Pagina 48 di 48 primaprima ... 38464748
Visualizzazione dei risultati da 471 a 474 su 474
Nubia Z11 Max: 6" Snap 652 4 Gb Ram 64 gb Storage
  1. #471
    Feb 2014
    Marche
    Grandi, Grossi... Cinafonotti
    Ringraziato 8,542 volte in 6,492 Posts
    Quote Originariamente inviato da Paanty Visualizza il messaggio
    Ciao amici a tutti sono nuovo. Avrei bisogno di aiuto nel tentare il reset del mio Nubia z11 Max non si accende più. Rimane ferma la scritta Nubia. Qualcuno può aiutarmi ?
    Inviato dal mio LEX720 usando Androidiani App
    Home ZTE ZTE Nubia Z11 Max Hard Reset and Factory Reset of ZTE Nubia Z11 Max
    2 years ago 0 Comments ZTE, ZTE Nubia Z11 Max
    Before you try the factory reset or hard reset on your device, make sure that you have backup your important files. Restoring the default settings or factory reset your device will delete all your existing files and will go back to its initial state.
    Factory Reset:
    >>> On your device touch on Home.
    >>> Go to Apps, then Settings.
    >>> Select on Backup and reset.
    >>> Choose Factory data reset.
    >>> Touch on Reset phone. If you also want to remove all data saved to an installed micro SD, just tick the Erase SD card check box before touching Reset phone.
    >>> And lastly touch on Erase everything and just follow the prompt to complete the factory reset.
    Follow the onscreen instructions to set up your phone again after the reset.
    Hard Reset:
    >>> Turn off your phone.
    >>> Press and hold together Volume Up + Power button for a few seconds.
    >>> Once Recovery menu appears on the screen, release the buttons.
    >>> Select "wipe data/factory reset" by using Volume buttons, and Power button / Volume Up to confirm.
    >>> Then choose "Yes -- delete all user data".
    >>> Confirm operation "reboot system now".
    prova la procedura da spento entrando nella recovery Zte
    non c'è più nessuna novità o aggiornamento per lo Z11 max? tutto fermo ?
  4. #473
    Senior Droid L'avatar di Vash89
    Sicilia
    G2-G4-RN3P-P1-IDOL3-Z11 MAX...
    Ringraziato 34 volte in 29 Posts
    Quote Originariamente inviato da mdlele Visualizza il messaggio
    Anche io aspetto da un pò qualche sviluppo, ma purtroppo credo che nessuno si interessi più.
    Peccato perché il dispositivo è una bomba e non credo di cambiarlo presto.
  5. #474
    Jan 2018
    Anche a me è successo... Ho trovato un archivio e gliel'ho copiato sopra e poi ho messo su la rom di Pesa e adesso funziona. Si è aggiornata a Android 6 prima aveva 5.1
