originariamente inviato da r_esisto Visualizza il messaggio
    Ciao ragazzi,
    non riesco a modificare la dimensione dei caratteri in Impostazioni->altro->Font di sistema.
    Il font lo cambia, ma non la dimensione....essendo mezzo orbo, questo è un problemino non indifferente per me considerato anche che le dimensioni "Grandi" nelle impostazioni generali (schermo) sono troppo piccole..
    Nessuna soluzione?
  8. #377
    May 2016
    LeTv X600, LeTv X800US
    Ragazzi una domanda, siccome la rete H3G mi sta uccidendo, ho fatto il test avrei lo stesso problema con Wind dato che manca la banda 900 per l' UMTS a quanto pare -.-"
    Con vodafone non ci sono problemi, anzi l' LTE è mostruoso nonostante la mancanza di B20 e B7.
    Comunque qualcuno di voi ha provato a flashare il fix della banda 900 riportato nel post della rom di cuoco sul letv X800US ?
    E' una cosa fattibile o richio il brick ?
    Ps: mi sembrava scorretto copiare ed incollare ma ho scritto un log per i cambiamenti dalla stock alla 11S v41, se a qualcuno interessa lo trova sull' altro post.
  9. #378
    Oct 2013
    Quote Originariamente inviato da alex4life Visualizza il messaggio
    Io ho risolto cosi: spegnendo il cellulare e solo dopo averlo spento collegandolo al cavo usb,e poi combinazione di tasti, solo in qyesto modo il pinguino mi resta sulla schermata senza far partire il sistema.
  10. #379
    Androidiano VIP L'avatar di slime00
    Ringraziato 299 volte in 250 Posts
    Quote Originariamente inviato da simon991 Visualizza il messaggio
    come, manca anche la 900mhz in 3g??
    non si capisce più nulla, ha del tragicomico come mediatek permetta in 2 secondi di togliersi il dubbio mentre qualcomm, blasonata e venerata, ci sta facendo impazzire!
    i russi hanno fatto un firmware per la versione internazionale, pare abbiano risolto il bug della modalità video non intercambiabile
    Everyone who bought the Us version of the firmware from Krivorukov Chinese are strongly encouraged to install! What has been done: * Updated kernel (Increased smoothness of operation, improved gps and much more), the core of the 13s. * Fixed color profiles (now it works) * works video camera and plays all the video files * Fixed the Messages app (now in the clamping does not take off) * Fixed SystemUi application (I get an error at 15% charge ) * There was a normal working stock browser * Fixed an application for scanning qr codes (it is in the lower curtain) * Listed stock music app * Add stock application services * Doabvleno stock app updates * Updated app-mail * Added awakening double-tapu (it was on the default sink firmware 11s, but smart-ass Chinese it was removed) * Cyrillic 99% * Now fall asleep when you press Knock back (or any other - is selected in the settings - special features) * I drank all guglovoe shit (left only play the market and Google services) * Trojan drank 3 !!!!! One was in the calculator (in flashing fake web calculator !!!!) other trojan was in the priv-app (disguised guglovuyu garbage), and the third was in the Trojan system folder * There Ruth * The default is TWRP 3.0.2.0 c the official website (who stock rekaveri needed, rename the file in origin_recovery recovery) firmware tried to do as close to the drain. As a manufacturer we cheated normally drain insertion. No shit left no type Viper yl Dolby Atmos (pure stock!). All requests to add some crap in the firmware will be ignored. Vnimamanie !!! After flashing all the data zatrutsya! How to put? 1. Unpack the archive on your PC 2. In the settings activate developer mode 3. Enable debugging for usd 4. Run Flash.bat folder with iOS 5. We are waiting for the end, we say thank you and enjoy a normal firmware p.s In the archive is password! Passwords distribute only in PM. Password is for one reason - I do not want that this firmware would hit the Chinese (who will start it puts on phones sold). I wrote 4 days Sellers Ali, efox store, asking me to drain the drain factory firmware on my return as amended. Someone ignored, someone sent to hell. I sawed this week firmware (in osnovonom night, as the day was still working), respect the labor of others, do not spread your password and firmware anywhere! If the firmware gets beyond 4pda, I stop upload new firmware for this phone is going to do for yourself only. Download the firmware for those who want viper and dolby atmos here is the link where you can download and put through twrp
    https://yadi.sk/d/muf2g4x6sSZnf
    Ultima modifica di NiloGlock; 13-06-16 alle 09:49 - Motivo: Unione post consecutivi
  11. #380
    Sassari
    LG G2, LeMax 2
    Ennesimo post consecutivo, dato che nessuno si preoccupa di utilizzare il multi-quote lasciando sempre al sottoscritto i post da unire chiudo per qualche giorno, vediamo se almeno questo servirà a qualcosa, dato che i continui avvertimenti e le infrazioni non hanno portato a nulla.
    Inviato dal mio ZenFone 2 Laser utilizzando Tapatalk
    Smartphone:
  12. I seguenti 2 Utenti hanno ringraziato NiloGlock per il post:
    turbogt (13-06-16),walterwhite82 (13-06-16)
