Pagina 284 di 696 primaprima ... 184234274282283284285286294334384 ... ultimoultimo
Visualizzazione dei risultati da 2,831 a 2,840 su 6953
[ROM][ICS] TIRAMISLIM Final V. 2.0 [OTA-AROMA-Aroma File Manager-SLIM]
  1. #2831
    Androidiano VIP L'avatar di Tex99
    Ringraziato 1,277 volte in 807 Posts
    Quote Originariamente inviato da maxysoft Visualizza il messaggio
    controlla se in updateme il percorso e corretto.
    si fatti numerosi tentativi. sennò passo di odin
    Senior Droid L'avatar di Frank_9.5
    Provincia di Caserta
    Ringraziato 271 volte in 193 Posts
    Quote Originariamente inviato da HalfManHalfBiscuit Visualizza il messaggio
    thanks bro told you.
    Just seen that people use my settings with Devil kernel and don´t get over 3000 score
    I have no idea how it comes that people have thousand problems with new ROM?????
    I´m using it 5-6 days WITHOUT 1 Fc,no lag (forgot what lag is lol),all apps work perfectly.
    IMHO people aren´t making FULL WIPE,come here and say they did it.Come on my Benchscore is 3400-3500 sometimes around 3600 with my settings how come you get 2800 score?????
    Always do FULL WIPE,but it´s up to you,don´t cry later if you sorry FUCK UP your phone,because your lazy to take 2-3 hours and install again.
    Yesterday I got 3380, today 3404! :P but I'm on tsunamics... I'm interested in trying this final release but I want to wait some days to see the real power of these settings anyway, everytime I flash a rom I usually flash a stock rom with odin and then my ics rom... I have no problem wiping the internal sd because I have all data on the external, should I wipe that too? It would take more and more time luckly I don't have any problem with these steps!
    Inviato dal mio GT-I9000 con Tapatalk 2
  4. #2833
    Androidiano VIP L'avatar di maxysoft
    GS, SII, S III, S5 | Nexus 7
    Ringraziato 1,547 volte in 1,008 Posts
    Quote Originariamente inviato da fave86 Visualizza il messaggio
    assolutamente niente! credo sia un problema del phone.apk... ad esempio quando digito il numero subito dopo la vibrazione del tap fa una vibrazione prolungata... ho fatto un wipe data, cache, dalvik e sto reinstallando tutto...
    nn potevi fare un ripristino del /system?
    REIMPOSTATE IL LIMITE DEI CARATTERI A 1000. 500 SONO TROPPO POCHI!
    Regalami 500mb di spazio su DropBox
  5. Il seguente Utente ha ringraziato maxysoft per il post:
    DjSound (22-06-12)
  6. #2834
    Quote Originariamente inviato da Tex99 Visualizza il messaggio
    quale percorso hai scelto?
    deve essere /mnt/sdcard
  7. #2835
    prima così varie volte, poi provando ad aggiungere /tiramisuota/themes ma nulla
  8. #2836
    Ringraziato 72 volte in 60 Posts
    dici dalla sezione di debug? ho provato ma poi NON SO PERCHE' mi ha cancellato tutte le tastiere..
  9. #2837
    c'erto che li cancella. le tastiere vengono installate in /system/app. tu facendo il ripristino cancelli l'intera partizione /system
    allora reinstalla da capo
  10. Il seguente Utente ha ringraziato maxysoft per il post:
    DjSound (22-06-12)
  11. #2838
    Senior Droid L'avatar di marcoperro74
    Ringraziato 899 volte in 551 Posts
    Quote Originariamente inviato da diegomattia Visualizza il messaggio
    lo meriti... sei sempre disponibile a provare e dare una mano agli altri... Grande Marco
    Grazie Diego... troppo gentile...mi fai arrossire... ho dei grandi esempi da seguire... grazie ancora
  12. I seguenti 2 Utenti hanno ringraziato marcoperro74 per il post:
    diegomattia (22-06-12),DjSound (22-06-12)
  13. #2839
    ora pare funzionare... ma ho questa vibrazione parecchio fastidiosa dopo ogni singolo tap.... mai successo...
  14. #2840
    Androidiano VIP L'avatar di diegomattia
    samsung galaxy s galaxy s3
    Ringraziato 2,848 volte in 1,796 Posts
    togli le spunte da impostazioni/audio e anche quella della tastiera in lingua e immissione
    Se volete offrirmi un caffè,cosi lavoro ancora di piu (schiavisti) c'e' questo
    SpartaRom - Frankenstein Team
    Il Ritrovo degli Spartani http://www.androidiani.com/forum/off...ml#post3548701
