Pagina 7 di 55 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 544
[Rom][4.4.4][Team D.I.R.T] Dirty Unicorns v. 8.1 Ottobre 2014
  1. #61
    Riserva Navajo
    No a me con questa rom non ho mai avuto questo problema...l'avevo con la C-rom a volte
    Riserva Navajo
    fresh update
    du_n7000_4.4.4_20140708-0742.zip | du_n7000_4.4.4_20140708-0742.zip | by chasmodo for Galaxy Note
    Subject Status Owner Project Branch Updated CR V
    Update DU TBO Gapps 07-06 Merged Edwin Rivera packages_apps_Settings du44 1:18 AM
    Update Deb blobs to 4.4.3 Merged Dominic Meyer proprietary_vendor_asus du44 Jul 7
    Build with the correct kernel Merged Edwin Rivera android_device_asus_grouper du44 Jul 7
    Fix build Merged Edwin Rivera android_kernel_asus_grouper du44 Jul 7
    Integrate stats into settings [3/3] Merged Alex Cruz vendor_du du44 Jul 6
    Integrate stats into settings [2/3] Merged Alex Cruz manifest du44 Jul 6
    Integrate stats into settings [1/3] Merged Alex Cruz packages_apps_Settings du44 Jul 6
    Fetch from Gerrit instead of Github Merged James Taylor build du-44 Jul 6
    This way is better [2/2] Merged Alex Cruz vendor_du du44 Jul 6
    This way is better [1/2] Merged Alex Cruz packages_apps_DU_stats du44 Jul 6
    Oppo Find 7 June 27, 2014 changes: sound/soc Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    Find 7 June 27, 2014 changes: drivers/input/touchscreen/ Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    Find 7 June 27, 2014 changes: drivers/power/ Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    Find 7 June 27, 2014 changes: touchscreen firmware Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    enable qpnp-charger and bq24196-charger debugging Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    Oppo change: Adjust key backlight duration when the screen is turned on Merged chasmodo android_kernel_oppo_msm8974 du44 Jul 6
    Vendor: Add common-tablet.mk and common-tablet overlay Merged James Taylor vendor_du du44 Jul 6
    audio-caf-bfam: Update macro parameters Merged chasmodo android_hardware_qcom_audio-caf-bfam du44 Jul 6
    Added support for DC-HSPA+ also in opt/telephony Merged chasmodo frameworks_opt_telephony du44 Jul 6
    core and telephony: Additional HSPAP support Merged chasmodo frameworks_opt_telephony du44 Jul 6
    FW/B: forward port DC-HSPAP support from cm-10 Merged chasmodo frameworks_base du44 Jul 6
    Media: Add quality levels for two 4k resolutions for camcorder Merged chasmodo frameworks_base du44 Jul 6
    libgralloc: Suppress "using old API" warnings Merged chasmodo android_hardware_qcom_display-caf-bfam du44 Jul 6
    Track the following packages Merged Alex Cruz manifest du44 Jul 6
    Do not just silently fail if surface creation fails Merged chasmodo frameworks_native du44 Jul 6
    Next⇨
  4. Il seguente Utente ha ringraziato Andromeda1968 per il post:
    AlienwareAR (08-07-14)
  5. #63
    Jul 2010
    Ragazzi ho un problema, ho installato questa rom, e ho installato la SwiftKey ma non viene riconosciuta perfettamente, cioè quando clicco x scrivere la tastiera è "vuota" e poi come appare si vede fino all'ultima riga di lettere, la riga dove c'è la barra spaziatrice è coperta da una striscia bianca, come mai?? Grazie
  6. #64
    Androidiano VIP L'avatar di AlienwareAR
    Pavia & Milano
    Honor 8 Pro
    Ringraziato 337 volte in 303 Posts
    Quote Originariamente inviato da RobCZ Visualizza il messaggio
    Ciao!
    Il tuo stesso problema è stato riportato anche sul thread ufficiale XDA.
    Ecco qui di seguito le risposte dei vari utenti:
    chasmodo
    Ask SwiftKey dev team for help, that happens in a number of Roms.
    gaurav-11
    I've also faced the same problem in C - ROM, then below worked for me. Not sure if it is related, but you can give it a try.
    Setting > Language & Input > Keyboard & Input Methods then turn H/w keyboard OFF.
    Best of Luck.
    knedge
    If you are partial to Swiftkey, deselect all other keyboards from the options under Input Method and just keep Swiftkey selected.
    It will still take some time for Swiftkey to appear when you need to input text. May be 2 taps in the text area for it to appear but it will.
    I think this is a problem with Swiftkey for many months now. This is how I solved my problem.
    Prova a vedere se una di queste soluzioni funziona..!
  7. #65
    salve a tutti,al momento monto la delirium di sfattucci 4.4.2 e mi trovo abbastanza bene,anche i consumi sono buoni,però la rom ha poche personalizzazioni, e quindi vorrei provare questa rom che sembra molto buona.Vorrei sapere se è stabile e come sono i consumi.
    grazie in anticipo
  8. #66
    Riserva Navajo
    se leggi nelle pagine precedenti è stato scritto che i consumi sono abbastanza standard per le aosp KK quindi alti rispetto a JB va le personalizzazioni e tutte le altre features fanno si che queste tipo di rom siano davvero eccellenti
  9. #67
    Perfetto!! Allora rispetto alle altre mi consigli questa?
  10. #68
    Riserva Navajo
    Quote Originariamente inviato da Giulio1000 Visualizza il messaggio
    dalla mia esperienza posso dirti che la Dirty e la Kang rimangono le migliori....anche se la Crom e la Pacrom non sono affatto male ma hanno bugghetti fastidiosi purtroppo
  11. #69
    Ok grazie ancora, la scarico e la provo 😀
  12. #70
    Riserva Navajo
    Fresh test build is up at DU G+ community, folks.
    New: weather panel, SwiftKey bug fix, telephony and email enhancements, mali updated and security hole fixed in the kernel.
