Plugged in this morning, nothing etc.
Not visible in my computer or device management
Only after start and volume it it vieble.
No com ltp but als device.
In HDD Raw device manager it is initialize but it looks like a mass.
MEGA for bigger picture
https://mega.co.nz/#!cVd1jazR!NPkm4W...EJ2kqRcIzeOUjE
https://mega.co.nz/#!hdcRALCK!vvz-bl...HeAuKs06Sfe5Kc
I have to go to work.
Try again to night
Probably usefull information
com ltp but as device is back.
Driver Qualcomm HS-USB QDLoader 9008 is there
In HDD raw Disk management Console mine dirve 1 says Partion style GPT Wrong GUID PARTION TABLE (GPT).jpg
I did do anything there and i did an partion style what so ever. Could i be that the partion style is a problem that the Z7 is not coming alive?
Should i change the partion style:GPT disks (GUID Partition Table) convert (MBR master boot record, master boot record) using the Windows interface
HDD RAW Says:
1 Please back up all volumes on GPT basic disk you want to convert to an MBR disk or move them.
2 If the disk partitions or volumes, right-click on the volumes on the disk and then Delete Volume.
3 Right-click on the GTP disk you want to convert to an MBR disk, and then click Convert to MBR disk.
Ultima modifica di Jan1959; 10-02-15 alle 23:17
- Motivo: Help from HDD RAW
>Hi Friend, i would appreciate yor help, my Nubia Z7 max is bricked after flashing the new(from needrom site) 5.0 stock rom and reflashing the original kitkat stock rom.
I need to repartition the phone storage , when i boot it appears only 4.0 Gbyte storage for programs , but no internal storage.
do you know How to repartition the internal storage?
can you give help in english
Gracie
Thank you
Hi, i sad to say that mine Z7 is officially dead. I think i was at the good way to find a solution but in the end is did nog succeed.
I already bought another phone and i will be carefull to use unstable tweaks.
Succes with you phone
Hi Friend,
i bricked my ZTE nubia 7max by trying to flash new stock 5.0 rom and go back to kittkat, the internal memory needs to be reinitialized.
i am able to go to Boatloader and to Stock recovery
can i use your method ?
I tried to understand you by google translate but could not.
can you give me a short english text ( Driver already installed)?
You can try but you must make a repartition. For this you can use or winhex or disk genius https://mega.co.nz/#F!rEBFXJTS!BXIXNgsY1NtPew7aGZpC2w
Ciao buona,
Io sono spagnolo e la traduzione ho usato il "traslator google" Ho bisogno di aiuto con il mio Z7 mini e ti dirà cosa è successo a me: ho il telefono per 5 mesi e in un primo momento ho fatto radice e introdotto le gapps con TWRP recupero e tutto perfetto il dispositivo ha funzionato molto bene, circa 10 giorni fa ho deciso di entrare nel Rom di Cuoco92 1.82 e tutto era perfetto, ma un aggiornamento KRASH esaurito funzionalità delle reti mobili che ho controllato e il problema è che non ho avuto IMEI di aveva perso, ho deciso metro il metodo Unbrinck con Nubia ToolStudio "nx507J_files" e provando e molte volte ho avuto modo di caricare la versione di origine, poi con la "RF_NV_Manager" Ho cercato di entrare nel IMEI (2) e di MEID ma ha ottenuto soltanto segnando il IMEI1. Provo più volte con diversi autori NV_Items senza successo anche io stavo leggendo forum cinesi e disperatamente attaccato con ToolStudio file Nubia Z7 MAX e da allora niente funziona e Gestione periferiche non riesce a "QHUSB_BULK" cosa Habre provato mille volte con diversi computer con Windows 7 e Windows XP e niente, ho aperto il telefono e ho staccato la batteria e niente, io sono disperata e non hanno più a che fare ... se si pensa a qualcosa. Si potrebbe mettere un recupero con HDDRaw?
Grazie in anticipo.
Per l'imei avrei potuto aiutarti ma oramai che hai flashato la rom del max sul mini non penso ci sia molto da fare....se in gestione periferiche ti compare qhusb_bulk, tu potresti provare a installare i driver in maniera forzosa....se non é possibile fare ciò non puoi agire neanche con qpst, per hddrawcopy avresti dovuto farti un backup del tuo dispositivo poiché nessuno può inviare il suo backup che contiene imei ecc questo porterebbe alla clonazione ed a molti problemi..
Qhsusb_bulk Solo fuori e non posso cambiare a COMXXX.¿con questo non può fare nulla.?
Gracias
- Non puoi inserire discussioni
- Non puoi inserire risposte
- Non puoi inserire allegati
- Non puoi modificare i tuoi messaggi
Regole del Forum
