Pagina 65 di 302 primaprima ... 1555636465666775115165 ... ultimoultimo
Visualizzazione dei risultati da 641 a 650 su 3012
[ROM][LP 5.0.x] Stock modded by Cuoco92 per Nubia Z7 Mini [NX507J]
  1. #641
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Quote Originariamente inviato da Estiquatsee Visualizza il messaggio
    Cuoco, visto che sono ancora in versione provvisoria con la 78,conviene che installi nuovamente la rom con le opzioni "wipe data" (questo eliminerà ogni traccia della vecchia rom), "wipe cache" e "wipe dalvik cache" (contenuta nel menu "advanced").
    Si fai semplicemente un FACTORY reset dal menù WIPE (swipe da sinistra a destra) senza entrare in quello avanzato.
    Aug 2014
    Ringraziato 47 volte in 37 Posts
    Ci ho provato ma compare un errore: "E: unable to mount storage" scritto in rosso, anche nell'installare la rom.
    Come mai?
    Ultima modifica di Estiquatsee; 15-05-15 alle 15:53
  4. #643
    May 2015
    Montenegro
    Lightbulb
    [quote name="Dzemper" post=6838010]Hi guys,
    Sorry that I'm writting in English, but my Italian is not great.
    So, I have installed stock V3.01 via nubia tool 2.0 and after that i have instaled CM 12.1 via TWRP (which is crap; battery and memory drainer!).
    Now I want to go to Cuoco92's ROM but when I'm trying to flash it TWRP says that I must go to the stock first.
    How to go back to the stock? Flash NX507J_CNCommon_V3.01.TAR via TWRP? Or use Nubia tool again (but nubia tool is not recomended to use if you are not on the stock!)?
    Anyone?
    Thanks.
    The Cuoco Rom contains a check into updater script which verify that you are on 3.01 before to proceed....best practice is to make a twrp backup of the 3.01 stock before to install others Rom so that you can easily go back to stock....
    I think now you can only try to get stock via nubia tool....hoping installation goes smoothly... But indeed never tried on cm12
    If anybody has a problem to go from CM 12.1 to Cuoco92 custom rom, here is solution that has worked for me.
    i didn't have TWRP backup of stock, so I did as follows:
    - found a custom rom online that is based on 3.01 (rom must be packed as twrp backup, you will find one at smartdigi)
    - copy TWRP backup to internal memory
    - factory reset in TWRP
    - system wipe in TWRP
    - restore TWRP backup
    - reboot your phone twice
    - install Cuoco92 rom as usual and rock
    Ultima modifica di Dzemper; 15-05-15 alle 20:21
  5. Il seguente Utente ha ringraziato Dzemper per il post:
    BB72 (15-05-15)
  6. #644
    Nubia Z7 mini
    Ringraziato 24 volte in 21 Posts
    Scusate ma come si cambia lo sfondo alla lock screen? Mi vergogno un po' a fare questa domanda.. 😊
  7. #645
    Salve ragazzi, spero possiate darmi una mano. Sto provando a decomprimere la cartella di formato tar del firmware 3.01 da flashare con il nubia tool, ma con winraar mi estrae un sacco di file strani senza la cartella "common" da flashare col tool. Avete suggerimenti?grazie
  8. #646
    Aug 2014
    [quote name="Cuoco92" post=6845019][quote name="Estiquatsee" post=6844978]Cuoco, visto che sono ancora in versione provvisoria con la 78,conviene che installi nuovamente la rom con le opzioni "wipe data" (questo eliminerà ogni traccia della vecchia rom), "wipe cache" e "wipe dalvik cache" (contenuta nel menu "advanced").
    Inviato dal mio NX507J usando Androidiani App[/QUOTE]
    Si fai semplicemente un FACTORY reset dal menù WIPE (swipe da sinistra a destra) senza entrare in quello avanzato.[/QUOTE]
    Allora, rifatto tutto dal nubia tool in poi..
    Aviate continua a crashare, ho capito che lo fa quando deve gestire le App.
    Qualche idea del motivo?
    Altro baco che sembrava risolto: anche a GPS spento dalle impostazioni rimane accesa l'icona nella nata superiore.
    Ultima modifica di Estiquatsee; 16-05-15 alle 09:42
  9. #647
    Androidiano L'avatar di paudino
    ZTE V987 - Nubia Z7 mini
    Ciao, problemino con App WhatsApp quando si entra in info contatto o gruppo, l'app si blocca, ho provato ad disinstallare e reinstallare ma nulla. Consigli ?
    Paudino.
  10. #648
    Mar 2010
    HTC Hero - GS2 - Z7 mini
    Ringraziato 39 volte in 32 Posts
    Quote Originariamente inviato da Cuoco92 Visualizza il messaggio
    No, no one 😉 just disable Wipe Cache Form update window.
    In prima pagina ho messo un firmware aggiornato (2.75) Lo trovate nella sezione FIRMWARE
    Installatelo SENZA NESSUN WIPE
    Scusa Cuoco, ma sono stato assente per un po ed ora leggendo tutto quello che mi sono perso non ci sto capendo piu' nulla.
    Io sono con la ROM:
    NX507J_EUROPA_V3.01_cuoco92&BB72
    aggiornato alla 2.78
    devo fare l'aggiornamento che dici o e' semplicemente la rom pre-aggiornata alla 2.75?
    E quindi sto bene cosi'?
    Ringraziato 23 volte in 18 Posts
    Quote Originariamente inviato da paudino Visualizza il messaggio
    Paudino.
    Succede anche a me, lo fa dall'ultimo aggiornamento dell'applicazione
  12. #650
    Aug 2014
    Quote Originariamente inviato da kekkoss Visualizza il messaggio
    [quote name="paudino" post=6846641]Ciao, problemino con App WhatsApp quando si entra in info contatto o gruppo, l'app si blocca, ho provato ad disinstallare e reinstallare ma nulla. Consigli ?
    Paudino.
    A me non capita, whatsapp tutto ok...
