Pagina 59 di 112 primaprima ... 949575859606169109 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 1119
[ALL-BL] Root & Recovery Firmware 6.1.1.B.1.54 / C.1.0 / .89 / .100
  1. #581
    Dopo aver installato kernel .10 il telefono si è spento per sempre
    Ciao a tutti, questa sera non posso altro che essere triste: dopo aver installato il firmware generico ST25i_.54_Nordic_DevStaff e il kernel .10 il telefono mi è morto. non parte più in nessun modo.
    il log che flashtool mi da è questo:
    7/006/2013 03:06:23 - INFO - <- This level is successfully initialized
    27/006/2013 03:06:24 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
    27/006/2013 03:06:24 - INFO - You can drag and drop ftf files here to start flashing them
    27/006/2013 03:06:31 - INFO - Launching Fastboot Toolbox 1.0 by DooMLoRD
    27/006/2013 03:06:32 - INFO - Device Status: NOT FOUND
    27/006/2013 03:06:34 - INFO - Device connected with USB debugging off
    27/006/2013 03:06:34 - INFO - For 2011 devices line, be sure you are not in MTP mode
    27/006/2013 03:06:44 - INFO - Device disconnected
    27/006/2013 03:06:49 - INFO - Device connected with USB debugging off
    27/006/2013 03:06:49 - INFO - For 2011 devices line, be sure you are not in MTP mode
    27/006/2013 03:06:55 - ERROR - This action can only be done in fastboot mode
    27/008/2013 03:08:13 - INFO - Selected ST25i_.54_Nordic_DevStaff.ftf
    27/008/2013 03:08:13 - INFO - Preparing files for flashing
    27/008/2013 03:08:50 - INFO - Finished Fastboot Toolbox
    27/009/2013 03:09:22 - INFO - Please connect your device into flashmode.
    27/009/2013 03:09:32 - INFO - Device disconnected
    27/010/2013 03:10:03 - INFO - Device connected with USB debugging off
    27/010/2013 03:10:03 - INFO - For 2011 devices line, be sure you are not in MTP mode
    27/010/2013 03:10:19 - INFO - Flash canceled
    27/010/2013 03:10:25 - INFO - Launching Fastboot Toolbox 1.0 by DooMLoRD
    27/010/2013 03:10:26 - INFO - Device Status: NOT FOUND
    27/010/2013 03:10:34 - ERROR - This action needs a connected device
    27/010/2013 03:10:36 - INFO - Device Status: NOT FOUND
    27/010/2013 03:10:46 - INFO - Device disconnected
    27/011/2013 03:11:00 - INFO - Device Status: NOT FOUND
    27/011/2013 03:11:10 - INFO - Device connected with USB debugging off
    27/011/2013 03:11:10 - INFO - For 2011 devices line, be sure you are not in MTP mode
    27/011/2013 03:11:13 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:17 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:18 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:20 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:23 - INFO - Device Status: NOT FOUND
    27/011/2013 03:11:24 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:26 - ERROR - This action can only be done in fastboot mode
    27/011/2013 03:11:26 - ERROR - This action needs a connected device
    27/011/2013 03:11:31 - INFO - Finished Fastboot Toolbox
    27/011/2013 03:11:35 - INFO - Device disconnected
    27/011/2013 03:11:36 - INFO - Device connected with USB debugging off
    27/011/2013 03:11:36 - INFO - For 2011 devices line, be sure you are not in MTP mode
    27/012/2013 03:12:57 - INFO - Device disconnected
    Ragazzi cosa posso fare? Aiuto
    Ultima modifica di Johnnyska88; 27-03-13 alle 04:47
    Caserta
    P20 / P10
    La batteria su che livello era? Per morto che intendi, i led si accendono?
    Ragazzi, titoli più sintetici e meno plateali .... mentre nei messaggi dovete mettere più dettagli sull'accaduto. In ultimo dovete scrivere all'interno delle guide che state eseguebdo o delle rom ... qua pare anarchia ed ognuno scrive dove gli pare.
    Accorpo alla discussione sul root visto che riguarda quella procedura.
    Ultima modifica di marce; 27-03-13 alle 09:57
  4. #583
    Grazie Marce per l'interessamento! Scusa se la forma della domanda e il topic non erano corretti. Ho risolto il problema: la batteria era carica al 90% e i led non si accendevano. Nonostante abbia provato a mettere il device in fastboot mode e in flashmode non succedeva nulla. Ho pensato da li a togliere la batteria e reinserirla. In questo modo il tel è risorto. Come mai è successo tutto ciò? Quali possono essere le cause di questo improvviso collasso del tel? Grazie
  5. #584
    Caserta
    P20 / P10
    E' successo qualche volta anche ame soprattutto dopo cambi kernel. Quindi non dare peso nulla di preoccupante, l'importante che ora sia tutto ok.
  6. #585
    E se volessi lasciare il kernel .10, come dovrei fare essendo che mi succede sempre questa cosa? Il link del primo post riguardante il kernel .10 è quello Munjeny?
  7. #586
    Caserta
    P20 / P10
    Sul firmware .54 non ti conviene lasciare quel kernel ma al contrario dopo aver ottenuto il root rimettere o il kernel .54 o il c.o. I kernel modificati li puoi mettere solo avendo bootloader sbloccato altrimenti no.
  8. #587
    Il bootloader l'ho già sbloccato seguendo la tua guida. Per c.o. intendi il Kernel 6.1.1.C.1.0?
  9. #588
    Caserta
    P20 / P10
    Si lui, ed allora hai carta bianca e puoi flashare qualsiasi kernel. Se non ti serve la recovery metti il c.1.0 altrimenti il munjieni, ce n'é anche un altro su xda ma ancora non ho portato la discussione qui appena ho tempo porto. Il vengeance é ottimo ma la recovery su stock non funzionava e non so se hanno risolto.
  10. Il seguente Utente ha ringraziato marce per il post:
    Johnnyska88 (28-03-13)
  11. #589
    Cosa implicherebbe non avere la recovery? (se posso) tu cosa mi consiglieresti in questo caso?
  12. #590
    Caserta
    P20 / P10
    Se non devi flashare mod varie la recovery non ti serve al momento e quindi puoi restare con il kernel stock sony dopo aver ottenuto il root. E cmq all'occorrenza puoi flashare un kernel con reovery quando ti servirà
  13. Il seguente Utente ha ringraziato marce per il post:
