Pagina 19 di 60 primaprima ... 9171819202129 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 592
[BRICK] Galaxy Note con ICS stock Recovery SOS & TEST !!
  1. #181
    Apr 2010
    Droidland
    Quote Originariamente inviato da falk88 Visualizza il messaggio
    questo AbyssNotekernel42CWTouchCustomLogo.zip?
    si metti questo flashalo da recovery poi ripristina un nandroid e dimmi cosa fa
    per il metodo della ricreazione del layout partizioni,male che vada hai messo in difficolta i il sig samsung cosi non e accessibile nulla nemmeno a loro..
    Ultima modifica di thay; 16-05-12 alle 22:57
    Riserva Navajo
    Su xda un utente ha scritto cio:
    I have tried using "parted" in the method described in the link and can see all the partitions of the Note as in the screen short file attached. That means the method should work and should let people see if one of their partition is damaged and then can recreate it. Or at least we can identify if the problems is with damaged one or more partition or something else.
    If you can run the parted command under adb shell then you can compare the partitions of your (soft-brick) note and see if it is different from the original partitions I posted in the picture. If you can still flash kernel but could not flash system rom then it is likely that the system partition (in Note they name it "FACTORYFS' or/and the data partition, named as 'DATAFS", have been faulty. The good thing is Note has a large SD card partition (they name it "UMS" therefore you can resize it to smaller size and use the free space to create the replacement partition (using parted commands as in the thread I posted above) for the system or/and data partition. For the damage partition you just need to delete them (using parted commands) and those areas become unused space and they cause no harm.
    Let me know if you have problem running the "parted" application. Maybe I could help.
    Che dite ci provo?
    come volevasi dimostrare il problema è la partizione rovinata.....
  4. #183
    Androidiano VIP L'avatar di pglmro
    GT-I9300++
    Ringraziato 712 volte in 527 Posts
    io però non capisco, odin dovrebbe ripartizionare col PIT.. perchè non va invece?
  5. #184
    Riserva Navajo
    Quote Originariamente inviato da pglmro Visualizza il messaggio
    perchè odin parte a leggere una partizione corretta per poi riscriverne una nuova ma se la partizione non è corretta o rovinata si blocca e non la riconosce
  6. #185
    Androidiano VIP L'avatar di vampireblood
    Galaxy Nexus
    Ringraziato 408 volte in 374 Posts
    bel casino proprio, speriamo che l'arcano venga scovato al più presto e risolto...
    Ultima modifica di vampireblood; 16-05-12 alle 23:06
  7. #186
    Mar 2011
    Google Nexus 4
    Ringraziato 67 volte in 37 Posts
    Aiutatemi vi prego,io ho flashato ics con successo come da guida,poi sicocme non avevo effettuato wipe dalvik e cache perchè non avevo su la cwm in quel momento, allora ho pensaato di utilizzare quella della singapore procedure,e quindi ho avviato la cwm appunto della singapore,tramire recovery quindi,e da li intendevo effettuare i 3 wipe,ma al primo wipe in pratica,il cell è rimasto su wipe data per un mare di tempo,palesemente bloccato,da allora la recovery non mi parte,ma mi va in download mode,purtroppo però se tento di flashare tramite odin nuovamente,non effetta alcun che..resta bloccato,vi scongiuro aiutatemi..
  8. #187
    Androidiano L'avatar di falk88
    Philippines
    Galaxy Note, iPhone 4
    Ringraziato 33 volte in 17 Posts
    D odin ho messo solo il pit per ripartizionare e lo ha fatto ma cmq non si riesce a skiodarlo dal factory
  9. #188
    Riserva Navajo
    Quote Originariamente inviato da daridima Visualizza il messaggio
    ma da CWM hai effettuato wipe factory reset ?
  10. #189
    Galaxy Nexus
    hai fatto varie prove di flash senza risultato???
  11. #190
    GT-I9300++
    Quote Originariamente inviato da vampireblood Visualizza il messaggio
    bisognerebbe riuscire a partizionare per poi usare odin
