Pagina 64 di 107 primaprima ... 1454626364656674 ... ultimoultimo
Visualizzazione dei risultati da 631 a 640 su 1067
[KERNEL] Stable: Boeffla-Kernel 2.x ONLY JB 4.1.x
  1. #631
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    Quote Originariamente inviato da PierrePisa Visualizza il messaggio
    si si c'ero gia arrivato non è complicato
    Esatto! Se hai dubbi chiedi pure
    Un Grazie è sempre ben accetto
    Vault 105
    OnePlus 5
    Ecco qui
    2.12 Stable
    Upstreamed to Linux 3.0.83 (www.kernel.org)
    * zRam configurable
    * Touch-to-wake
    * zzmoove governor 0.5.1b contained
    * WIFI driver back ported from i9505 (Galaxy S4)
    * Multicast filter for better battery life
    * Special handling of Boeffla-Sound with certain custom roms (i.e. Omega rom) for better compatibility
    * Soft CPU overclocking to 1500 or 1600 MHz
    * Governor profiles for pegasusq and zzmoove for performance, battery saving etc.
    * GPU frequencies configurable (underclocking, overclocking up to 700 MHz)
    * GPU voltages configurable (undervolting, overvolting)
    * Boeffla-Tweaks app to configure most important kernel features via easy user interface (latest features: load predefined profiles, save&restore your own settings)
    * Configuration file for easy configuration of kernel without additional apps for many options
    * Compatibility to common standard apps (Voltage Control, SetCPU, System tuner etc.)
    * Boeffla-Sound engine V1.6.0 to unleash the power of the Galaxy S3 audio chip (latest new functionalities: speaker tuning, intelligent microphone sensitivity setting for both recording and call, call-detection, stereo expansion, mono downmix)
    * Full configuration of Boeffla-Sound engine via Boeffla-Sound app from Google playstore possible
    * Custom equalizer support via configuration file possible
    * LED fading can be enabled (for a demonstration video CLICK HERE - thanks to Andreas61 for recording the video) - Note: It does only work for non-Samsung apps (does not work for missed calls, stock sms etc!)
    * Increase brightness of notification LED for both blinking or fading
    * Exynos vulnerability fixed
    * Sudden death issue supposed to be fixed
    * Custom boot animation support
    * CRT-OFF animation supported
    * CPU undervolting interface
    * Adjustable charger rate, defaults increased to 1100 mA for ac (usb stays on 475 mA per default) - you can now set USB charge down to zero, so it does not load when you plug it into your PC to just transfer files etc.
    * Hardcore speedmod sharpness fix implemented (default is off, you have to enable it in the config file)
    * Touch boost switchable (default is on)
    * Black crush fix for better balanced display
    * SD card read ahead buffer configurable separate for internal and external SD memory (default is 256 kB)
    * Ext4 File system tweaks (can be disabled)
    * System Tweaks (default is off)
    * Schedulers configurable separate for internal and external SD memory
    * SIO scheduler (with slight tweaks)
    * ROW scheduler (latest version)
    * BFQ scheduler (version v5r1)
    * ZZmoove 0.3 governor (focus on battery performance)
    * LulzactiveQ governor included (tweaked)
    * Dynamic fsync 1.2 implemented
    * Timeouts for external SD card changed to improve handling of crappy cards
    * Proportional rate reduction TCP implemented
    * Entropy generator for random data fixed
    * Car dock support
    * Swap support
    * XBox controller support
    * Wifi mac address change support
    * init.d support (automatic folder creation and permissions setting)
    * CIFS compiled as a module (load module from /lib/modues if required)
    * NFS compiled as a module (load module from /lib/modues if required)
    * Auto Root (disabled by default)
    * exFat support switchable (switch it off if you do not need it)
    * Triangle away supported
    * Automatic EFS backup to external (priority) or internal SD Card (fallback)
    * Kernel initialisation log file (with history of 3 log files)
    * Disabled Android logger (can be enabled again)
    * Disabled Kernel logging (can be enabled again)
    * Disabled various debug logs and traces
    * Battery monitor wakelocks reduced
    * Compiled with Google arm 4.7 toolchain
    * Internal kernel busybox version 1.20.2
    * Ramdisk from XXEMR2 firmware
    * Source code base is GT-I9300_JB_Opensource_Update10
  4. I seguenti 2 Utenti hanno ringraziato BlackJack89 per il post:
    andredroido (27-06-13),Locaa92 (27-06-13)
  5. #633
    Androidiano VIP L'avatar di andredroido
    Busto Arsizio
    xiaomi redmi 3 pro / MI NOTE 3
    Ringraziato 184 volte in 176 Posts
    Che famo ?? Flasho subito ??
  6. #634
    Vault 105
    OnePlus 5
    Quote Originariamente inviato da andredroido Visualizza il messaggio
    Subbbbbito!
  7. #635
    Androidiano VIP L'avatar di Locaa92
    Torino
    Galaxy SIII
    Ringraziato 236 volte in 213 Posts
    In testing
    Immagini allegate
  8. #636
    Busto Arsizio
    Quote Originariamente inviato da Locaa92 Visualizza il messaggio
    In testing
    testing 2 fatemi mangiare almeno
    c'è qualcosa di nuovo ?? (per studiarmi il changelog ci metto 2 giorni)
    Ultima modifica di andredroido; 27-06-13 alle 22:09
  9. #637
    Torino
    Galaxy SIII
    Tutto quello che c'era nell'ultima beta con l'upgrade dei governor scheduler ecc.. Hanno perfezionato il boeffla sound engine e basta credo...
  10. Il seguente Utente ha ringraziato Locaa92 per il post:
  11. #638
    Vault 105
    OnePlus 5
    Ormai più di così non so cosa si possa fare...
  12. #639
    Androidiano VIP L'avatar di reS28raM
    Samsung Galaxy S3 / LG Nexus 5
    Ringraziato 583 volte in 476 Posts
    Bé, il porting dei driver wi-fi dell' S4 io lo trovo molto interessante! Mi piacerebbe poterlo provare, uso il wi-fi 2-4 ore al giorno lol. Poi il zzmoove... Ho montato una rom da poco e ora non posso, devo ancora capire se il mio cell adesso funziona meglio lol, ma questa versione mi intriga, spero di potere provarla presto. Poi voglio confrontare il suono con quello del Perseus perché sulle modifiche di Andrei non ci ho capito molto.
    A parte che ha corretto un bug sul microfono che credo ci sia anche nel Perseus solo che Andrei si è sempre rifiutato di lavorarci perché poco diffuso e difficilmente riproducibile...
    Ultima modifica di reS28raM; 27-06-13 alle 23:56
    If Linux Is Not Unix Then Windows Are Not Gates
    Anonymous, XX Century
  13. #640
    Torino
    Galaxy SIII
    Quote Originariamente inviato da superpippo57 Visualizza il messaggio
    Prova questo kernel e non tornerai più indietro
