Pagina 128 di 290 primaprima ... 2878118126127128129130138178228 ... ultimoultimo
Visualizzazione dei risultati da 1,271 a 1,280 su 2900
[ONLINE] X-NOTE build 17.0 ( N9005 )
  1. #1271
    Nov 2013
    Sì certo...ho flashato 2 mila rom diverse con l'htc one e non ho mai avuto problemi...potresti mandarmi i link della corretta recovery e del download della rom per favore ? Così provo a rifare tutto da capo
    Androidiano VIP L'avatar di soloilmeglio
    N7100 - N8000
    Ringraziato 1,796 volte in 1,191 Posts
    upload inizia tra poco... abbiamo chiuso
    COMPLETE FEATURES (new features in red)
    • Based on Germany samsumg firmware NB4 modified to have region free
    • the system will start at 360 dpi by default as now almost all apps are multi dpi ready (only Samsung Email have big characters when writing a email in some density, recommended to install in aroma AOSP email)
    • added new density 289 dpi with automatic switch system UI in phablet mode
    • reworked snote, now perfect layout at all screen densities
    • multi dpi samsung file manager
    • page buddy themed
    • more transparent accuweather widget and multi dpi
    • launcher grid selection 4x4 or 5x4 (aroma) all multi dpi
    • samsung gallery multidpi reworked
    • Hide / show home button and lock button in status bar, in left or right side, all controlled by X-Note application (tip: at first boot select all 4 option in x-note app, reboot systemUI, unselect all, reboot systemUI then you can do whatever you want)
    • Complete system UI switching with X-Note app (the phone will autoreboot in 5 seconds after selection), you can choose:
      * Default X-Note theme
      * AOSP theme
      * Galaxy S5 theme (if you enable gravity box, the original notification panel color code is #033268 )
    • Added Universal INIT.D enabler (linked in X-Note app) to run Init.d script at boot even with stock kernel
    • Added (X-Note app) ability to choose the number of visible toggles (4-5-6-7-8-9-10)
    • Added (X-Note app) ability to enable/disable the additional toggles
    • Added (X-Note app) torch Toggle (removed xposed torch module)
    • Show/Hide (X-Note app) week day in status bar
    • Ability to change status bar color (so you can change color even without enabling the x-posed gravity box module)
    • Ability to change traffic meter color (tip: at first boot just tap on hide/show traffic meter to unlock the color option)
    • Added Notification Toggle application (linked in xnote app)
    • Added Xposed module to fully control the Google Home launcher (available with KitKat AOSP apps in aroma)
    • added in OTA all available samsung camera filters
    • enabled Galaxy S5 Settings (Grid view and list view). You will have 2 settings icon in your drawer, just use your favourite
    • Download Optimizer available in Galaxy s5 settings (to use both wifi and mobile data for huge files downloading)
    • air browse available in Galaxy S5 settings (scroll internet pages with air gestures)
    • reworked samsung photo editor multi dpi
    • hide/show lock button in status bar (longpress opens power menu)
    • hide/show clock in status bar + hide/show AM-PM
    • reworked samsung clock multi dpi
    • more wallpapers (70) in sec Wallpaper chooser (new gradient wallpapers)
    • added x note banner in device info settings
    • added Yahoo Weather (aroma)
    • Super user and other apps updated
    • Deodexed + busybox (modified binary - NO reboot issue with root applications)
    • kernel selection (aroma) - NEW X-Kernel v.1.5 release + UNTOUCHED stock kernel
    • Zipalign new applications at boot and db optimize
    • New bootanimation to celebrate the KitKat taste ahhahahaha
    • Knox free
    • aroma installer
    • csc could be selected in aroma during installation (France - Germany - UK - Italy - Poland)
    • sound mod selection (aroma)
    • enable/disable some system sound (aroma)
    • enabled multi instance for +6000 most used applications
    • X-transformer feature ... almost all Samsung application reworked to fit all dpi + 289 dpi density:
      Tips:
