Visualizza i risultati del sondaggio: Quale ROM per z7 Max ti soddisfa di più?
Chi ha votato
74. Non puoi votare questo sondaggio
  • STOCK Nubia UI
    5 6.76%
  • Mod By BB72 "Phablet Experience"
    46 62.16%
  • Mod By BB72 "Phone Experience"
    16 21.62%
  • CM11/MOKEE
    2 2.70%
  • Altro....
    5 6.76%
Pagina 221 di 429 primaprima ... 121171211219220221222223231271321 ... ultimoultimo
Visualizzazione dei risultati da 2,201 a 2,210 su 4286
[ROM][KK 4.4.x] Stock modded by BB72 per Nubia Z7 Max | Basata su 1.62 [NX505J]
  1. #2201
    Quote Originariamente inviato da enay Visualizza il messaggio
    I cant receive international sms like wahtsapp or truecaller or any international sms(from outside my country )
    i did not had this problem before in my other phones
    i have try to use different sim from defferant cellular provider here but same problem
    i now it is wired but that's my problem
    No idea and I have no way to check...only thing I know is that into 1.48 in order to have the incall associated with contact you have to set all contacts number with international prefix...maybe ZTE also changed something related to international sms...I suggest you to make nandroid backup via cwm and then install the stock 1.48 in order to see if it works... also you could try my 1.41 Repack just to see if with previous release it is ok....
    [quote name="enay" post=6343343]I cant receive international sms like wahtsapp or truecaller or any international sms(from outside my country )
    EDIT: check that into settings/others/sms predefined app you do not have Titanium backup as default one....
    Another test could be to install 3rd party sms app (e.g. Messenger) and set it as default....
    Inviato dal mio NX505J usando Androidiani App[/QUOTE]
  4. #2203
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    BB72 dopo un giorno di full 1.48 che mi dici cambia qualcosa dall ota ?
  5. #2204
    Quote Originariamente inviato da PIGTWO Visualizza il messaggio
    [quote name="manuelb" post=6343319]Mi dispiace Franky69...hai i mie stessi sintomi...
    Cmq io sto continuando a farci di tutto...ma niente...ho dovuto rimettere in esercizio il mio vecchio S2...a questo punto non mi rimane che cercare di ripristinarlo e mandarlo indietro...
    Tra i vari smanettamenti ho scoperto che dopo aver spinto il tasto power se si tengono tre dita contemporaneamente sopra i tre tasti softouch si avvia in modalità provvisoria, cioè appare la scritta "modalità provvisoria" in basso a sinistra, ma poi non so che faccia perchè mi si spegne...
    Aggiungo, non so se possa essere indicativo di qualche cosa, ma quando lo collego al pc mi appaiono tutte queste unità:
    E per ogni unità mi apre la finestra con la richiesta di formattare l'unità...[/QUOTE]
    A me succedeva quando ho cambiato la partizione… poi con il fix wifi di cuoco ho risolto ed è resuscitato… prova lo ��
    BB72 for president… 1.48 va che è una scheggia 4G esagerato con Tim 35 MB
    Stessi identici sintomi se lo collego al PC.
    Vorrei provare il fix ma dove trovò le istruzioni?
    Se non riesco vorrei tornare alla ROM stok e sfruttare la garanzia ma non ho idea come, mi potete dire la pagina dove se ne parla?
    Scusate ma non riesco a trovarla.
    Inviato dal mio ZTE Z7MAX usando Androidiani App[/QUOTE]
    Vai alla prima pagina sotto e trova questo
    Io al momento ho flashato 1.41 stock con recovery stock.
    Non sia avvia quasi mai e quando si avvia dopo qualche secondo si sblocca e si spegne, altre volte all'avvio fa un rumore tipo tv senza segnale e si spegne.
    Io lo lascio cosi.
    Ho contattato il venditore, sono in attesa di risposta.[/QUOTE]
    Da dove lo hai preso ???
  6. #2205
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    Notato nulla di nuovo....
  7. #2206
    Senior Droid L'avatar di PIGTWO
    Jul 2014
    Meizu M1 Note Blue 32g
    Ringraziato 42 volte in 38 Posts
    Io lo lascio cosi.
    Aliexpress
  8. #2207
    Androidiano L'avatar di RadamanZero
    Ringraziato 25 volte in 20 Posts
    Non riesco in nessun modo a replicare il problema...
    Non ti preoccupare ti ringrazio tantissimo, vedrò di fare qualche altra prova da me ed in caso ti faccio sapere ancora grazie!!!
    P.S. è possibile che tu possa estrarre il solo contatti.apk per provare a reinstallarlo/riflasharlo? thx
  9. #2208
    Quote Originariamente inviato da RadamanZero Visualizza il messaggio
    [quote name="BB72" post=6343318]Non riesco in nessun modo a replicare il problema...
    P.S. è possibile che tu possa estrarre il solo contatti.apk per provare a reinstallarlo/riflasharlo? thx[/QUOTE]
    Il mio contatti.apk è lo stesso che trovi nello zip della 1.48 sotto system/priv-app....ho anche rifatto il flash per riprova....
  10. Il seguente Utente ha ringraziato BB72 per il post:
    RadamanZero (25-11-14)
  11. #2209
    ricevuto provo thx
    Provato a reinstallarla mi da errore mi dice che l'applicazione non ha certificati
    Ultima modifica di RadamanZero; 25-11-14 alle 17:38
  12. #2210
    Oneplus 8T 12/256
    Ringraziato 3,599 volte in 2,650 Posts
    scusate la domanda un po' datata ) mi e' arrivato lo Z7 Max con firmware 1.38 , sto testando un po' il telefono e mi sto accorgendo che la rete 3g con wind va piu' lenta in scaricamento dati rispetto al precedente telefono. Ho settato su GSM/WCDMA preferred ma la situazione sembra non migliorare. APN a posto ( internet.wind). Con la 1.41 o la 1.48 stock si risolve qualcosa ? Ho letto il changelog della 1.41 e della 1.48 su nubiaforums ma non mi sembra si parli di miglioramenti in tal senso.
    Prima di installare la modded di BB72 volevo fare qualche prova con la stock.. Grazie
    Ultima modifica di bluemask; 25-11-14 alle 17:46
