Pagina 19 di 37 primaprima ... 9171819202129 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 362
[GUIDA] 3 button combo fix
  1. #181
    Androidiano VIP L'avatar di iaio72
    Jul 2009
    Ringraziato 618 volte in 346 Posts
    Quote Originariamente inviato da regster Visualizza il messaggio
    Bravo! 100%
    Per tutti quelli che hanno controllato e nel file "bml1.dump" si trovano prima della scritta "ofni" la "@" ovvero così
    possono proseguire a secondo di questi requisiti:
    sicura per chi ha froyo con recovery 3e no brand:
    HEIMDALL METHOD:
    01. Unplug the phone from the computer (if connected)
    02. Kill all Kies related software (tray agent, etc)
    03. Start Heimdall Downloader
    04. Plug in the phone to the computer
    05. Download adbDownload.zip
    06. Unpack adbDownload.zip and run/double click on Download.bat
    07. Download RAZ_P-SBL_SGS.tar
    08. Unpack RAZ_P-SBL_SGS.tar
    09. Move to Heimdall (GUI) and select boot.bin and SBL.bin.
    10. Flash the bootloaders
    oppure
    ODIN3 METHOD:
    3. Start Odin3 v1.3 or v1.7 Downloader
    7. Download PSbl_stockJPU.tar.md5
    8. Move to Odin3 v1.3 or v1.7 Downloader and select "PSbl_stockJPU.tar.md5" as PDA file. Make sure "Phone Bootloader Update" is ticked and re-partition is unticked. Do not select any other files but "PSbl_stockJPU.tar.md5".
    9. Press "Start" button to launch the update process. It will take around three seconds to complete. After the update phone will reboot automatically.
    Sicura Per chi ha eclair con recovery 2e No brand puo eseguire questa:
    Step 1: Download RAZ-FiX-SGS.zip
    Step 1.1: Place the file to the root of the INTERNAL phone's memory and rename it to: Update.zip
    Step 1.2: Make sure USB debugging is enabled (Settings->Applications->Development->USB Debugging)
    Step 1.3: Connect the Phone to the PC
    Step 2: Download adbRecovery.zip
    Step 2.1: Unpack adbRecovery.zip
    Step 2.2: Run Recovery.bat
    Step 3: Select on the phone's menu: apply sdcard; update.zip and press the Home button.
    Ricordate di ringraziare l'autore "RazvanG" se volete anche con donazioni a vostro buon cuore.
    La guida originale la potete trovare QUI
    Chiedo ai moderatori di postare le guide più aggiornate come quelle riportata qui sopra in PRIMA pagina!
    Vi voglio bene e non mi permetterei di offendere nessuno ma permettetemi questa critica!
    Si crea una confusione madornale se non si aggiornano le guide con quelle nuove e non si postano nella prima pagina di fatti alcune guide/passaggi si trovano nei meandri del thread.
    Una povera persona è costretta a volte a leggersi 70 pagine per fare un'operazione semplice!
    Be è certo che non posso trovare e leggere tutti i molteplici post in tutte le sezioni samsung!
    Aggiornata guida grazie per la segnalazione!
    ps la prox volta basta un semplice mp per avvisarmi!
    OnePlus 3T
    Meizu Mx6
    Baby Droid L'avatar di matteo666
    Frosinone
    Galaxy Nexus, Samsung Galaxy S
    5) Aprite il prompt dei comandi(dal pc) e digitate il seguente comando: adb reboot recovery, questo passaggio non va xchè il prompt mi dice adb command not exist
    Galaxy Nexus - ROM: CM 10.1 RC5
    Galaxy S GT-I9000 - ROM: CM 10.1 RC5
  4. #183
    Quote Originariamente inviato da matteo666 Visualizza il messaggio
    In che situazione sei ? se devi sbloccare la combo dei tre tasti ti consiglio di non seguire la guida di questo post (incomprensibile) ma quella con odin del post su xda...
  5. #184
    Jul 2010
    Scusate ragazzi mi servirebbe una info...
    Voglio rotare il cell ho provato a scrivere root galaxy s nel form ma escono solo discussioni di problemi per fare il root non una guida pratica. Sen non chiedo troppo vorrei un link per il root ed uno per il unroot.
    Poi un'altra cosa che significa recovery 3e e recovery 2e come lo capisco quale ho io?
    Anticipatamente grazie
  6. #185
    Jul 2010
    Nel caso dovesse servire a qualcuno ho risolto con questa guida facile indolore ed è possibile unrotare con la stessa facilità
    [APP]SuperOneClick v1.5.5 (Root, Unroot, Enable Non-Market App, Get UNLOCK code) - xda-developers
  7. #186
    fatto seguendo la procedura con odin!...ci mette davvero tre secondi e funzia!!!
    Ciao
  8. #187
    Nov 2009
    Allora devi seguire la guida flashando da pc con Heimdal oppure come ho fatto io che ero nelle tue stesse condizioni, con odin 1,7 seguile alla lettera accertati quando attacchi il cell che ti venga riconosciuto dal pc, lo puoi controllare dalla gestione risorse di windows.
    Ora e sicuro anche con odin visto che e stato aggiornato il pacchetto da installare, prima era un normale .zip adesso e un .tar.md5 (molto piu sicuro)
    Tempo 10 secondi e hai il tel con i 3 tasti!
    Sent from my GT-I9000 using Tapatalk
    ho seguito la guida alla lettera ma mi sono ritrovato con questa schermata
    e adesso mi ritrovo con il cel briccato (solita schermata cel-pc con triangolo in mezzo).
    cosa posso fare adesso?
    un aiuto.......
  9. #188
    Quote Originariamente inviato da joker123 Visualizza il messaggio
    mi daresti il link ? Grazie.
  10. #189
    Jul 2010
    Ragazzi ho eseguito la guida con odin 1.7 e quando premo su start windows mi va in errore con la solita finestra "si è verificato un errore" in realtà nn ho prestato molta attenzione al nome dell'errore. Ma per fortuna è andata cosi perchè potevo rischiare di briccare il cell. In quantio eseguendo il dump di BML1 mi ha dato come risultato e-fused. Penso di averla scampata .
    Ora mi chiedo per me e tutti quelli come me che hanno BML1 e-fused, si possono scordare di abilitare la combo dei tre bottoni?
    Ultima modifica di carlitos081; 22-12-10 alle 10:30
  11. #190
    Jul 2010
    @Zasso
    Ciao io vengo da htc quindi mai avuto problemi ad andare in recovery mod. Però leggendo tutto il forum mi pare di aver capito che hai 2 possibilità:
    1) andare in assistenza e provare.
    2)fare come ha fatto qualcuno nel forum cioè è riuscito ad andare in recovery mod tramire usb+ resistenze(c'è anche un videotutorial) e da li puoi installare una rom fresca fresca
    anche se a pensarci in realtà hai fleshato il bootloader e non la rom in questo caso, quindi nn saprei.
    Spero di esserti stato d'aiuto.
    Ultima modifica di carlitos081; 22-12-10 alle 10:31
