Pagina 224 di 242 primaprima ... 124174214222223224225226234 ... ultimoultimo
Visualizzazione dei risultati da 2,231 a 2,240 su 2417
[ROM] - UltimaROM - Sammy based [AROMA]
  1. #2231
    Senior Droid L'avatar di morgan7676
    Letv x600/Leeco 3pro/ONP 3
    Ringraziato 187 volte in 149 Posts
    manco a dirlo e...
    nuova verisione :
    UltimaROM - v16.0 Typhoon
    Rebased to Android 4.3
    Removed Samsung bloat
    Included xposed and GravityBox as default, since it has ALL the mods we used to have (except some colour stuff, which I will work on, if necessary. Though I don't want to make the ROM a colouring book).
    Added AOSP Lockscreen
    Added Ripple Lockscreen with Ink
    Added Watercolour Lockscreen
    Added Lense Flare Lockscreen
    Added Transparent Statusbar setting in UltimaROM Settings
    Added FULLY stock Google SystemUI
    Added AOSP and Samsung Contacts + Phone
    Added AOSP and Samsung Messaging
    Added Blocking Mode notification removal
    Added Call recording options (Samsung Phone and Contacts ONLY)
    Added Zero Wake Lag mod
    Added another theme to the UltimaROM settings - Holo Light Dark ActionBar - just for fun
    Added Wifi Band Switcher
    Added USB Mass Storage Enabler
    Added AdAway
    Added Chronus
    Added FasterGPS
    Added ES File Explorer
    Themed Settings
    Themed Framework-res
    Themed Gallery and Camera AOSP style
    Included Google Gallery and Camera - Flash working properly on camera, no more FC.
    Included Google 4.3 Launcher
    Removed S-Voice - Doesn't cause odd home button behaviour
    Senior Droid L'avatar di lukas78
    Mar 2011
    Samsung Galaxy S3, S4, S5
    Ringraziato 19 volte in 13 Posts
    No.. Non è possibile!
    Dici che ci hanno sentito?
    Comunque vedo non è basata ancora sulla kitkat...
    editato....
    Ultima modifica di dieguccio; 02-01-14 alle 13:35
  4. #2233
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da lukas78 Visualizza il messaggio
    Sapete per caso se si può estrapolare l app fotocamera e messaggi per tenerla sulla CyanogenMod?
    siete off topic
  5. #2234
    Mar 2011
    Colpa mia... Chiedo scusa...
  6. #2235
    Androidiano VIP L'avatar di skorpion83
    Caserta
    HTC One E8
    Ringraziato 4,891 volte in 2,484 Posts
    Oh, ma allora ce l'abbiamo anche noi il thread di questa rom
    Rom tra le più seguite su xda e posso anche capire il perchè...è davvero splendida!!!
    Messa ieri, è molto simile alla blackBox per grafica ma ha tante tante cose in più.
    Da amante delle grafica aosp, grazie a questa rom mi è stato meno traumatico tornare su un firmware samsung.
    La rom è molto leggera, ha tutto, ma proprio tutto delle rom aosp (grazie al modulo gravity box integrato nella rom...).
    E soprattutto, si comporta esattamente come una aosp/aokp dal punto di vista della leggerezza e della velocità. Ram libera sempre sui 200mb (usando greenify), fluidità sempre al top (superiore a tutte le rom sammy provate finora) e consumi degni di una rom samsung, di sicuro inferiori alle aosp. In più, essendo basata sull'ultimo firmware ml2, ha la fotocamera stock (che fa foto sempre belle...) e tutti i driver samsung (audio e video fantastici...).
    Sono riuscito ad impostare la barra di navigazione proprio come l'avevo sulla slim bean (aosp 4.3.1) con la pressione lunga posso avere funzioni (come bloccare lo schermo...) avanzate e soprattutto posso configurarla e colorarla come più mi piace. E ovviamente rendere sia la status bar che la barra, trasparenti come su kitkat 4.4 e oltretutto, grazie al modulo xposed Floating Window, sono riuscito a configurare i toggle e le notifiche con le "finestrelle", proprio come HALO!!!!
    Solo una cosa non è nativa della rom, il multiwindows esteso a tutte le app. Ho risolto installando quest'app (davvero fenomenale) : https://play.google.com/store/apps/d...jbinc.mwmphone
    Avevo sentito parlare di questa rom tantissimo e ne sono rimasto davvero sorpreso, è ottima, è bella e funziona alla grande.
    Lo sviluppatore però rilascia le rom con cadenza moooooolto lenta
    Questa che monto ora è uscita il primo gennaio 2014 ed è la v16.
    Leggendo su xda, ho scoperto che la v15 è addirittura su base 4.1.2 ed è uscita molto molto tempo fa!!!
    Dunque, aggiornamenti brevi difficilmente se ne avranno, ma ciò significa che l'ultima versione funziona talmente bene che non necessita di correzione di bug, perchè non ce ne sono...
    Straconsigliata a tutti...
  7. I seguenti 2 Utenti hanno ringraziato skorpion83 per il post:
    ClaudìoS3 (08-01-14),riccardi (09-01-14)
  8. #2236
    Androidiano VIP L'avatar di ClaudìoS3
    Profondo SUD
    GACE, Ascend P1, GS3, ZUK Z1
    Ringraziato 280 volte in 191 Posts
    Quote Originariamente inviato da skorpion83 Visualizza il messaggio
    L'avevo messo anche io ma pensavo che qui il thread non esistesse!
    La consiglio anche io è fantastica... inoltre le release che vengono rilasciate non subito mi fa pensare che il lavoro è tanto
    Ah comunque ho letto sul sito che a breve sarà rilasciata la 16.1 con alcuni fix
    Ultima modifica di ClaudìoS3; 09-01-14 alle 16:43
    Se ti sono stato utile, clicca il tasto "THANKS" a sinistra
    LENOVO ZUK Z1
    ROM: Cyanogen OS 12.1 Android: 5.1.1 Lollipop
    EX Nick: GalaxyAceICS; ClaudìoP1
    Tutto è possibile, l'impossibile richiede soltanto più tempo.
  9. Il seguente Utente ha ringraziato ClaudìoS3 per il post:
    skorpion83 (08-01-14)
  10. #2237
    Androidiano L'avatar di ryuxxx
    Ho sempre montato questa rom...ed è la migliore in assoluto!Quest'ultima ha bisogno di alcuni fix...A me ad esempio non funziona la videochiamata e ci sono molte meno personalizzazioni con Aroma Installer... Speriamo che con la 16.1 ci sia un miglioramento...
  11. #2238
    Senior Droid L'avatar di StevenRed
    Borgo Valsugana
    Samsung Galaxy Note 8
    Da come la descrivete è addirittura meglio della CyanogenMod... Devo provare assolutamente
  12. #2239
    Borgo Valsugana
    Sono in bootloop, cosa devo fare?
  13. #2240
    Androidiano VIP L'avatar di lucacerio
    LG Nexus 5
    Ringraziato 257 volte in 227 Posts
    Quote Originariamente inviato da StevenRed Visualizza il messaggio
    Recovery, wipe data e riavvia
    Pigia il tasto thanks se ti sono stato utile..non da dipendenza tranquillo
    "The only limit is the one you set yourself"
