Pagina 29 di 62 primaprima ... 19272829303139 ... ultimoultimo
Visualizzazione dei risultati da 281 a 290 su 618
Guida di unbrick z7 max-mini
  1. #281
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Have you try to tap on refresh ?
    Rawprogram0.xml there is on the package of rom..Control !!
    Inviato dal mio z7 max 48000 antutu usando Androidiani App
  4. #283
    Feb 2015
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    I saw that Cracky said that you must rename the map z7max_nx505j with chinese signs and delete these
    Afterthat the xml stop was gone.
    First i write NX505J_PROSign_DSXPK1JD00H138App_elf with HDD RAW
    It did not succeed
    Then I write NX505J_Z0_CN_DSXPK1JD11H138 with hdd
    It looks every was writing to the device and it ended succesfully.
    After that i wait for the process to finish ... .at the end you will have your nubia "always if everything runs smoothly" functioning , peel it off and restart it ....
    When i unplugged from the PC and start it it still vibrating shortly.
    Do i miss something.
    nubia tool info
    21:04:00:911 Release DM Service. PortName:
    21:06:23:534 Release DM Service. PortName:
    21:06:24:109 COM8[USB1#3#3] disconnected
    21:07:37:123 Release DM Service. PortName:
    21:09:23:555 Release DM Service. PortName:
    21:15:06:174 Release DM Service. PortName:
    21:17:46:914 COM8[USB1#3#3] disconnected
    21:25:49:224 Release DM Service. PortName:
    Ultima modifica di Jan1959; 09-02-15 alle 22:38 - Motivo: nubia tool info
  5. #284
    Feb 2015
    My phone did not response.
    After unplugged several times i see after restart and volume down all the driver show again but also mine z7 in my computer
    Im afraid to unplugged it from mine PC.
    What to do.
    We are almost there i think.
  6. #285
    Try this driver https://mega.co.nz/#!kpR3VBZT!vBqK47...XhZmTQBHMQd0Cg install it as i showed you and retry with nubiatool
  7. #286
    Feb 2015
    When unplugged it and start it does nothing
    When I plugged it in the PC i still vibrates again and again.
    I see nothing in my computer
    When pusing start and volume down it does not response
    After start and volume down and up Z7 is coming back
  8. #287
    Feb 2015
    When i brows the drive i see a application that is downloaded mine own N7player
    not recognizable 15376982.pkm
    Does that mean that i got my old information back but the the written software is not truly been written to the drive.
    Ultima modifica di Jan1959; 09-02-15 alle 23:35
  9. #288
    Feb 2015
    I just try to installed the driver again and now i have to restart mine PC.
    I try the nubia tool again and will write the result
  10. #289
    Feb 2015
    Nubia tool ended succesfully.
    Refersch afterwards does not show min z7
    Unplugged, Does not start
    Plugged, does vibrate again and again
    Power en Volume up and down shows mine phone again.
    Drive can be seen en maps and files are there
    In stead of start START ALL?
    22:46:37:816 Release DM Service. PortName:
    22:48:48:190 COM8[USB1#3#3] disconnected
    22:52:15:437 Release DM Service. PortName:
  11. #290
    Quote Originariamente inviato da Jan1959 Visualizza il messaggio
    Not for this but for qhusb_bulk....you must click on update driver on qualcoom hs_usQloader..in com ltp
    Ultima modifica di manuelb; 10-02-15 alle 07:47
