Pagina 228 di 380 primaprima ... 128178218226227228229230238278328 ... ultimoultimo
Visualizzazione dei risultati da 2,271 a 2,280 su 3794
[ROM][ICS 4.0.4] CyanogenMod 9.1 [Thread Ufficiale by carminelnx]
  1. #2271
    Samsung Galaxy S i9000
    Forse x la nigtly di oggi? Riporto visto che il sito é quasi sempre down..
    to be included in next nightly:
    LockscreenWeather : Reset screen time out for manual sync (android_frameworks_base) Disable AM/PM style selection menu while 24-hour clock is selected (android_packages_apps_Settings) Fix an NullPointerException when finished (android_packages_apps_Mms) Do not set minimum value for mobile data limit dialog higher than the actual set value (android_packages_apps_Settings) Remove message notification while in conversation ui (android_packages_apps_Mms) Fix a StaleDataException issue when pressed MENU in busy (android_packages_apps_Mms) FinalizerWatchDog:Fix the daemon not to wake up target frequently. (android_libcore) Add two more GC parameter interfaces (android_libcore) Phone: Use ICS alert icon (android_packages_apps_Phone) dalvik: Increase HEAP_IDEAL_FREE to 7.2 MB (android_dalvik) Settings: Lock screen Calendar (Part 1 of 2) (android_packages_apps_Settings) Framework: Lock screen Calendar (Part 2 of 2) (android_frameworks_base) Browser: Use ICS alert icon (android_packages_apps_Browser) framworks/base: Changes to use MVS path for VoIP feature (android_frameworks_base) hardware/qcom: msm8660: Fix no voice issue in Voipcall (android_hardware_qcom_media) Navbar Settings : Modify visibility conditions (android_packages_apps_Settings) Settings: Use ICS alert drawable (android_packages_apps_Settings) Framework: Use ICS alert drawable (android_frameworks_base) Mms: Fix ic_dialog_alert usage (android_packages_apps_Mms) SuperUser: Use ICS alert icon (android_packages_apps_Superuser) frameworks/base: Enable LPA for music stream only. (android_frameworks_base) msm7x30: fix for SEMC devices with stereo hw speaker (android_hardware_qcom_media) french: Quiet hours, Volume and Weather (android_packages_apps_Settings) Settings (Weather, lock screen) hungarian translations (android_packages_apps_Settings) CM9-Settings-Update Russian Translation (android_packages_apps_Settings) Bind VolUp+VolDown to toggle the ringer (android_frameworks_base) Fix for Signal bars on Samsung devices (android_frameworks_base) QualcommSharedRIL: Fix restoring network mode preference on reboot. (android_frameworks_base)
    Inviato dal mio GT-I9000 con Tapatalk 2
    Senior Droid L'avatar di Evilken95
    Sant'anastasia (Na)
    Samsung galaxy s3
    Esiste un applicazione chiamata "cm-nightlies" che ci permette di vedere i changelog ...
    Inviato dal mio GT-I9000 usando Tapatalk
    Samsung Galaxy Note
    Jelly Bean 4.1.2 xxlsa leaked
  4. #2273
    Androidiano L'avatar di dasnichts
    Oneplus One 64gb
    in download ci sono 2 nightly cm9 targate 29
    Gesendet von meinem GT-I9000
    Galaxy SIII I9300 32gb white
    all stock
  5. #2274
    Senior Droid L'avatar di thcico
    Nexus 4
    Ringraziato 34 volte in 30 Posts
    Quote Originariamente inviato da Evilken95 Visualizza il messaggio
    Ma se ti crei un preferito per il sito dei changelog e uno per il sito del download ottieni lo stesso risultato senza dover installare un'app in più!
    Android: 4.4.2 KitKat
    Rom: Rastakat
    Kernel: Franco Kernel
  6. #2275
    Androidiano VIP L'avatar di punticci
    Vicenza
    LG Nexus 4
    Ringraziato 152 volte in 126 Posts
    Ragazzi non mi va più tapatalk o.O mi dice che non sono loggato ma in verità lo sono.. non vedo nessuna discussione e non posso fare nulla, e tutto questo aggiornando l'ultima release..come mai?ah, esiste un'app per il meteo però che resta nella "tendina" delle notifiche?
    Modello: Nexus 5
    Play Store:https://play.google.com/store/apps/d...=Davide+Dellai
    All In One System: https://play.google.com/store/apps/d...dd.androreboot
    Email: dellai.davide@gmail.com
  7. #2276
    Oneplus One 64gb
    stesso problena io ieri e nin solo con tapatalk. poi mi ė arrivata mail da androidiani che hanno tentato di entrare nel mio profilo. ip era di roma.
    hanno problemi di sicurezza sul sito?
    all stock
  8. #2277
    Vicenza
    LG Nexus 4
    Quote Originariamente inviato da dasnichts Visualizza il messaggio
    AH cavolo..e in sintesi??o.O
    Modello: Nexus 5
  9. #2278
    Oneplus One 64gb
    ho cambiato password e subito di nuovo ok
    all stock
  10. #2279
    Raga io ho la ultima nightly quella del 29
    ma a voi funziona il tethering??
    Appena lo attacco si blocca e si riavvia il telefono
    solutions???
  11. #2280
    Senior Droid L'avatar di Frank_9.5
    Provincia di Caserta
    Ringraziato 271 volte in 193 Posts
    Per vedere i changelog provate su questo sito BBQLog - CyanogenMod Changelog
