Pagina 20 di 121 primaprima ... 1018192021223070120 ... ultimoultimo
Visualizzazione dei risultati da 191 a 200 su 1210
[ROM] [ICS] AOKP Android Open Kang Project - GT-N7000
  1. #191
    Androidiano VIP L'avatar di vampireblood
    Galaxy Nexus
    Ringraziato 408 volte in 374 Posts
    Quote Originariamente inviato da sondra Visualizza il messaggio
    Migliorie della 38?
    -reverted tablet nav bar button padding change (back to stock ics padding now)
    -fix SMS/BT crash bug when no msgs exist
    -reworked lockscreen music layout to be cleaner
    -fix ugly gradient on dark holo background
    -added AOKP Tips widget
    -added statusbar autohide for tablets (for apps that need full screen)
    -added support for more lockscreen targets (2-8 options, your choice)
    -cleaned up octo lockscreen layout
    -fixed certain FCs with RC related to weather
    -Mms: fixed stripping certain Polish characters
    -decreased size of custom lockscreen apps to match other icons
    -statusbar brightness enabled by default after you wipe (sliding thumb across statusbar to change brightness)
    -added statusbar notification counter (RC > Statusbar General > Notification Counter)
    -new AOKP boot animation from @rascarlo
    -Out of range Bluetooth devices won't show up anymore in Settings
    -Browser: added option to close all other tabs (besides current)
    -Fixed data toggle
    -Removed requirement to reboot when toggling keyboard switcher (IME switcher) in statusbar
    -added nav bar widgets (to enable, go to nav bar settings > add toggle widgets as one of your nav bar actions/ long press actions, then add widgets -- be sure to add at least 2 for best --experience)
    -as always, tons of fixes for devices and other backend fixes!
    Androidiano L'avatar di aquariusp
    H815 LG G4
    Migliorie della 38?
    Fixati bugs su lockscreen e toggle... più altri fix minori...
  4. #193
    Galaxy Nexus
    flashata adesso la r38vediamo
  5. #194
    Senior Droid L'avatar di King Elessar Telcontar
    Xiaomi Mi5
    Ringraziato 62 volte in 59 Posts
    Quote Originariamente inviato da vampireblood Visualizza il messaggio
    Fammi sapere, in caso la provo
    Possiamo solo decidere cosa fare con il tempo che ci è stato concesso...
  6. #195
    Galaxy Nexus
    Quote Originariamente inviato da King Elessar Telcontar Visualizza il messaggio
    Bhe il bug della loocscreen sembra scomparso(anche se prima non me lo faceva sempre)...il toggle dati ancora non c'è e non so perchè...bisogna anche riflashare le gapps(per coloro questo passaggio non era sotto inteso)la batteria sembra un pochino scendere ma sicuramente si riprenderà già al secondo ciclo di scarica...e per il momento questo è ciò che posso dire di questa r38
    Inviato dal mio Galaxy Note con la MAGNIFICA AOKP Android Open Kang Project ROM
  7. Il seguente Utente ha ringraziato vampireblood per il post:
    hiace (05-06-12)
  8. #196
    Feb 2011
    Torre Annunziata (NA)
    G Note 3
    Ringraziato 32 volte in 28 Posts
    In merito al bug dell accensione del Note quando lo si mette sotto carica ?
  9. #197
    Androidiano VIP L'avatar di sondra
    Jun 2010
    brianza
    galaxy note
    Ringraziato 654 volte in 527 Posts
    Resta comunque sicura da brick....
  10. #198
    Gia per quello io l'ho flashata......per il resto la 38 va davvero benissimo, io la tengo in modalità tablet a 213 dpi la batteria mi dura due giorni se non ci smanetto troppo ma con un uso normale......che dire, ne vale davvero la pena per me......
  11. #199
    Senior Droid L'avatar di Maurizio7013
    Ringraziato 34 volte in 30 Posts
    Migliore questa o la Paranoid?
  12. #200
    l hanno gia chiesto mille volte ma dalla king 2.1 cche procexura devo seguire?
