Pagina 39 di 163 primaprima ... 2937383940414989139 ... ultimoultimo
Visualizzazione dei risultati da 381 a 390 su 1630
[Rom custom,stock,root,kernel,Driver,etc]Nubia z7 max
  1. #381
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    è uscita la versione stock 1.62 (beta ovviamente per il momento...diventerà ufficiale se non si troveranno grossi bug)
    nubia?????????????,rom,??,??,????
    changelog tradotto da google
    solve the card a mobile 4G, card 2 Unicom, the mobile phone card fumbled questions
    optimize card a telecommunications card 2 Unicom two cards texting speed
    interface to optimize incoming calls
    solve the front camera self-timer in the sun, people face the problem of part of a spot
    connected to the computer is turned on solving large-capacity storage, restore the default ringtone problem
    solving pressing Back button appears when charging nearly 100% jump screen problem
    solving nubia Niu error interception SMS problem
    solving Niu two flow calibration card, the card does not automatically replace two texting problem
    solving Gallery Set Wallpaper gallery when the question of error
    to optimize the system comes back up, including desktop settings can not be restored to solve problems, to solve a scheduled backup failed question, compatible with older versions of the backup data format
    recommended applications increase Koala FM radio
    software close call background sound
    to resolve the question of error systemU process
    optimization FOTA update process online
    new "special thanks" menu item, showing part of the beta group members
    Ma Android L?
    Ma Android L?
    non penso, ci sarebbe scritto
    cmq adesso la metto in download
    Nubia Z7MAX
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    BB72 (16-01-15)
  5. #383
    ah...hanno appena postato questa cosa riguardo la versione lollipop
    codice:
    Little friends, Hello, everyone!
    Z7Max and Z7mini 4G telecom Netcom single card full version has been released for some time, the new 4G telecommunications single card to verify the version currently being tested, the test results will be reviewed next week to see if suitable for everyone to use. Recently, many small partners are more concerned on Android L version, in this very sorry, but the original plan in mid-January release Z7Max, Android L beta version Z7mini behind schedule because of various reasons, to reach previously expected.
    Specific reasons I will not say more, we have to say we save to make excuses, let the status quo for the next version of it:
    Z7Max: Android has provided a beta version of L (the old UI 1 early January fitness equipped), there are the second version (new UI visual effects) are internal testing;
    Z7mini: The first Android L version is currently being tested.
    In Android L version, while when UI 2.5 version based on Android 4.4 beta underway, according to everyone's feedback to update the official version. The update, in addition to upgrading Android L platform, while the UI visual effects were larger adjustment, and modify the system partition, you need to use wire brush tool to complete the upgrade, and the original data will be completely removed. We find that during the self-test of the beta version and the Brush tool and a larger presence of the current instability and risks (including the brush into the brick, the parameter is missing, part of the application does not work properly, etc.), we can not reach the outside world version send request.
    We also hope to launch soon a bit of a relatively stable version for everyone to experience, from the present rate of progress it will take some time to look at, I hope you can understand.
    Thank you.
    link: nubia?????????????,rom,??,??,????
    praticamente sembra che cambierà anche la dimensione delle partizioni del cell e per questo l'upgrade sarà da effettuare tramite un tool dal pc
    Ultima modifica di PaoloW8; 16-01-15 alle 14:17
    Nubia Z7MAX
  6. #384
    Thank you.
    Certo se continuano a perdere tempo con kitkat...!!....
    mi sa che non lo vedrò mai Android L su questo device...stanno uscendo dei dualism veramente interessanti....
  7. #385
    personalmente preferisco facciano le cose con calma ma sicure invece di far uscire qualcosa a rischio brick (e prevedo molti brick visto la necessità di usare il pc per upgradare a android L )
    cmq il lavorare su kitkat non preclude di lavorare anche su lollipop....saranno sicuramente team diversi, non penso lavori una persona sola in nubia
    in più non sono mai stato il tipo che smania per cambiare cell ogni mese...anzi tutt'altro, lo z7 max mi durerà fino a quando non si romperà
    Nubia Z7MAX
  8. #386
    Beato te...io cambio spesso e questo max ha già oltrepassato da tempo il record di permanenza tra le mie mani....vedremo....
  9. #387
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Bene bene bene ottimo paolo aspettiamo il tu primo feedback sulla 1.62 facci sapere se cambia e in che cosa....per android l si sapeva che non avrebbero potuto riuscire per metà gennaio precisamente mica é una stock google é normale ragazzi che per una cosa fatta bene bisogna aspettare attualmente in italia apparte nexus 5 nessun device é stato aggiornato ad android L
    Inviato dal mio z7 max 48000 antutu usando Androidiani App
    Ultima modifica di manuelb; 16-01-15 alle 15:23
  10. #388
    Ringraziato 33 volte in 32 Posts
    il vantaggio di questa nuova twrp 2.8.3.0 plus è che oltre a fare il backup classico della system, data e boot può fare il backup anche delle partizioni "speciali" tipo bootloader, persist, nvram, etc quindi si ha una copia completa del cell.
    consiglio di attivarle quando si fa il backup in modo da poter ripristinare il cell "completamente" in caso di necessità
    Per caricare una nuova rom è sufficiente date il wipe tradizionale su TWRP : Data, Cache e Dalvil?
    A cosa serve il Format data?
    Nel ADVANCED WIPE c'è anche il System, il Secure ma non vedo la memoria interna?
    Per favore mi aiuti a fare chiarezza.
    Ciao
  11. #389
    Quote Originariamente inviato da ldani Visualizza il messaggio
    Ciao
    io quando flasho una rom da zero e voglio fare il wipe completo faccio semplicemente wipe da twrp (che è il factory reset e quindi fa il wipe data, dalvik e cache)
    è praticamente l'unico wipe che serve
    al limite a volte potrebbe servire formattare la system (che puoi fare dall'advanced) ma a me non è mai servito farlo anche perchè di solito la system viene formattata dallo script di flash della rom.
    nell'advanced puoi selezionare quali partizioni formattare, la memoria interna è internal flash mentre la sd esterna è micro sdcard (non li ho provati ed è una cosa che non faccio mai)
    il format data è semplicemente il format della partizione data...praticamente inutile perchè lo fa già il wipe classico
    Nubia Z7MAX
  12. #390
    La questione di android l mi intriga una nuova interfaccia e chiedono tempo mi aspetto qualcosa di eccezionale.....
