Utente del giorno: ciccariell con ben 1 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: 9mm con ben 5 Thanks ricevuti negli ultimi sette giorni
Pagina 7 di 17 primaprima ... 56789 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 161
[ROM][G920/5.1.1] XtreStoLite Deo-Mod Edition [490MB]
  1. #61
    Androidiano VIP L'avatar di adonis
    Nov 2009
    Samsung Galaxy S6 Flat
    Ringraziato 224 volte in 141 Posts
    Quote Originariamente inviato da Donatod87 Visualizza il messaggio
    Ragazzi segnalo la versione v.2.4
    Thread Aggiornato in prima pag:
    Deodexed Mod Edition V.2.4 Final:
    - Updated ROM to firmware bases XXU3COI9
    - Updated UniKernel to v.9-Test5
    - Fixed the Swiftkey (and other apps too!) reloading problem (apps no longer get killed in the background!)
    - Updated T/W8 in-call audio fix to the latest version from -Mr. X-
    - Added Samsung My Files (file manager) application at default in the ROM now (to fix the Download manager FC)
    - Fixed the new Stagefright bug (all stagefright leaks are now fixed!)
    - Re-named Medium kernel profile to Stock, and the new Medium profile has now different settings
    - Fixed VM tweaks (now gets applied properly in unikernel.prop file)
    - Disabled Samsung Keyboard 'auto correction' option at default (you can turn it on again under Samsung keyboard settings)
    - Integrated Netflix fix (model number is now SM-G925K as default to fix Netflix streaming)
    - Updated SuperSU to BETA 2.52
    - Updated Google Play Services to v.8.1.18
    - Updated Google Play Store to v.5.9.12
    - Updated Google WebView to v.46.0.2490.64
    - Misc. fixes & optimizations
    - Done the deodexing process and mods with the latest tools!
  2. I seguenti 3 Utenti hanno ringraziato adonis per il post:
    Donatod87 (12-10-15),simoboy89 (12-10-15),Wolf230 (11-10-15)
    Androidiano VIP L'avatar di ingwye
    Aug 2013
    Napoli
    Mate 10 Pro
    Ringraziato 185 volte in 172 Posts
    Da provare
  5. #63
    Androidiano VIP L'avatar di erghetto
    Napoli
    Galaxy S6 Flat SM-G920F
    Ringraziato 385 volte in 344 Posts
    Si può usare con bootloader engineering?
    O bisogna aggiornare per forza la base?
    [Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
    [ROM] Noble Nougat Experience 4.5
    [kernel] Kiboi kernel 2.5
  6. #64
    Senior Droid L'avatar di Wolf230
    Sep 2009
    Galaxy S8
    Ringraziato 137 volte in 113 Posts
    Quote Originariamente inviato da erghetto Visualizza il messaggio
    Cito perchè non ho ancora avuto modo, ma su Xda c'è chi ha installato la 2.4 sull' Eng. bootloader e funziona tutto.
    Se le mie risposte hanno risolto un tuo problema.....perchè non premere "GRAZIE"...
    Ex Devices: Samsung galaxy i7500 / Htc Legend / Lg P990 (...sì il Dual) / Nexus S / Xiaomi M1S / Galaxy S3 / Nexus 4 / Nexus 5 / Z1 Compact / Galaxy S6
    Now with:
    Galaxy S8
    Free 500 mb on Dropbox: Quì
  7. Il seguente Utente ha ringraziato Wolf230 per il post:
    erghetto (12-10-15)
  8. #65
    Aug 2013
    Napoli
    Mate 10 Pro
    Stasera la flasho da sopra e vi faccio sapere
  9. #66
    Androidiano L'avatar di uninc76
    Da come ho capito bisogna aggiornare prima il bootloader
  10. #67
    Campobasso
    Samsung Galaxy S6 flat
    Ringraziato 149 volte in 131 Posts
    Di solito su tutte le rom dicono di installare l'ultimo bootloader
    Inviato dal mio Super S6 super moddato!!!
    Se ti sono stato d'aiuto premi il tasto thanks.
  11. #68
    palermo
    Samsung Galaxy S3
    Io ho installato la 2.4 sulla 2.3. Installando l add on 2.4 mi va il telefono in bootloop. Ho installato la 2.4 con add on 2.3 e va perfettamente
  12. #69
    Quote Originariamente inviato da daron96 Visualizza il messaggio
    anche a me va in bootloop con l add on 2.4...con il 2.3 ti funziona?
  13. #70
    Napoli
    Su xda mi pare che abbiano trovato il problema. Lo scrolling cache dell'addon 2.4 manda in bootloop il cell
