Pagina 295 di 597 primaprima ... 195245285293294295296297305345395 ... ultimoultimo
Visualizzazione dei risultati da 2,941 a 2,950 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #2941
    Androidiano L'avatar di Napoletano80
    lg p990 dual core
    Gentilissimo e spiegazione chiarissimo.il kernel vodanka old attualmente come hai detto eé il migliore magari ci tieni sempre aggiornati:-)
    Inviato dal mio Optimus 2X usando Androidiani App
    lg p990 dual core
    Venezia
    S4 & G3
    Per vuole provarlo, oggi nuovo aggio del vadonka etana e della MisjudgedTwat's
    Kernel
    Update 2012.05.03:
    Minor code cleanup
    Updated ZRAM driver
    Enabled Sched MultiCore Scheduler powersave mode
    John Stultz ram console patch set
    Switch to sysfs console
    Disabled the framebuffer console (it useless in a headless device, and interfered with the sysfs console)
    Various memory fix
    Adjust voltages for better stability
    sched: fix OOPS when build_sched_domains percpu allocation fails
    Switch to SLAB allocator
    Linux kernel is updated to 3.0.30
    ROM
    CHERRY-PICKS
    ROMNEW Ib2ff8fa5: Update hungarian translation.
    NEW I882cb6db: Update Telenor Online apn settings
    NEW I5e087e95: Update hungarian translation
    NEW I0ff2bff0: Update hungarian translation
    NEW I87169137: Update hungarian translation
    UPDATED I19cb79b8: Fix typo in queue_property_triggers ident
    MERGED If93f8199: Applying theming to more framework items.
    PORTS FROM OTHER SOURCES
    commits for statusbar restart:
    NEW - Add option to restart status bar to CMParts
    NEW - Improve functionality of status bar restart + cleanup
    commits for bootanimation changer:
    NEW - Add bootanimation changer to CMParts (1/2)
    NEW - Add preference for bootanimation chooser
    NEW - Add preference to bootanimation chooser
    NEW - Forgot to change intent on bootanimation chooser
    NEW - CM Boot Animation Helper
    Ultima modifica di redefined; 03-05-12 alle 14:46
  4. #2943
    Senior Droid L'avatar di desmochecco74
    Apr 2011
    Salve ho l'ultima rom la 98 non ho piu l'orologio nella barra di notifica come mai? Succede anche a voi?
    Inviato dal mio Optimus 2X usando Tapatalk
  5. #2944
    Senior Droid L'avatar di 480p
    Ringraziato 142 volte in 120 Posts
    Quote Originariamente inviato da desmochecco74 Visualizza il messaggio
    Devi andare in impostazioni, cyanogenmod, interfaccia, modifiche barra di stato, clock color e imposti il colore che vuoi!!
    Inviato dal mio Optimus 2X con Tapatalk 2
  6. #2945
    Jan 2011
    Lg Optimus One, Lg Optimus Dua
    Ringraziato 13 volte in 5 Posts
    Quote Originariamente inviato da 480p Visualizza il messaggio
    Lo chiedono in molti.. xk non lo mettono di default bianco??
  7. #2946
    Jan 2011
    Quote Originariamente inviato da redefined Visualizza il messaggio
    Kernel
    Update 2012.05.03:
    Minor code cleanup
    Updated ZRAM driver
    Various memory fix
    ROM
    CHERRY-PICKS
    Il kernel 3.x sono stabili?
  8. #2947
    Apr 2011
    Grazie grazie risolto
  9. #2948
    Quote Originariamente inviato da WidowMaker Visualizza il messaggio
    Questo bisognerebbe chiederlo a loro!! comunque secondo me è meglio, metti il colore che più ti piace!!
  10. #2949
    Venezia
    S4 & G3
    quelli che ho provato mi hanno sempre dato qualche problema. Gli ultimi 2 non li ho provati.
  11. #2950
    Ho installato MisjudgedTwat's UNOFFICIAL BUILD RC1-12 + il pack bangmod, il processore li porta a 1312 mhz secondo voi puo dare priblemi? In caso cosa mi consigliate di fare? Vi ringrazio.
LinkBacks (?)
