Pagina 23 di 96 primaprima ... 1321222324253373 ... ultimoultimo
Visualizzazione dei risultati da 221 a 230 su 958
[ROM] [Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #221
    thanks for the report
    1) I checked in the configuration of the rom and is was set only 1 user, now I have it set to 4
    2) I have only one icon Sim Toolkit, probably it depends on the sim
    3) I will check
    4) fixed
    5) I need to do more tests for fix it (yes for now works only after start recorder)
    6) auto brightness seems to me that it works properly (with or without livedisplay active), I can do more testing
    7) yes is superfluous but not a real issue
    8) my phone never hang when i tap on compass icon in statusbar notification (I tried 30-40 times)
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (15-07-15)
    Ringraziato 282 volte in 242 Posts
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    Good evening dear Paolo!
    I'm from Russia, and it is difficult to correctly express their thoughts on CM12. I apologize in advance for your trouble. Despite the fact that I registered on the forum just a couple of hours ago, I can assure you that what I write is true. I work in the field of software testing and have this great experience. If you do not understand some of the points, ask, I will try to explain or make a video.
    So, I have seen the problems and shortcomings in the CM12.1
    - Icon "My Profile" in the top right corner of the notification does not open the window for editing the profile. In addition, the phonebook is no field "Customize Profile", ie it is impossible to create a business card of my contact. I do not rule out that the reason for the absence of an account Cyanogen Mod on my device.
    - SIM menu is displayed twice (two icons). The first icon Sim Toolkit gives you access to the SIM-menu of both SIM cards. The second icon Sim toolkit 2 SIM menu opens a second SIM card. I think that the second icon is superfluous.
    - The rest is always running dual core processor (CPU Core CPU Core 0 and 3).
    - When connecting the device to a PC via Mass Storage (UMS), a blank CD-ROM. I checked this mode for WinXP and Win8.
    - If you enable the recognition of the phrase "Okay Google" on any screen, this function will not work anywhere except the application itself Google. To fix this, you need to install the firmware after open Recorder and press the Record button. Phone hangs for 5-7 seconds, then starts recording. Now, you can cancel the recording process and ensure that it is now the phrase "Okay Google" works with any screen. There is a suspicion that the service is necessary to initialize the voice recognition microphone somehow. Probably for the same reason, the recorder freezes on first use. Pay attention, that the data manipulation required after installing the firmware when the application is not to be started nirazu Recorder. This bug has been seen on the firmware present on the beta1 and beta2.
    - Auto brightness likely (not exactly sure, because he could not determine the relationship) begins to run only when the user disables auto-tune and at least once manually change the brightness with the slider in the notification bar.
    - In the application settings menu App Phone - Settings - General - Phone ringtone is superfluous, as it allows to assign the ringtone without reference to a specific SIM card. In these settings, there is a set of options that allows you to assign a ringtone to each SIM card (App Phone - Settings - Calling accounts - Sim card 1 / Sim card 2).
    - In the setting of the notification bar, if you add a tile Compass, with a high probability when enabling notifications Compass in the curtain will hang for 7-10 seconds. Tile Compass at this time will be highlighted white circle.
    PS Some of these problems are drawn for a long time, there are some even YiOS, and some have appeared recently.
    Sincerely, users 4PDA Forum community in Russia!
    The ok google bug is also on mini z7.
    Now I use nova as workaround ...
  5. #223
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Thank you for the quick response!
    6) I'm not talking about LiveDisplay function. When I installed the CM, the brightness does not change depending on the brightness of the room. Then I opened the settings, uncheck the automatic correction of brightness and change the brightness level slider that is in the notification bar. Then I turn on the switch again, the automatic correction of brightness and it has earned. I'll test it, maybe I'm wrong ...
    8) Could not reproduce the bug again to record the video. I'll test this new version to identify addiction.
    In addition, twice hitting the bug when after unlocking device appears API, which was open to the lock, and then 2 seconds all is lost and can only be seen wallpaper, then the interface will appear again. I tried to block the device several times, but every time you unlock the bug manifests itself again. It helps to reboot the machine. I have not been able to reveal the dependence of the appearance of the bug, so I can not fully describe it or play video.
    Thanks for your work! I appreciate it.
  6. Il seguente Utente ha ringraziato LiveMoto per il post:
    luiseteyo (15-07-15)
  7. #224
    how to have enabled the ok google everywhere ?
    with trebuchet launcher (the cyano stock launcher) it seems impossible, you use the google launcher ?
  8. #225
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    I installed Google Search application and has included this feature in the application settings.
    Google Launcher I do not use.
    I want to say that this feature is implemented in the Google search application. The launcher can not do it, and it should not.
    Screenshot from the Internet:
    Ultima modifica di LiveMoto; 15-07-15 alle 13:25
  9. #226
    yes I have installed google search
    but if I use trebuchet i can set search only in google app
    if I use google launcher i can set in every home page
    with google launcher "ok google" works well
    so I think it's a trebuchet problem, I do more tests
  10. #227
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Dear Paolo unfortunately the language barrier does not allow me the first time to explain to you what it is about =) I'm sorry.
    In your screenshots shows the switch number 1.
    I'm telling you about the switch number 2 is called the switch "Frome Any screen".
    This switch has no effect on the launcher. In addition, this switch allows you say "Okay Google" on any screen (Browser, Gallery, and so on) regardless of how the launcher installed on the phone (Apex, Trebuchet, Nova, Hola, Go Launcher and etc).
    Trebuchet Launcher is working properly, the problem is not in it. We need to look in a different direction
    I can record a video and post it on YouTube to illustrate the problem. What do you think?
    PS in the firmware YiOS this is not a bug.
  11. #228
    ehehe sorry but I never used this feature (ok google) so I don't know how it works (or should work)
    btw the only difference between screenshot 1 and 2 is the used launcher.
    ok, if you want to make a video maybe I can understand better
    meantime I continue to look for info
    (now I restore a YIOS backup so i can try with this rom)
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (15-07-15)
  13. #229
    umh...I restored a YIOS backup and ok google works exactly like my rom
    I can set only "in google app" like in my first screenshot
  14. #230
    Jul 2015
    se qualcuno vuole il fix per i led dei tasti basta che flasha questo zip senza nessun wipe
    cm12.1_fixlight_buttons.zip
    Thanks. But the buttons do not light up when the smartphone is connected to the charger.
