Pagina 36 di 79 primaprima ... 26343536373846 ... ultimoultimo
Visualizzazione dei risultati da 351 a 360 su 781
Delirium n7000 XXLSA JB 4.1.2
  1. #351
    Ringraziato 2 volte in 1 Post
    R: Delirium n7000 XXLSA JB 4.1.2
    Adesso finalmente va abbastanza bene... la v1.0 era inutilizzabile!
    Androidiani Power User L'avatar di ntony17
    Plutone
    G Note (PiastrellaPhone)
    Ringraziato 1,673 volte in 1,138 Posts
    Quote Originariamente inviato da Meda Visualizza il messaggio
    pare la lsa completa.
    sfatt che dici di fare una stock deodexed, zipaligned, rooted version con kernel philz per farcela provare?
    così avrai poi il tempo per studiartela e fare la tua delirium con questa base...
    Hotfile.com: 1-CLICK Dateihoster: N7000XXLSA_N7000OXALSA_DBT.zip
    We have FULLY TESTED this firmware and this firmware works perfectly as any other official firmware.
    Some of the Enhancements in the new Jelly Bean Update:
    - Android 4.1.2 – Build JZO54K
    - Buttery Smooth Performance & Great Stability (Thanks to Project Butter)
    - Multi-View (Multi Windows Multitasking, same as in Note II)
    - Multi-View can also be disabled
    - Page Buddy
    - Notification Panel can now be customized
    - New Additions in Notification Panel
    - Smart Rotation (Screen Display adjusts to your angle of sightings)
    - Continues Input in Samsung Keyboard (Like Swipe or Android 4.2 Keyboard)
    - Samsung’s Cloud services
    - Direct Call, Smart Stay and Pop-up Play Features
    - New Widgets From the Galaxy S III
    - 2 Home screen modes
    - New Notifications bar
    - Google Now
    This is a PRE-RELEASE version not official from KIES.
    As this is a PRE-RELEASE firmware so expect some minor bugs.
    Firmware Details:
    Android Version: 4.1.2 – JZO54K (Jelly Bean)
    PDA: N7000XXLSA
    CSC: N7000OXALSA
    MODEM: N7000XXLSA
    Changelist: 549786
    Build Date: 20th November 2012
    Region: Europe
    Country: Germany
    Download: N7000XXLSA_N7000OXALSA_DBT.zip
    Flashing Instructions:
    - Unzip the file
    - Open Odin 3.04 (Get it from HERE)
    - Restart phone in download mode (Home+power+vol down)
    - Connect phone and wait until you get a yellow sign in Odin
    - Add CODE_N7000XXLSA_549786_REV02_user_low_ship.tar.md5 to PDA
    - Add MODEM_N7000XXLSA_REV_05_CL1222228.tar.md5 to PHONE
    - Add CSC_OXA_N7000OXALSA_549786_REV02_user_low_ship.tar .md5 to CSC
    - Make sure re-partition NOT ticked
    - Start flash, sit back and wait a few minutes.
    qualcuno può linkare il thread di riferimento di xda????
  4. #353
    Cinisello B. (MI)
    S7 Edge
    Ringraziato 582 volte in 412 Posts
    Ragazzi sono tornato!!! Premetto che la LS7 si è comportata bene
    Ora fatemi capire: della 1.1 non vedo link. E se Fabio ha intenzione di deodexare la stock nuova quasi quasi attendo.
    Mi fai sapere che cosa farai Sfatt?
    Galaxy S7 Edge - Galaxy Tab S2 8.0
  5. #354
  6. Il seguente Utente ha ringraziato twinmaster per il post:
    ntony17 (29-11-12)
  7. #355
    Androidiano VIP L'avatar di Sfattucci
    Caserta
    Tab S2 T715, S8 Plus, Gear S
    Ringraziato 6,165 volte in 2,803 Posts
    Quote Originariamente inviato da francanna Visualizza il messaggio
    La 1.1 repack ho rimesso il link ... e la sto provando da stanotte ... mai una piega ... liscia come l'olio ... ora per il firmware completo, stanotte quando torno da lavoro e ho più tempo do un occhiata ... magari ne parliamo qui e vediamo il da farsi col firmware completo, magari solo deodexed/zipalligned con root ... ma vi posso mai far flashare una rom al giorno?
    Delirium n9005 MMport 6.0.1 S7Edge - Note 5 - NewUX full features
    Delirium n9005 Kernel mmport 6.0.1 Linaro 6.0 Experimental + Patch Uber CortexA15
    Delirium Tab S2 T715 mm 6.0.1 ITV
    Delirium Tab S2 T715 Kernel mm 6.0.1 Linaro 6.0 Experimental
  8. #356
    Cinisello B. (MI)
    S7 Edge
    Ragazzi scintille si xda tra eybee e faryhad di sammobile. On sintesi sammobile ha dichiarato che è senza bug mentre eybee dice è la stessa 1:1 su cui hanno lavorato eybee e robbiehood.
    Insomma buona per chi vuole flashare da odin e tenerla cosi... ma credo che non abbia senso deodexarla e zipalinearla perché si otterrebbe quella di eybee da cui Sfat è partito.
  9. #357
    Caserta
    Stavo appunto leggendo sta cosa LOL ( e nel frattempo stavo preparando Odin 3.0.5 ) ... bah ... io intanto implemento l'unica cosa che manca ( la rotazione automatica con il volto in comodo zip flashabile) e poi vediamo che succede
  10. #358
    marche
    galaxy note
    Quote Originariamente inviato da Sfattucci Visualizza il messaggio
    Ciao sfattucci,l ho provata anche io stanotte,ed e“ veramente ottima.
    Ho provato a flesharci sopra qualche mod xxlsa ma non ne va uno
  11. #359
    Caserta
    Quote Originariamente inviato da kuky87 Visualizza il messaggio
    ciao sfattucci,l- ho provata anche io stanotte,ed [ veramente ottima.
    Di quali mod parli? Toggle? Mod grafiche? Mi pare strano che nessuna funzioni ... io sono a 240 dpi e ha funzionato ... poi altre mod non ne metto ... mi serve snello e scattante, infatti quella che uso io è ridotta all'osso ... molto di più di quella postata qui.
  12. #360
    Androidiano VIP L'avatar di Meda
    Samsung Galaxy S7 edge SMG935F
    Ringraziato 583 volte in 434 Posts
    Strano però. Questa ultima è oltre un giga, quella di eybee non mi sembrava così pesante. Boh. Stiamo a vedere.
    ____________________o____________________
    [ROM&KERNEL]: Sempre alla ricerca della migliore combinazione
