Pagina 8 di 53 primaprima ... 67891018 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 527
Root Z1 4.4.4 con un semplice click
  1. #71
    Feb 2014
    Harlingen (NL)
    Sony Xperia Z1
    Ringraziato 119 volte in 92 Posts
    Quote Originariamente inviato da Alessandro1983 Visualizza il messaggio
    05/034/2014 17:34:16 - INFO - <- This level is successfully initialized
    05/034/2014 17:34:16 - INFO - Flashtool Version 0.9.15.0 built on 15-03-2014 23:00:00
    05/034/2014 17:34:21 - INFO - Device disconnected
    05/034/2014 17:34:28 - INFO - Selected Bundle for Sony Xperia Z1 (C6903). FW release : 14.1.G.1.534. Customization : [NUT]
    05/034/2014 17:34:28 - INFO - Preparing files for flashing
    05/038/2014 17:38:59 - INFO - Please connect your device into flashmode.
    05/042/2014 17:42:09 - INFO - Opening device for R/W
    05/042/2014 17:42:10 - INFO - Device disconnected
    05/042/2014 17:42:10 - INFO - Start Flashing
    05/042/2014 17:42:10 - INFO - Processing loader.sin
    05/042/2014 17:42:10 - INFO - Checking header
    05/042/2014 17:42:10 - ERROR - Processing of loader.sin finished with errors.
    05/042/2014 17:42:10 - INFO - Ending flash session
    05/042/2014 17:42:10 - ERROR - Error flashing. Aborted
    05/042/2014 17:42:12 - ERROR - Drivers need to be installed for connected device.
    05/042/2014 17:42:12 - ERROR - You can find them in the drivers folder of Flashtool.
    05/042/2014 17:42:14 - INFO - Device connected in flash mode
    05/043/2014 17:43:15 - INFO - Device disconnected
    05/043/2014 17:43:28 - INFO - Device connected with USB debugging off
    05/043/2014 17:43:28 - INFO - For 2011 devices line, be sure you are not in MTP mode
    05/044/2014 17:44:13 - INFO - Device disconnected
    05/044/2014 17:44:28 - INFO - Device connected in flash mode
    05/045/2014 17:45:28 - INFO - Device disconnected
    05/045/2014 17:45:37 - INFO - Device connected with USB debugging off
    05/045/2014 17:45:37 - INFO - For 2011 devices line, be sure you are not in MTP mode
    05/045/2014 17:45:52 - INFO - Device disconnected
    non capisco dove sbaglio...i driver li ho installati ma niente devo selezionare solo il file 14.1.G.1.534 o anche l'altro k è nella cartella?
    Hai messi il cellulare in usb debug?
    Ora devi aprire la cartella di flashtool ed entrare nella cartella firmwares ed eliminare la cartella "prepared" (mi sembra si chiami cosi ma lo vedi)
    il file da selezionare e solo quello che inserisci tu.
    Per prima cosa dobbiamo abilitare il debug usb nel nostro cellulare :
    1) Andiamo su impostazioni del cellulare e cerchiamo "info sul telefono" (solitamente e l'ultima voce)
    2) Entriamo su "info telefono" e cerchiamo "numero build" premiamoci piu volte sopra finche non dice ora siete uno sviluppatore.
    3) ritorniamo nel menu impostazioni e cerchiamo la voce "Opzioni sviluppatore"(solitamente penultima voce)
    4) entriamo in "Opzioni sviluppatore" e spuntiamo la voce "Debug USB "
    5) torniamo alla home del cellulare e colleghiamolo tramite cavetto usb al pc in modo che installi in automatico i driver
    Ora il vostro cellulare e pronto per il prossimo passaggio.
    Ricordati che il cellulare poi va collegato da spento (quando ti chiede di collegarlo) tenendo premuto il pulsante volume basso.
    (spegni cellulare,tieni pulsante volume giu premuto e senza lasciarlo collega l'usb.)
    Qualcuno ha provato ad usare l'app link2sd per liberare la memoria interna del nostro dispositivo con 4.4.2?Funge?
    Inviato dal mio C6903 usando Androidiani App
  4. #73
    Feb 2014
    Harlingen (NL)
    Sony Xperia Z1
    Quote Originariamente inviato da Desmojsh Visualizza il messaggio
    io utilizzo Clean master e molto semplice da utilizzare e ti avvisa se e meglio non toccare l'app di sistema.
  5. #74
    Ok Clean.... Ma io intendevo qualcosa che spostasse app su sd
  6. #75
    Feb 2014
    Harlingen (NL)
    Sony Xperia Z1
    Fai una ricerca qui sul forum scrivi solo " link2sd " .
    Se non erro per funzionare devi fare una partizione ,ora non ricordo bene ci dovrebbero essere varie guide.
  7. #76
    Quote Originariamente inviato da Firestorm2 Visualizza il messaggio
    [quote name="Desmojsh" post=5494989]Ok Clean.... Ma io intendevo qualcosa che spostasse app su sd
    Se non erro per funzionare devi fare una partizione ,ora non ricordo bene ci dovrebbero essere varie guide.[/QUOTE]
    Ok finestra...grazie per le dritte!
  8. Il seguente Utente ha ringraziato Desmojsh per il post:
    Firestorm2 (05-04-14)
  9. #77
    xke quando faccio il secondo passaggio dopo aver fleshiato e messa si blocca dopo la scritta xperia??
  10. #78
    Feb 2014
    Harlingen (NL)
    Sony Xperia Z1
    sicuro che si e bloccato?
    Hai atteso 5 minuti?
    la batteria e carica?
    Hai fatto esattamente come scritto nella guida?
    cosa intendi per secondo passaggio?
  11. #79
    entro nel menu faccio tutti i wipe carico la 290 poi faccio il flash alla riaccensione del pc fa sony xperia i disegni e il secondo neanche finisce e si riavvia e se provo ad entrare di nuovo nel menu per rifaew il wipe non mi fa entrare..la batteria era la 78 %....rifaccio il flash con la android 4.2 build 14.1.G.1.534
    Ultima modifica di Alessandro1983; 06-04-14 alle 15:27
  12. #80
    Feb 2014
    Harlingen (NL)
    Sony Xperia Z1
    Ora possiamo fare l'upgrade alla 4.3 vers. 14.2.A.0.290 .
    1) Scaricate questi 2 file :
    -=- [NUT]'s XDA download page -=-
    (Il primo File e un torrent quindi una volta scaricato dobbiamo procurarci un client torrent per scaricare il file che ci serve)
    2) Copiate il file "C6903_14.2.A.0.290.flashable.zip" nell'sd esterna del vostro z1 (non decomprimetelo va copiato cosi come lo scaricate)
    3) Copiate il file "C69XX_14.2.A.0.290_Stripped.ftf" nella cartella firmwares, presente dentro alla cartella di installazione di flashtool (ad esempio C:\Flashtool\Firmwares)
    4) Avviate la TRWP (spegnete il cellulare e durante l'accensione quando appare la scritta Sony tenete premuto il tasto volume basso in modo che vi si apra un nuovo menu)
    5) premete su Wipe poi su Advanced Wipe e mettete la spunta a queste voci:
    - Dalvik-Cache
    - System
    - Cache
    - Data
    Ora con il dito fate lo swipe della barra che vedete sotto per confermare .
    Finito questo passaggio NON spegnere il cellulare ma tornare alla home (pagina dove ci sono gli 8 tasti)
    Premete su Install e sul menu che vi apre premete sopra la prima cartella ( Up A Level)
    Cercate la cartella ( external_Sd ) e premeteci sopra (ora ci troviamo dentro la micro SD)
    Cercate il file C6903_14.2.A.0.290.flashable.zip e premeteci sopra
    Fate lo swipe con il dito sulla barra per confermare e attendete che il cellulare finisca.
    Alla fine NON riavviate assolutamente! Tornate alla home della recovery e premete su (Reboot) e poi su (Power off)
    aprite Flashtool sul vostro pc cliccate sopra il pulsante raffigurante un lampo (lo trovate nella parte alta a sinistra)
    lasciate la spunta su flashmode e cliccate ok
    Selezionate il file alla vosta sinistra (in questo caso 14.2.A.0.290) e cliccate su flash (lo trovate nella parte bassa a destra)
    Attendete che finisca tutta la sequenza e rimuovete il cavo (finisce in pochissimo tempo)
    Ora accendiamo il cellulare e siamo arrivati alla versione 14.2.A.0.290 con root.
    P.s. : Riabilitate la modalita debug usb (prima parte della guida)
    Quando fai i passaggi dello swipe non devi spegnere il cellulare ma tornare al menu principale (menu con 8 tasti) premere su reboot e poi su power off
    lasciare il cellulare spento, avviare flash tool e selezionare il file 14.2.a.0.290 fatto quello cliccare su ok e aspettare che flashtool ti chieda di collegare il cellulare.
    Sempre a telefono spento tieni volume giu premuto e collega l'usb e il programma procede.
    Avvia il cellulare solo dopo che ti dice che puoi scollegarlo e avviarlo.
