Pagina 30 di 44 primaprima ... 20282930313240 ... ultimoultimo
Visualizzazione dei risultati da 291 a 300 su 439
[ROM] NeatRomLite [ XXUGNE1 4.3] [XXEMJ2 4.1.2] Themed/Aroma/Full/Mods[I9300]
  1. #291
    Senior Droid L'avatar di Giandrox
    Ringraziato 128 volte in 104 Posts
    Versione 7.2 online
    Senior Droid L'avatar di giovag7
    Ringraziato 114 volte in 103 Posts
    non era 7 punto 1
  4. #293
    Quote Originariamente inviato da giovag7 Visualizza il messaggio
    non era 7 punto 1
    Evidentemente no.
  5. #294
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    NeatROM for Samsung Galaxy S3 I9300
    March 15, 2014
    Firmware: I9300XXUGNB6 NeatROM v7.2 Aroma (4.3)
    Build date: Tue Feb 25 15:30:51 KST 2014
    Kernel: Stock XXUGNB6 Repacked
    Modem: XXUGNA8
    CSC: OJVGNB3-Multi
    Change List: 2454463
    Available languages in Rom: Armenian, Azerbaijani, Bahasa, Catala, Cestina, Dansk, Deutsch, Eesti, English, Espanol, Estonian, Euskara, Francais, Galego, Hrvatski, Icelandic, Irish, Italiano, Kazakh, Latviesu, Lao, Lietuviu, Macedonian, Magyar, Myanmar, Nederlands, Norsk bokmal, Polski, Portugues, Romana, Slovencina, Slovenscina, Suomi, Svenska, Tieng Viet, Turkce, Udru, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Serbian, Korean, Chinese...
    Fully Deodexed
    Zipaligned
    Rooted
    BusyBox
    SuperSU v1.93
    NO WIPE
    Disabled Boot Sounds
    Init.d Support
    Init.d Tweaks
    Build.prop Tweaks
    Tweaked
    Improved Virtual Memory
    Kernel Debugging - Disabled
    sysro/sysrw
    Default Language - English
    No Auto Converting messages to MMS
    Unlimited Contacts to SMS,MMS
    No SMS,MMS in Call Log
    Enabled Camera Sound Menu
    OpenVPN
    Enabled All Languages for Samsung Keyboard
    Enabled More Contacts (990)
    Large Apn List
    4 Way Reboot Menu
    Enabled Secondary Symbols on Stock Keyboard
    HD Voice Thanks to @tarzan11
    Call Recording
    Modded Mms (Sent Time instead of Received Time)
    Enabled Hidden Torch Settings
    S4 WallPapers
    MultiWindow for all Apps
    Flare Effect Thanks to @Arsaw
    New update script from AOSP Neat
    v7.0 cooked through JustArchi's awesome kitchen Thanks to @JustArchi
    Rebuilded all permissions
    Deodexed using latest smali/baksmali
    Zipaligned using latest SDK
    New updater-script
    New Aroma installer
    Fixed SystemUI
    Fixed S Cloud
    Added NeatROM Logo Thanks to @Spannaa
    Added more Languages for Samsung Keyboard
    Added Custom Settings in Settings Thanks to @ficeto, @Goldie and @MyLifeRocks10
    Added option to set Battery Icon:
    - Stock
    - Text only
    - Stock Icon with Text
    - Stock Icon with Center Text
    - Castaway
    - Circle
    - Clock Battery
    - CM Battery
    - Dotted Circle
    - Xor Circle
    - Hide Battery Icon
    - BOX Battery Thanks to @MyLifeRocks10
    - Alternate Circle Thanks to @MyLifeRocks10
    - KitKat Thanks to @tarzan11
    Added option to set Battery Icon Color (Color Picker)
    Added option to set Battery Percentage Text Color (Color Picker)
    Added option to set Circle/Dotted Battery Animation Speed:
    - Slow
    - Stock
    - Fast
    - Stop
    Added option to set Battery Bar
    Added option to set Battery Bar Color (Color Picker)
    Added option to set Battery Bar Style:
    - Regular
    - Center
    Added option to set Battery Bar Thickness:
    - 1dp
    - 2dp
    - 3dp
    - 4dp
    Added option to Enable/Disable Battery Bar Charging Animation
    Added option to Enable/Disable Full Battery Notification in Status Bar
    Added option to Enable/Disable Low Battery Notification in Status Bar
    Added option to set Clock Position:
    - Left Clock
    - Center Clock
    - Right Clock
    - Hide Clock
    Added option to set AM/PM Style:
    - Small
    - Normal
    - Hide
    Added option to set Date Style:
    - Small
    - Normal
    - Hide
    - Lowercase
    - Uppercase
    Added option to set Date Format
    Added option to set Date Color (Color Picker)
    Added option to set Notification Panel Color (Color Picker)
    Added option to Enable/Disable Traffic Meter
    Added option to set Traffic Meter Color (Color Picker)
    Added option to Enable/Disable Lock Button (Notification Header)
    Added option to Enable/Disable Notification Count in Status Bar
    Added option to set Screen Off Animations:
    - CRT
    - Fade
    - Stock
    Added option to Enable/Disable Long Press Menu to Kill
    Added option to Enable/Disable Skip Music
    Added option to set Music Controls (Time out, Volume Up, Volume Down Action)
    Added option to select LockScreen Mod:
    - AOSP Lockscreen
    - Water effect
    - Ripple effect
    - Light effect
    Added option to Enable/Disable Ink Effect
    Added option to set Ink Effect Color (Color Picker)
    Added option to Enable/Disable Quick Pin/Password Unlock
    Added option to Enable/Disable Lockscreen Camera Widget
    Added Note3 Keyboard
    Enabled Secondary Symbols on Note3 Keyboard
    Added option to Enable/Disable One-Hand Operation (Calculator, Note3 keyboard and Pattern Lockscreen)
    Added Note3 Browser Thanks to @Strumpf
    Added Note3 Calculator Thanks to @Strumpf
    Added Note3 Widget Active Apps
    Added Note3 My Files Thanks to @pes1x
    Added Note3 Video Player Thanks to @Strumpf
    Added Smart Stay
    Added Smart Pause
    Added Smart Scroll (Note3 Browser) Thanks to @Strumpf
    Disabled Phone Number Formatting
    Enabled Signature in Messaging
    Enabled Directory Search in My Files
    Disabled Verify Apps By Default
    Allowed Installation Of Apps From Unknown Sources By Default
    Modded Camera (Removed Camera Battery Warnings)
    Enabled Automatically Send/Receive MMS Thanks to @ICavalera
    Enabled Assistive Light Widget
    Enabled Mono/Stereo Widget
    Updated Greenify
    Updated NeatEFS
    Updated Wanam Xposed[/COLOR]
    Added Gravity Box
    New Neat Wallpaper Thanks to @Rosario34
    www.NeatROM.com as default home page for Browser
    More Optimized
    Better RAM
    Faster Boot UP Time
    New Tweaks
    Other minor changes and fixes
    Added Option to Install:
    - Extra Lite ROM + Bloatware
    - Lite ROM + Bloatware
    - Full ROM
    Enable/Disable NeatROM Bootanimation Thanks to @momo.martinovic
    - v1
    - v2
    - v3
    - v4
    Recovery:
    - Philz Touch Recovery v6.07.9
    - Philz Touch Recovery v6.19.3
    Apps:
    - CWM Manager app
    - Fast Dormancy Toggle
    - Greenify
    - CPU Control Lite
    - DropBox
    - Xposed Framework
    - Xposed Apps (App Settings, Gravity Box, Wanam)
    - NeatEfs Thanks to @bender_007
    - NeatUpdate (All the Apps/Mods/Themes in one place) Thanks to @acquariusoft
    Available Mods:
    - Note 3 Keyboard
    - Google Gallery
    - Google Gallery
    - S4 Launcher, 100% Transparent AccuWeather
    - S3 Launcher (4x5, 5x5, 5x6, 4x6...)
    - Note III Launcher (4x5, 5x5)
    - Google AOSP Launcher
    - Google Experience Launcher
    - Note II Popup Browser
    - Nexus 5 Tones Thanks to @tarzan11
    Choose the Apps you want to Install:
    - Accuweather Widget
    - Digital Clock Widget
    - Dual Clock Analog Widget
    - Dual Clock Digital Widget
    - S Planner Widget
    - Favorite App Widget
    - Favorites Widget
    - Google Search Widget
    - Simple Alarm Clock Widget
    - Web Manual Widget
    - Adapt Sound Widget
    - ChatON
    - Sansung Fonts
    - Group Play
    - Kies
    - Live Wallpapers
    - S Memo
    - Mobile Print
    - Music Live Share
    - Music Player
    - Paper Artist
    - Polaris Viewer
    - Samsung Apps
    - Samsung Hubs
    - S Cloud
    - Samsung All Share
    - S Sugest
    - S Voice
    - Talkback
    - Samsung Update
    - Video Player
    - Voice Recorder
    - Yahoo
    - Facebook
    - AccuWeather
    - AllShare
    - Samsung Direct
    - Email/Exchange
    - FWUpgrade
    - Gallery
    - Gear Manager
    - Keystring
    - FM Radio
    - Remote Control
    - Stock Browser
    - Samsung Service
    - NFC
    - Language Files
    - Gmail
    - Chrome
    - Hangouts
    - Magazines
    - Maps
    - Play Music
    - Play Games
    - Google Plus
    - Google Search
    - YouTube
    - Picasa Uploader
    - Play News Stand
    - Page Buddy
    - Samsung Push
    and many more...
    I probably forgot something
    BIG THANKS TO @MyLifeRocks10
    http://click.xda-developers.com/api/...20v7.2%20Aroma
  6. Il seguente Utente ha ringraziato dieguccio per il post:
    Michaelsdj (15-03-14)
  7. #295
    Bologna
    Galaxy SIII
    Ringraziato 19 volte in 13 Posts
    Sono passato dal firmware stock alla NeatRom (7.0-7.1 e da ieri 7.2).
    Ottima ROM non c'è che dire, la batteria adesso mi dura un giorno intero anche senza l'opzione risparmio energetico attivo.
    L'unica cosa è che ho sempre 700Mb di RAM costantemente occupati (circa 100 app installate).
    Posso diminuirlo?
  8. #296
    Quote Originariamente inviato da geneo85 Visualizza il messaggio
    Posso diminuirlo?
    Lascia stare, è la gestione automatica della ram di android e va bene così.
  9. #297
    Androidiano VIP L'avatar di ClaudìoS3
    Profondo SUD
    GACE, Ascend P1, GS3, ZUK Z1
    Ringraziato 280 volte in 191 Posts
    Posso diminuirlo?
    Scarica Greenify dal play store e iberna tutte le app inutili che non ti servono.. in più puoi scaricare clean master che con un tap nel widget permette di liberare la ram
    Se ti sono stato utile, clicca il tasto "THANKS" a sinistra
    LENOVO ZUK Z1
    ROM: Cyanogen OS 12.1 Android: 5.1.1 Lollipop
    EX Nick: GalaxyAceICS; ClaudìoP1
    Tutto è possibile, l'impossibile richiede soltanto più tempo.
  10. #298
    T19
    T19 non è in linea
    Ringraziato 14 volte in 9 Posts
    scusate gente io sono passato dalla 6.5 alla 7.3 stamane
    mi da sempre errore ui di sistema si è arrestato tipo ogni 3 secondi rendendo il cell inutilizzabile
    premetto che ho fatto tuti i wipe del caso.
    da cosa potrebbe dipendere
    come recovery uso la TWRP 2.7
  11. #299
    7.3? Hai installato la rom giusta? Io sono passato dalla 6.5 alla 7.0 senza problemi
  12. #300
    T19
    T19 non è in linea
    sorry..
    volevo dire la 7.2
    come dicevo ui di sistema che s'interrompe. mi succedeva anche con la 7.0
    puo' dipendere dal tipo di recovery?
