Pagina 78 di 109 primaprima ... 2868767778798088 ... ultimoultimo
Visualizzazione dei risultati da 771 a 780 su 1081
[ZOPO 980/990/C2/C7][WIP]Sviluppo kernel (sorgenti) compatibile con KK
  1. #771
    Quote Originariamente inviato da dreamer7 Visualizza il messaggio
    Hi paolo, I tried to build a new kernel (eastaeon89_wet_kk). got a bunch of vertical gray bars on the display. overheated GPU. then this is still half a day the screen flickered.
    besides ADB shell work - showed the kernel version 3.4.67
    have not seen such a problem?
    Quote Originariamente inviato da Voldemaar Visualizza il messaggio
    Hello, Paolo! I try to compile kitkat kernel for my iOcean X7, but i cant boot, shows me just logo. Your C2 have different TP and cameras. Can you share your project? or help me to boot kernel?
    try to compile with command:
    codice:
    LOCALVERSION= TARGET_BUILD_VARIANT=user ./makeMtk eastaeon89_wet_kk n k
    and use a KK rom for boot
    for vertical gray bar try to change the lib in /system/vendor/lib from another KK rom
    (i use the vendor/lib from vibe x rom VIBE UI???? - ????)
    Nubia Z7MAX
  2. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    dreamer7 (27-08-14),Voldemaar (27-08-14)
    Androidiano L'avatar di Voldemaar
    Aug 2014
    RUSSIA
    iOCEAN X7
    Ringraziato 43 volte in 21 Posts
    Also i have a question about Lcm driver. Do you edit KK lcm nt35596_fhd_vdo_truly or use another from 4.2?
  5. #773
    Jul 2014
    paolo, Vibe UI are using? have not tried the full build?
  6. #774
    i have a zopo 990 using lcm nt35595_lg60_truly (which is not in the source kk)
    i use the driver from 4.2 kernel
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
  8. #775
    yes, now i have a full build
    but before yesterday i used a mix of rom (this rom Fly IQ4410 Quad Phoenix - Êàñòîìíûå ïðîøèâêè (OS 4.x) - 4PDA with /system/vendor from vibex)
    Ultima modifica di PaoloW8; 27-08-14 alle 10:59
    Nubia Z7MAX
  9. #776
    Aug 2014
    RUSSIA
    iOCEAN X7
    [QUOTE=paolothlw8;6020917]try to compile with command:
    codice:
    Mama mia! It booting! Bravissimo, Paolo!
  10. #777
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    codice:
    ehehe nice
    Nubia Z7MAX
  11. #778
    Aug 2014
    RUSSIA
    iOCEAN X7
    Do you fix sensors?
  12. #779
    Do you fix sensors?
    not yet
    Nubia Z7MAX
  13. #780
    Senior Droid L'avatar di aquilacd70
    cuneo
    One Plus X - S3 Neo
    Ringraziato 58 volte in 49 Posts
    novità della tua kk da ieri sera??? :o
  14. Il seguente Utente ha ringraziato aquilacd70 per il post:
    SCLvit21 (27-08-14)