      - Samsung Email have big characters when writing a email in some density, recommended to install in aroma AOSP email or use Xposed
      - Use Xlarge res (with xposed app settings module) for samsung Video app (com.samsung.everglades.video) at lower densities
    • X-Transformer application (credits @xperiacle for the main code) updated with new densities and enable/disable nav bar + softkeys:
      289 + nav bar option + enable/disable softkeys option + automatic switch to phablet layout
      300 + nav bar option + enable/disable softkeys option
      330 + nav bar option + enable/disable softkeys option
      360 + nav bar option + enable/disable softkeys option
      390 + nav bar option + enable/disable softkeys option
      420 + nav bar option + enable/disable softkeys option
      450 - no nav bar option - no softkey option
      480 - no nav bar option - no softkey option
      +custom (it will ask for nav bar and soktkeys between 289-420 dpi)
    • modified TW launcher with THEMES enabled (just longpress on home or select the option pressing menu key)
      Available themes APPLIED ON THE FLY WITHOUT REBOOTING (currently working on to build more themes)
      - SAMSUNG BASIC
      - X-NOTE CHROME
      - X-NOTE HTC
      - X-NOTE IOS7
      - X-NOTE JB
      - X-NOTE KITKAT
      - X-NOTE DEFAULT
    • launcher selection (aroma)
    • sview now is fixed at all dpi
    • mms max size 2048000 bytes, also increase the mms image size to 4096x2048
    • sms 1000 unlimited recipient limit
    • quick office app
    • no increasing ringtone enable/disable (xposed module)
    • Modded settings with link to X-NOTE APPLICATION
    • All application can be easy selected to have in floating window. Credits @xperiacle and his great application
    • Multiwindow manager app by @xperiacle ... thanks a lot for your contribution to the galaxy note 3 community
    • 4 way reboot menu
    • Sound boost mod via x-note app (3 levels... stock, medium, strong)
    • customized some UI sound
    • themed SPlanner
    • Face unlock
    • Cpu monitor (Xnote app)
    • Cpu spy (Xnote app)
    • AD Away (Xnote app)
    • LMT for gesture and pie (Xnote app)
    • OFFICIAL status in settings (instead of modified)
    • Xposed framework
    • Xposed per app density (set many options for each app included dpi density)
    • disabled infinite scrolling in launcher (I like more)
    • Fully themed with X-Note default theme (See screenshots)
    • Enabled secondary symbols on stock samsung keyboard
    • Camera with shutter sound on/off option
    • Browser with exit option
    • Unlocked call and message block settings
    • Sms will display sent time instead off received time
    • Unlimited contacts join
    • Greenify app
    • NEW extra fonts available by default (nice!) + ifont app.
    • Donators, supporters and credits are mentioned in xnote application
    • fully customizable battery bar with animation all controlled by battery bar application (credits to pvyParts). To apply modification please restart only systemUI (read below)
    • X note restart application with option to restart only systemui to apply mods (it will asks root permissions)
    • modified default System UI (now clear button is on top like aosp + removed the screen off button)
    • Speedmeter
    • Disabled SMS, MMS, And Email Log History In Call Logs
    • Enable Split-view Mode On/Off Toggle in Mms
    • Added AOSP app selection in aroma (samsung will be not removed so you will have samsung+AOSP)
      - Calculator
      - Google Calendar
      - Google Home Launcher
      - Clock
      - Google Keep
      - ThinkLeft SMS (similar to aosp, can be selected as default sms application with the option to have standalone without the sammy app)
      - Movie Studio
      - Chronus Clock/Meteo widget (similar to the cyano clock)
    • Ability to control the Screen Off effect (stock, fade, CRT) VIA GRAVITY BOX (the modules has many working features)
    • Viper4Android sound mod (aroma) credits to @zhuhang http://forum.xda-developers.com/show....php?t=2191223 please support him too, the mod is awesome!!!
