Pagina 261 di 696 primaprima ... 161211251259260261262263271311361 ... ultimoultimo
Visualizzazione dei risultati da 2,601 a 2,610 su 6953
[ROM][ICS] TIRAMISLIM Final V. 2.0 [OTA-AROMA-Aroma File Manager-SLIM]
  1. #2601
    Ringraziato 72 volte in 60 Posts
    Quote Originariamente inviato da HalfManHalfBiscuit Visualizza il messaggio
    Ok now i have the ULTIMATE GUIDE if you make shit and your phones breaks/dies FOREVER
    Listen carefully and do what i did once
    DONīT PANIC,if you have Garantie = Garantire on your phone,go to the store you broth your phone and play STUPID
    Ok,this is what you will do my friends WORKS ALMOST ALWAYS 99,9%
    YOU : My phone is broke
    SELLER : Why that kid,what happened?
    YOU : Sir itīs very simple,you sold me some serious poop (If itīs in your character start a bit crying,show a few tears really helps)
    SELLER : Thatīs impossible kid,thatīs a brand new phone
    YOU : Thatīs a brand new SHIT you sold me Mr. and slap with your hand against the table
    SELLER : (Thinks your crazy and youīll scare all the other customers) Kid calm down,itīs just a phone
    YOU : Yeah itīs just a 600$ phone not much more and i WILL not calm down SIR (SAY SIR ITīS VERY IMPORTANT) (Again show a few tears to soften the SELLER heart,that is if he has one (you got nothing to lose here))
    SELLER : (If your lucky heīll think the kid is prepared for the worst,better i give him a new phone or he will shot me down)(Your not intending to do that of course,but he has to think that ) Ok kid i see it was my mistake,youīll get a BRAND new phone
    YOU : Mmmmm are you sure thatīs not going to happen again SIR? (AGAIN SIR VERY IMPORTANT) (Play hard to get satisfied )Ok i see i can TRUST YOU (You of course donīt think that)Thanks for your understanding SIR
    If you have any questions please ask,donīt be scared to ask
    LOOOOOOOOOOOOOOOOOOOOL
    dude i'll try this next time!!
  2. Il seguente Utente ha ringraziato fave86 per il post:
    HalfManHalfBiscuit (20-06-12)
    Ehm..ragazzi...qualcuno di voi ha provato ad installare da Update_Me il pacchetto S Voice?!
    Ho provato, tutto ok all'apparenza. Peccato che quando provo a dargli qualche comando mi dice che il sistema di sintedi di Google non funzia!
    La cosa mi fa strano perchč Vlingo l'ho provato e gira senza problemi.
    Suggerimenti?
    Ciao!
  5. #2603
    Androidiano L'avatar di sidbarret
    Ringraziato 73 volte in 52 Posts
    Quote Originariamente inviato da manuel81
    Suggerimenti?
    Ciao!
    Anche io l'ho provato e non funziona, mi č stato detto che al momento non esistono ancora soluzioni. Ti conviene disinstallarlo e aspettare
    Rom: Paranoid Android 3.99
    Kernel: Franco Kernel r178
    Modem: 0.84
    Mod: Awesome BEATS, Touch Control
  6. #2604
    Androidiano VIP L'avatar di Pietrone94
    Localitā
    Trento
    Samsung Galaxy S3 ; Galaxy S
    Ringraziato 2,012 volte in 1,502 Posts
    Quote Originariamente inviato da ticoti68 Visualizza il messaggio
    hi again
    i read tiramislim final will have multilanguages so i predict it will have portuguese correct? but rom will have portuguese or itīs aroma installer?
    i have the final(because i am one of betatesters) and rom haven't got portuguese...i think aroma is in portuguese
    Quote Originariamente inviato da cr7s Visualizza il messaggio
    ho installato la Tiramislim di DjSound ed ho riscontrato questo bug.
    Ho installato pių di tre versioni Stock da odin, reset a non finire, restore di nandroid, ma nulla.
    In pratica con la rom stock i tasti una volta sfiorati si illuminano ma non fanno nessuna operazione, il tel mi comincia a imballare fino a quando non spengo e riaccendo il display con il tasto power. Mentre con ICS i tasti soft touch non danno nessun segno di vita.
    Ho provato anche mettendo la seguente stringa *#*#2663#*#* dal dialer, mi si riavvia il cell ma nulla.
    Ora chiedo un aiuto a voi prima di prendere la decisione di portarlo in assistenza.
    Grazie in anticipo.
    Quote Originariamente inviato da diegomattia Visualizza il messaggio
    Non credo dipenda dalla rom visto che lo fa anche con quella stock..a questo punto farei un bel format system/cache/datadata/data e full wipe e reinstallerei la rom
    Inviato dal mio GT-I9000 con Tapatalk 2
    oh bentornato cr7s!!!
    quoto diegomattia: prova a fare i wipe e format...se no la soluzione, se vuoi evitare l'assistenza, č mettere la barra del galaxy nexus
    Quote Originariamente inviato da manuel81 Visualizza il messaggio
    Suggerimenti?
    Ciao!
    Quote Originariamente inviato da sidbarret Visualizza il messaggio
    avete la rc1?? xke nella rc1 c'era il bug del sistema di sintesi vocale...nn mi ricordo chi ma qualcuno aveva trovato una soluzione...nella rc2 invece non c'č il bug quindi sarebbe un bug dell' s-voice
    Sent from my GT-I9000 with Tiramislim...yes the new base is Slim
    Se ti sono stato utile, premi il tasto Thanks qui in basso a sinistra. Non costa nulla ed č ben gradito!
  7. I seguenti 2 Utenti hanno ringraziato Pietrone94 per il post:
    amadario93 (16-01-13),cr7s (20-06-12)
  8. #2605
    Io ho la rc2, ma qualche giorno fa dj mi ha detto che s voice č da aggiornare e che al momento non funziona
    Ultima modifica di sidbarret; 20-06-12 alle 11:38
    Modem: 0.84
  9. #2606
    Androidiano VIP L'avatar di DjSound
    Mar 2011
    Ringraziato 2,715 volte in 1,217 Posts
    Ragazzi la final sarā multilanguage non solo in Aroma, ma nell' intero sistema!
    Ho infatti aggiunto tutte le 25-30? lingue mancanti e ovviamente sono opzionali
    Per S-Voice devo aggiornarlo ma ora veramente non ho tempo, certa su xda sono sicuro che lo troverete
    My Tiramislim Gold users: maxysoft, diegomattia
  10. I seguenti 3 Utenti hanno ringraziato DjSound per il post:
    diegomattia (20-06-12),marcoperro74 (20-06-12),ticoti68 (20-06-12)
  11. #2607
    Localitā
    Trento
    ah ok allora sorry
    Quote Originariamente inviato da DjSound Visualizza il messaggio
    ottimo ottimo...ho detto ke nn c'era xk in quella che hai dato a noi nn c'e ma ho ben pensato che potevi insere le lingue successivamente
    s-voice io lo presi dal 3d presente nella sezione galaxy s2 e andava..era impreciso perō andava
  12. I seguenti 3 Utenti hanno ringraziato Pietrone94 per il post:
    amadario93 (16-01-13),marcoperro74 (20-06-12),ticoti68 (20-06-12)
  13. #2608
    Mar 2011
    Quote Originariamente inviato da Pietrone94 Visualizza il messaggio
    ah ok allora sorry
    No no c'č l'hai anche te
    Appena entri č la prima finestra dopo la richiesta del backup dell'efs
  14. I seguenti 3 Utenti hanno ringraziato DjSound per il post:
    diegomattia (20-06-12),marcoperro74 (20-06-12),Pietrone94 (20-06-12)
  15. #2609
    Localitā
    Trento
    ma quello lė nn č di aroma??..io sn andato a vedere in lingua e immissione e li nn č presente
  16. #2610
    Androidiano VIP L'avatar di diegomattia
    samsung galaxy s galaxy s3
    Ringraziato 2,848 volte in 1,796 Posts
    no no e' per le lingue di sistema una volta installato poi puoi anche cambiare lingua da immissione
    Se volete offrirmi un caffč,cosi lavoro ancora di piu (schiavisti) c'e' questo
    SpartaRom - Frankenstein Team
    Il Ritrovo degli Spartani http://www.androidiani.com/forum/off...ml#post3548701
  17. I seguenti 3 Utenti hanno ringraziato diegomattia per il post:
    DjSound (20-06-12),marcoperro74 (20-06-12),Pietrone94 (20-06-12)
