=                giefroot v3.1               =
=            created by zxz0O0               =
=       Many thanks to:                      =
=       - [NUT]                              =
=       - MohammadAG                         =
=       - Keen Team                          =
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
Waiting for Device, connect USB cable now...
Make sure that you authorize the connection
if you get any message on the phone
Device found
Sending files
63 KB/s (259 bytes in 0.004s)
cannot stat 'getroot': No such file or directory
cannot stat 'giefroot': No such file or directory
cannot stat 'modulecrcpatch': No such file or directory
cannot stat 'systemrw.sh': No such file or directory
cannot stat 'wp_mod.ko': No such file or directory
cannot stat 'UPDATE-SuperSU-v2.45.zip': No such file or directory
5117 KB/s (657704 bytes in 0.125s)
cannot stat 'installsupersu.sh': No such file or directory
Unable to open /data/local/tmp/modulecrcpatch: No such file or directory
Unable to open /data/local/tmp/giefroot: No such file or directory
Unable to open /data/local/tmp/getroot: No such file or directory
Unable to open /data/local/tmp/systemrw.sh: No such file or directory
Unable to open /data/local/tmp/wp_mod.ko: No such file or directory
Unable to open /data/local/tmp/installsupersu.sh: No such file or directory
Error: Seems your kernel / device is not supported
/system/bin/sh: /data/local/tmp/getroot: not found
Press any key to continue . . .
