Pagina 85 di 109 primaprima ... 3575838485868795 ... ultimoultimo
Visualizzazione dei risultati da 841 a 850 su 1081
[ZOPO 980/990/C2/C7][WIP]Sviluppo kernel (sorgenti) compatibile con KK
  1. #841
    Jul 2014
    paolo, collected systemrom CPU-Z relationship hangs on the sensors, in the IQ4400 rom sensors also not visible/ not work. sensors on something else where you have to specify?
    and 2 SIM not work
    Quote Originariamente inviato da dreamer7 Visualizza il messaggio
    and 2 SIM not work
    for sensor u have to compile the entire rom because some settings are in HAL
    for sim try to use the original zopo modem.img (rename in modem_1_3g_n.img)
    Nubia Z7MAX
  4. #843
    Androidiano L'avatar di Voldemaar
    Aug 2014
    RUSSIA
    iOCEAN X7
    Ringraziato 43 volte in 21 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    i found the kxtj2_auto driver in this source: https://bitbucket.org/DerTeufel/andr...6589/downloads
    i get from this (in custom/g4s dir accelerometer) the drivers: kxtj2_auto, mma8453q_auto, src
    and i have edited few things (i2c address)
    btw, in attach u can find my modified files
    ah, i use my compiled rom...in iq4400 rom sensors still do not work
    super! i got all sensors there!
  5. #844
    Jul 2014
    paolo, something does not add up to me.
    What is the latest list of modules sensors turned out?
    the camera has for some reason turned upside down
    Ultima modifica di dreamer7; 29-08-14 alle 11:56
  6. #845
    you talk about projectconfig.mk ?
    codice:
    CUSTOM_KERNEL_ACCELEROMETER=kxtj2_auto mma8453q_auto
    which driver u use ?
    in vanzo driver there is a config for the camera rotation
    codice:
    VANZO_MAIN_CAM_ROTATION = 180
    on zp990 is 180, on zp980 is 0
    if u use the original driver from 4.2 source u can add this line in projectconfig
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    dreamer7 (29-08-14)
  8. #846
    Androidiano L'avatar di forart
    Sep 2013
    VF-895N - Olipad100
    Ringraziato 21 volte in 19 Posts
    ITA: salve volevo segnalare che un'altro dev italiano (shutt1e @ XDA) che sta lavorando alla CM 10.2 per MTK 6589
    ENG: hi there, wanna inform you that another dev (shutt1e @ XDA) that is working on CM 10.2 for MTK 6589
    https://github.com//shutt1e/android_device_phonepad
  9. #847
    Quote Originariamente inviato da forart Visualizza il messaggio
    si ho parlato con lui un po' di tempo fa su xda via pm, gli ho passato tutte le patch che avevo fatto sulla cm11
    cmq la cm10 è android 4.3 mentre noi stiamo lavorando a 4.4 kitkat
    Nubia Z7MAX
  10. #848
    Jul 2014
    how to compile original driver from 4.2 ?
    ov12830trulybmipiraw_Sensor.c:1198:21: error: 'OV12830TRULYB_SENSOR_ID' undeclared (first use in this function)
    or/ov12830trulybmipiraw_Sensor.c:1198:21: note: each undeclared identifier is reported only once for each function
  11. #849
    Aug 2014
    RUSSIA
    iOCEAN X7
    you must add sensor to inc and src
  12. #850
    u need to edit some file...i have done some days ago and now i don't remember which files
    btw i'm still working on it because not work property (focus for example)
    when i'm done i will release the source code
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    dreamer7 (29-08-14)
