Pagina 130 di 284 primaprima ... 3080120128129130131132140180230 ... ultimoultimo
Visualizzazione dei risultati da 1,291 a 1,300 su 2840
[KERNEL] gl NOTECORE * Safe Kernel * ICS N7000
  1. #1291
    Androidiano VIP L'avatar di wolvie80
    Cameri (NO)
    Ringraziato 958 volte in 648 Posts
    Dalla 5.x sempre auello normale, non va mai in difficolta ed è fluissimo per edesso non sento il bisogno di provare quello overclockato.
    Inviato dal mio non so cosa con Tapatalk
    Androidiano VIP L'avatar di OverDrive
    Jul 2010
    Samsung Galaxy Note
    Ringraziato 217 volte in 182 Posts
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    Download:
    v10 - CWM zip - http://hecubus.com/xda/kernel/GL_NOTECORE_V10_Uni.zip
    v10 - ODIN tar - http://hecubus.com/xda/kernel/GL_NOTECORE_v10_Uni.tar
    (remember this is an overclocked kernel so it wont work for everyone - if you get no boot reboot to download mode and flash the ODIN version of the STANDARD kernel below)
    STANDARD KERNEL - NO OVERCLOCKING
    This will work on all phones, even those incapable of running the universal version
    v10 STANDARD CWM zip - http://hecubus.com/xda/kernel/GL_NOTECORE_V10.zip
    v10 STANDARD ODIN tar - http://hecubus.com/xda/kernel/GL_NOTECORE_v10.tar
    INFO FOR DEVS / ROM COOKERS
    If you choose to include this kernel in your ROM, please feel free to do so. however, please only include the "STANDARD" version to avoid the possibility that "Universal" will not work for everyone filling your threads with "my phone wont boot" etc etc.
    Changelog
    v10
    - Added universal voltage tables that cover both discovered versions of the motherboard for better stability, battery life and less heat for everyone
    - Settings > About in "kernel version" will tell you (and us) what Voltage table your phone is using
    - Performance improvements
    - Maybe enabled 32bit colour on the display
    - VM tweaks
    - CPU frequency change latency changed in init code
    Sei in ritardo di qualche post
  4. #1293
    Senior Droid L'avatar di 1xxDIMAxx1
    Pordenone
    Iph 4-S2-Note1-S3-N8000-Note2
    Ciao.
    Raga io ho notecore. V8.1.
    Quale allora e migliore che devo flasha la. V9 o la v.10. Parlo sempre di standart kernel.
    Poi per favore potete likarmi solomante il script per la pulizia. Non il sito di xda xche li ce ne sono 3ink e non so quale. Grazie
  5. #1294
    Androidiano VIP L'avatar di jokerpoker1
    latina
    mitico galaxy note 2
    Ringraziato 1,255 volte in 943 Posts
    Quote Originariamente inviato da topinojerry Visualizza il messaggio
    anche io vorrei saperlo
    normale tutta la vita
  6. #1295
    Androidiano VIP L'avatar di tataccio
    roma
    Al momento p10
    Ringraziato 149 volte in 135 Posts
    Flashato vediamo se migliora la batteria..
  7. #1296
    Campobasso
    Lg G4
    Ringraziato 15 volte in 10 Posts
    Ragazzi ma cosa cambia tra l'universale e lo standard grazieeee :-)
  8. #1297
    Senior Droid L'avatar di mark1
    vicino Viterbo
    In decisione...
    Ringraziato 103 volte in 93 Posts
    Quote Originariamente inviato da claudioup
    Su xda hanno scoperto che esistono diverse versioni di mobo per i note...
    Per ora si chiamano tipo A e tipo B.
    Sembra che la differenza sia nei voltaggi di cpu e gpu, almeno questo è quello che è stato scoperto finora....
    Il kernel universale riconosce la mobo e setta voltaggi custom per permettere a tutti di poter usare gli 1.6ghz.
    La mobo tipo A ha voltaggi leggermente più alti della tipo B.
    La vostra versione di mobo è deducibile da tegrak guardando i voltaggi di processore e gpu, oppure flash and il kernel universale e guardando alla voce info kernel in impoatazioni....
    Io ho la mobo B, e voi?
  9. #1298
    Riserva Navajo
    Quote Originariamente inviato da mark1 Visualizza il messaggio
    tipo B come babbione
  10. #1299
    roma
    Al momento p10
    Tipo A... Monto quello universale
  11. #1300
    Campobasso
    Lg G4
    Gruppo b :-)
