Pagina 60 di 63 primaprima ... 10505859606162 ... ultimoultimo
Visualizzazione dei risultati da 591 a 600 su 623
[ROM][LP][5.1.1r26] Resurrection Remix [CM 12.1/UBER 4.9]
  1. #591
    Moderatore L'avatar di 8thphloor
    ONEPLUS2, NOTE2, NEXUS 7 2013
    Ringraziato 2,944 volte in 1,616 Posts
    Quote Originariamente inviato da Coach85 Visualizza il messaggio
    A me è arrivato un nuovo aggiornamento..
    Resurrection Remix- v5.5.9 Lollipop-5.1.1_r26
    Android 5.1.1_r24->5.1.1_r26
    Kernel Auditor Tile
    Add Option For 5 Tiles Per Row in QS
    *Include GCC version and Info (for Optimized Builds Only, See Note Below (for maintainers only)) *
    base: don't show reboot options for safe mode
    perf: Add support for additional power profiles
    SystemUI: update keyguard state when profiles disable keyguard
    FingerprintService: fix fingerprints disappearing
    Keyguard: fix fingerprint not starting after user switch
    SettingsProvider: load animation defaults into correct table
    Keyguard: Show backdrop when sim pin secure screen shown
    SystemUI: HeadsUp: Check if view isn't already in windowManager
    Fix crash if Exif-Tag buffer-length and component-count are both 0
    Update boosted audio files
    Fix NOT_RESTRICTED network capability and enforce it
    Don't mark NetworkRequests restricted when they don't have restricted caps
    base: get rid of android time class
    Listen phone state change
    Shell: Declare cyanogenmod WRITE for system and secure settings.
    Recents: Fix IndexOutOfBoundsException
    Settings: Add security level default string …
    Remove CM translations of security_patch …
    wifi Settings: Add a filter
    Settings : Update performance tile drawable reference
    HighTouchSensitivity : Add Settings preference
    settings: ensure we don't call isProtectedApp with an invalid reference …
    Settings: Made advanced reboot option avaliable from button settings.
    vendor: Remove instance of server=""
    Vendor: add opt-out for exFAT
    vendor: make cgroups files read-only for all users
    Merged All StageFright Patches
    Included All latest CM updates
    Improved Translations
    For Full Acitivity Track Github
    The answer to the ultimate question of life, the universe and everything is:
    CLEAN FLASH
    Ringraziato 28 volte in 22 Posts
    che bug/problemi ci sono con l'ultima versione?
    ci sono ancora problemi con i video?
    audio basso?
    altro?
    poi volevo sapere se volessi tornare a una rom su base tw 4.4.2 opp 4.4.4 posso farlo tranquillamente flashando la rom o devo passare da odin?
    Ultima modifica di Gianluca85; 26-11-15 alle 15:45
  4. #593
    Nov 2010
    Io non visto ne sentito grande differenze. Devo sempre fleggare owerlay hv in opzioni sviluppatore per i video e la fotocamera se usata con le app. Monto il kernel agni.
  5. Il seguente Utente ha ringraziato krft72 per il post:
    hgagge (29-11-15)
  6. #594
    ciao a tutti, purtroppo da quando ho istallato questa rom sul mio note 2 , anzicchè migliorare ha avuto il colpo di grazia, video che crashano, fotocamera che crasha, sim che si disconnette e si riconnette solo dopo 5-6 riavvii, audio video pessimo gracchia e basta , non si sente nulla...insomma , tanti problemi, vorrei ritornare ad una versione stock di samsung ma non so quale istallare, vorrei istallare l'ultima, mi potreste indicare quale è? istallando versione stoc perdo anche la recovery oppure no? come istallo la versione stock? sempre da istall in recovery come ho istallato questa? grazie
  7. #595
    Zêna - Pianeta Genoa
    Mate 20 Pro
    Ringraziato 7,418 volte in 5,980 Posts
    Quote Originariamente inviato da remoflash Visualizza il messaggio
    Domanda da Pronto Soccorso Modding
    https://www.androidiani.com/forum/sh...d.php?t=201998
    - Riporta i dati che hai facendo *#1234#
    - Sì, perdi la Recovery Custom
    - Il Flash lo si fa con Odin
    Queste le notizie base...
    Per approfondire usa il thread linkato
    Ultima modifica di Varioflex; 04-12-15 alle 07:42
    ___________________
  8. #596
    Quote Originariamente inviato da Varioflex Visualizza il messaggio
    Grazie mille ,allora chiedo di lì...
  9. #597
    Nov 2010
    Qualcuno di voi ha provato la nuova RR?
    http://forum.xda-developers.com/gala...5-6-0-t3278709
  10. #598
    Ciao ragazzi,
    ho un problema abbastanza serio con questa ROM, che stranamente è partito da quando ho fatto il passaggio a Vodafone.
    In pratica, quando sono in auto, e faccio partire una chiamata col bluetooth (ho il Parrot) di colpo cade completamente la linea e appare l'errore Rete Mobile non disponibile.
    Di contro se mi chiamano riesco a rispondere ma non sento l'audio.
    Mi potete aiutare?
  11. #599
    Androidiano L'avatar di AlessioDiggia88
    Sep 2013
    Note I, Note II
    Ho la ditto note 3 con la quale mi trovo benissimo, sto aspettando da almeno 3 mesi che questa rom diventi matura ma ogni volta che ricontrollo ci sono sempre tantissimi post di utenti che hanno problemi, sono sconsolato. Chissà quanto ci vorrà? Anche perchè oramai le rom per il note 2 sono quasi tutte abbandonate
    Super Androidiano
  12. #600
    Sassari
    LG G2, LeMax 2
    Quote Originariamente inviato da AlessioDiggia88 Visualizza il messaggio
    Sarebbe interessante sapere a quali problemi ti riferisci....
    Smartphone:
