Pagina 259 di 696 primaprima ... 159209249257258259260261269309359 ... ultimoultimo
Visualizzazione dei risultati da 2,581 a 2,590 su 6953
[ROM][ICS] TIRAMISLIM Final V. 2.0 [OTA-AROMA-Aroma File Manager-SLIM]
  1. #2581
    Senior Droid L'avatar di SiMcarD
    Localitā
    Vaprio d'Adda
    Samsung Galaxy S23+
    Ringraziato 98 volte in 84 Posts
    Quote Originariamente inviato da Zinsput Visualizza il messaggio
    il giorno in cui lo farō (tra qualche settimana/mese passerō al SIII oppure al note) spero che anche DJ e Robin facciano la mia scelta.
    Non iniziamo a fargli venire strane idee, eh!
  2. Il seguente Utente ha ringraziato SiMcarD per il post:
    DjSound (19-06-12)
    Senior Droid L'avatar di peppesound
    Localitā
    Salerno
    Ringraziato 354 volte in 267 Posts
    Quote Originariamente inviato da HalfManHalfBiscuit Visualizza il messaggio
    Ok now i have the ULTIMATE GUIDE if you make shit and your phones breaks/dies FOREVER
    Listen carefully and do what i did once
    DONīT PANIC,if you have Garantie = Garantire on your phone,go to the store you broth your phone and play STUPID
    Ok,this is what you will do my friends WORKS ALMOST ALWAYS 99,9%
    YOU : My phone is broke
    SELLER : Why that kid,what happened?
    YOU : Sir itīs very simple,you sold me some serious poop (If itīs in your character start a bit crying,show a few tears really helps)
    SELLER : Thatīs impossible kid,thatīs a brand new phone
    YOU : Thatīs a brand new SHIT you sold me Mr. and slap with your hand against the table
    SELLER : (Thinks your crazy and youīll scare all the other customers) Kid calm down,itīs just a phone
    YOU : Yeah itīs just a 600$ phone not much more and i WILL not calm down SIR (SAY SIR ITīS VERY IMPORTANT) (Again show a few tears to soften the SELLER heart,that is if he has one (you got nothing to lose here))
    SELLER : (If your lucky heīll think the kid is prepared for the worst,better i give him a new phone or he will shot me down)(Your not intending to do that of course,but he has to think that ) Ok kid i see it was my mistake,youīll get a BRAND new phone
    YOU : Mmmmm are you sure thatīs not going to happen again SIR? (AGAIN SIR VERY IMPORTANT) (Play hard to get satisfied )Ok i see i can TRUST YOU (You of course donīt think that)Thanks for your understanding SIR
    If you have any questions please ask,donīt be scared to ask
    True Story..
    Inviato dal mio I-Pho.... ehm... Galaxy S GT-i9000 :-D
    i9300 Marble white
    Kernel: Googy Max Kernel + Settaggi ILLUMINATI
    1° Rom: Imperium Rom 12.3
    2° Rom: Slim Rom 5
  5. #2583
    galaxy s i9000
    Ringraziato 30 volte in 22 Posts
    Quote Originariamente inviato da peppesound Visualizza il messaggio
    True Story..
    why so many work??? for me itīs simples, very simple, you think your phone not good, and is damaged, ok no problem, take battery off, and take a electric cable conect to your car and then touch contacts on your phone , try to on your phone one and twice, ok itīs ready, now put your battery and..... your phone will be dead, so you just need to go to store and say my phone donīt work ok it goes to reparation , (there no reparation ) 2 ou 3 weeks after you will have a new phone it happen with me and my daughterīs phone
  6. #2584
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    Quote Originariamente inviato da Pietrone94 Visualizza il messaggio
    si vai avanti...ci dev'essere la voce tipo "nothing"
    Sent from my GT-I9000 with Tiramislim...yes the new base is Slim
    grazie ora provo !! voglio smanettare per bene con questa rc 2 cosė sono pronto per la final ! a proposito quando verrā approvata dai beta tester ??
  7. #2585
    Androidiano VIP L'avatar di Pietrone94
    Localitā
    Trento
    Samsung Galaxy S3 ; Galaxy S
    Ringraziato 2,012 volte in 1,502 Posts
    Quote Originariamente inviato da Tex99 Visualizza il messaggio
    noi ce l'abbiamo disponibile da 22-23 ore
    posso dire che per ora va benissimo...aspetto Dj se gli serve che proviamo qualcosa...dopo spetta a lui
    p.s. Dj x qualsiasi cosa dimmelo che provo
    Se ti sono stato utile, premi il tasto Thanks qui in basso a sinistra. Non costa nulla ed č ben gradito!
  8. I seguenti 2 Utenti hanno ringraziato Pietrone94 per il post:
    amadario93 (16-01-13),galaxxy (19-06-12)
  9. #2586
    ho provato a mettere la tastiera htc ma non mi ha cambiato nulla ed č rimasta quella ics invertita mentre e animazioni e la boot animation le ha cambiate. qualcuno ha provato ?
  10. #2587
    Localitā
    Trento
    ...da aroma??
    vai in impostazione-->lingua e immissione e da li la selezioni
    oppure qnd scrivi un messaggio, hai la notifica di "seleziona metodo di inserimento" e la scegli da li
  11. I seguenti 2 Utenti hanno ringraziato Pietrone94 per il post:
    amadario93 (16-01-13),Tex99 (19-06-12)
  12. #2588
    Androidiano VIP L'avatar di DjSound
    Mar 2011
    Ringraziato 2,715 volte in 1,217 Posts
    Per ora niente di particolare solo un bug sul multilanguage e sul tema...
    Ma sulle prestazioni come vi sembra? Pm!
    Inviato dalla mia Tiramislim the Only Real Custom Rom
    My Tiramislim Gold users: maxysoft, diegomattia
  13. I seguenti 2 Utenti hanno ringraziato DjSound per il post:
    diegomattia (19-06-12),galaxxy (19-06-12)
  14. #2589
    un problema che sto rilevando con la rc2 č che per chiamare un numero devo provarci almeno 3 volte..succede spesso. le prime due volte neanche squilla e il telefono aggancia subito,alla terza va. mai successo ?? proverō a cambiare modem
  15. #2590
    Senior Droid L'avatar di marcoperro74
    Ringraziato 899 volte in 551 Posts
    Se vai in update me sotto mods c'č il fix da flashare...
    Marco dall'unica e vera custom rom: TiramiSlim!!!
