Pagina 75 di 109 primaprima ... 2565737475767785 ... ultimoultimo
Visualizzazione dei risultati da 741 a 750 su 1081
[ZOPO 980/990/C2/C7][WIP]Sviluppo kernel (sorgenti) compatibile con KK
  1. #741
    non ci posso credere...ha dato errore dopo 2 ore e 45 minuti di compilazione -.-
    adesso mi tocca pure capire qual'č l'errore e poi rilanciare il tutto -.-
    codice:
    In file included from external/chromium_org/content/common/android/hash_set.cc:5:0:
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:10:26: error: extra tokens at end of #ifndef directive [-Werror]
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:11:26: error: missing whitespace after the macro name [-Werror]
    target thumb C++: content_content_common_gyp <= external/chromium_org/content/common/android/surface_texture_peer.cc
    target thumb C++: content_content_common_gyp <= external/chromium_org/content/common/android/trace_event_binding.cc
    target thumb C++: content_content_common_gyp <= external/chromium_org/content/common/browser_plugin/browser_plugin_constants.cc
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:24:20: error: expected initializer before '<' token
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:26:17: error: expected initializer before '<' token
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:29:22: error: expected '{' before '<' token
    out/target/product/eastaeon89_wet_kk/obj/GYP/shared_intermediates/content/jni/HashSet_jni.h:29:22: error: expected unqualified-id before '<' token
    external/chromium_org/content/common/android/hash_set.cc:30:1: error: expected '}' at end of input
    cc1plus: all warnings being treated as errors
    make[3]: *** [out/target/product/eastaeon89_wet_kk/obj/STATIC_LIBRARIES/content_content_common_gyp_intermediates/content/common/android/hash_set.o] Errore 1
    make[3]: *** Attesa per i processi non terminati....
    Nubia Z7MAX
    Senior Droid L'avatar di aquilacd70
    Localitā
    cuneo
    One Plus X - S3 Neo
    Ringraziato 58 volte in 49 Posts
    mamma mia ma che sfiga!!! sei anche un mostro nelle previsioni catastrofiche....hai scritto "se non da errore tra 2 ore o 3" e te lo ha dato dopo 2:45??!!
  4. #743
    ma perchč conosco i miei polli (in questo caso mediatek)
    cmq sembra sia un errore dovuto alla versione java in uso
    la cm11 la compili con quello che vuoi senza problemi
    questa invece se non hai java6 della oracle (su linux di solito si usa openjava) non va...
    adesso ho sostituito la versione java e rilanciato la compilazione...vediamo che succede (fra 2 ore e 45 )
    Nubia Z7MAX
  5. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    batman64 (26-08-14),SCLvit21 (26-08-14)
  6. #744
    Zopo C2 Platinum KitKat 4.4.2
    Ringraziato 151 volte in 82 Posts
    Alla Mediatek sono chiusi come il deretano di una scimmia...
    Inviato dal mio ZP980 usando Androidiani App
    BELLAAAAAAAAAAAAAAAA
    VENDO zona MN (oppure spedisco) mini pc Android MK808 + tastiera RC11 nuovi, volendo con giā la rom Finless installata
  7. #745
    Localitā
    cuneo
    One Plus X - S3 Neo
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    spettacolo allora sono in ansia per il verdetto , ore 18:10 circa :o
    ......ma il deretano della scimmia č chiuso??? poverina
  8. #746
    MI5 Zuk Z1 Zopo ZP980 Note3Neo
    Ringraziato 96 volte in 87 Posts
    Paolo se fai il miracolo, domani vado a piedi fino al Divino Amore, poi magari proseguo fino a Trigoria !!! Ah ah ah
    Inviato dal mio ZP980 2/32 ColorOs usando Androidiani App
  9. Il seguente Utente ha ringraziato lupotto301 per il post:
    SCLvit21 (26-08-14)
  10. #747
    Quote Originariamente inviato da aquilacd70 Visualizza il messaggio
    ehehe...ma magari ridā lo stesso errore
    oppure ne esce un altro diverso
    o chissā...esplode il sole e ci vaporizza o veniamo tutti risucchiati da un buco nero...o magari i maya si erano solamente sbagliati di data
    insomma...vedremo
    cmq hai sbagliato i conti
    Ultima modifica di PaoloW8; 26-08-14 alle 18:15
    Nubia Z7MAX
  11. #748
    Localitā
    cuneo
    One Plus X - S3 Neo
    insomma...vedremo
    sbagliato i conti??? tu lo hai detto alle 15:24 + 2:45 = 18:09.....oppure gli orari del forum sono errati??!!
  12. #749
    Localitā
    cuneo
    One Plus X - S3 Neo
    o cavolo, hai ragione, ora segna 16:24 il tuo post!! ma che cavolo........quindi 19:10 va..
    ma poi chi se ne frega...basta che ci riesci
  13. #750
    alle 15:45...poi ho dovuto cercare la soluzione, scaricare java oracle, configurare, rilanciare
    alle 16:24 ho scritto che ho rilanciato la compilazione....quello č l'orario da considerare
    (forse tu vedi l'orario di 1 ora indietro, basta che guardi che orario vedi in questo post....solo le 17:25)
    si infatti
    una cosa che ho imparato da molti anni č che bisogna avere pazienza in queste cose...ma tanta tanta
    Ultima modifica di PaoloW8; 26-08-14 alle 18:28
    Nubia Z7MAX
