Visualizza i risultati del sondaggio: Quale ROM per z7 Max ti soddisfa di più?
Chi ha votato
74. Non puoi votare questo sondaggio
  • STOCK Nubia UI
    5 6.76%
  • Mod By BB72 "Phablet Experience"
    46 62.16%
  • Mod By BB72 "Phone Experience"
    16 21.62%
  • CM11/MOKEE
    2 2.70%
  • Altro....
    5 6.76%
Pagina 417 di 429 primaprima ... 317367407415416417418419427 ... ultimoultimo
Visualizzazione dei risultati da 4,161 a 4,170 su 4286
[ROM][KK 4.4.x] Stock modded by BB72 per Nubia Z7 Max | Basata su 1.62 [NX505J]
  1. #4161
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi BB,
    Whenever I unlock the screen or after finish the phone call, screen light is on only after 5 sec until that screen looks black. But red notification light is immediately on.
    Whatz the problem, how to solve. I am still using 1.64
    Thanks
  4. #4163
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi BB,
    Thanks
    I'm not anymore on kitkat since weeks.. and..to be honest I didn't notice what you are experiencing...is something you always had as strange behavior or just recently? If recently check some conflicting app you installed or maybe make factory reset
    Inviato dal mio LG-D858HK usando Androidiani App
  5. Il seguente Utente ha ringraziato BB72 per il post:
    niza2000in (29-04-15)
  6. #4164
    Oct 2014
    Thanks for the support.. Since last two days I am facing things problem. Anyway I am plannig for Lollipop upgrade.
    How about 3.09, I read many comments stable and faster than 3.08. What's your opition
    In case if I want upgrade to 3.09, can I directly wire tool brush from 1.64 or 1st I need to upgrade to 2.13 then 3.09.
  7. #4165
    For 3.09 I'm working on it....As said...it is good room...even of not complete as kitkat (e.g. Not possible to switch off one sim or to select SD as main memory and others details...)
    For what I understood you can upgrade to 3.09 with nubia tool 2.0 directly from 1.64 but I couldn't verify it since I was already on 3.08...
  8. Il seguente Utente ha ringraziato BB72 per il post:
  9. #4166
    Nov 2014
    nubia z7 max vs nubia z9 mini ? mi dite pro e contro ?
  10. #4167
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Nubia z7 max pro...z9 mini contro scherzo ahaha cmq z7 max superiore in tutto ma 5.5 z9 mini 5 pollici
    Ultima modifica di manuelb; 01-05-15 alle 18:23
  11. #4168
    Nov 2014
    un mio amico vuole fare scambio col mio nubia z7 max di 6 mesi per lg g2 e htc m7 entrambi di un anno che dite?
  12. #4169
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Tieniti il max 😉🙌
  13. #4170
    Nov 2014
    perchè? non è conveniente lo scambio?