    • xposed addition module that allow to remap all hardware buttons (skip track, kill application and so on)
    • removed notify clean module the same function is in gravity box module
    • intelli3g x-posed module - automate 2g/3g switch to save battery
    • X-Note app updated with tons of new features
    • X-Off Widget to simple turn off the screen from home
    • REMOVED Multiwindow Plus - the same function now is included in xnote application (4 window mod) to avoid warning dialogs
    • added CrappaLinks xposed module to avoid redirectering links from applications
    • Ability to hide/show the network speed indicator
    • Unlock text and shortcuts on/off now available in x-note app too
    • Ability to enable/disable on the fly the infinite scrolling in TW launcher
    • Ability to enable/disable on the fly the wallpaper scrolling in TW launcher
    • Ink effect CUSTOM COLOR now available and included in x-note app credits to @mythtrandyr (of course working also with finger)
    • added keyboard theme selection (aroma):
      - black
      - grey
      - white - credits to my friend @DaOldMan
    • added alternative OTA host in x-note app
    • Increased TW launcher home grid and Hotset icon number (please replace your widgets at first boot)
    • Ability to show/hide alarm, bluetooth, sound icon in status bar (restart systemui to apply)
    • EXTRA toggles enabled by default with ability to disable it via x-note application
    • Multi dpi PlayStore updated
    • added email client selection (aroma): AOSP client / Samsung client
    • Timely application
    • Youtube AdAway module
    • Xui Mod Module
    • AOSP THEME AND DEFAULT THEME AVAILABLE IN OTA (credits to my friend @foreverloco that giving me permission to take many png images and save me lot of time!!!)
    • softkeys can be also enabled/disabled via X-note app
    If you like my work and wants to keep the project alive please consider to buy me a glass of red wine or a toy for my dog
  4. I seguenti 3 Utenti hanno ringraziato soloilmeglio per il post:
    ermaglia (28-02-14),Gilles72 (02-03-14),lorenzo63 (28-02-14)
  5. #1273
    Senior Droid L'avatar di Zacca90
    S10+ 128gb Prism Black
    Ringraziato 41 volte in 32 Posts
    Cosa leggono i miei occhi.. so prospetta un fine settimana all'insegna del modding...😆😆😆😆
  6. #1274
    Senior Droid L'avatar di gionnyb89
    Oooooohooooooo *o* bella roba...ma se leggo bene Solo avete implementato anche la possibilità di spostare i button home e lock sulla statusbar a piacimento destra/sinistra? Ho non capito na mazza?
  7. #1275
    N7100 - N8000
    scambio destra sinistra + entrambi a destra o entrambi sinistra
  8. Il seguente Utente ha ringraziato soloilmeglio per il post:
    gionnyb89 (28-02-14)
  9. #1276
    Nov 2013
    ragazzi ho risolto...e sapete cos'era ??? dovevo rinominare il file da .rar a .zip.....ma i wipe li fa in automatico giusto ??? o li devo fare io prima di installare la rom ??comunque grazie a tutti per l'aiuto e le risposte sempre rapide, mi scuso con i coordinatori e i moderatori se ho usato sezioni sbagliate e vi faccio i complimenti !!! ottima app e ottimo forum !!
  10. #1277
    Nov 2010
    galaxy nexus
    Grandissimo e uscitaaaaa ecco il post su xda col link 😆😆😆
    http://forum.xda-developers.com/show...php?p=50688151
    Ultima modifica di xxfedexx; 28-02-14 alle 01:26
  11. Il seguente Utente ha ringraziato xxfedexx per il post:
  12. #1278
    Nov 2013
    raga tutto ok ho installato la rom...ma come personalizzo la schermata di blocco schermo e quei widget che si vedono nella foto ad anello come faccio a metterli ? intendo si possono mettere nella lock screen ?
  13. #1279
    Oct 2013
    Ringraziato 22 volte in 21 Posts
    Quote Originariamente inviato da gionnyb89 Visualizza il messaggio
    Im più se non ho capito male viene ripreso il nuovo tema delle impostazioni del nuovo galaxy s5. ..giusto? ?? Ma che grandi è appena stato presentato a Barcellona. ...
  14. #1280
    GT-I9505 <3
    Ringraziato 28 volte in 24 Posts
    Grande..il tema s5 è in aroma?
    Device:I-900F White
    Rom : X-Note v1.1
    Kernel : X-Note v1
    Recovery : CWM
