Pagina 24 di 96 primaprima ... 1422232425263474 ... ultimoultimo
Visualizzazione dei risultati da 231 a 240 su 958
[ROM] [Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #231
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    umh...I restored a YIOS backup and ok google works exactly like my rom
    I can set only "in google app" like in my first screenshot
    In the same menu change language voice search English (US). You will be able to include recognition of any screen.
    I have a method of enabling voice search in other languages, but for testing I think enough English to write less unnecessary information for you.
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    Thanks. But the buttons do not light up when the smartphone is connected to the charger.
    yes becouse is in charger mode with only the central button light
    btw i still working to optimize liblight
  4. #233
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    yes, i have enabled English (US), English (UK) and English (generic) but nothing
  5. #234
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Google Search application should be installed as a system (system/priv-app/Velvet/Velvet.apk).
    In order not to lose time, you can download GAPPS for Android 5.0, which already include a Google search.
    I use it: https://drive.google.com/open?id=0B5...EIwTWN0elhoMlU
    It works on YiOS. I used alone until your firmware.
    Try.
    Ultima modifica di LiveMoto; 15-07-15 alle 15:58
  6. Il seguente Utente ha ringraziato LiveMoto per il post:
    PaoloW8 (15-07-15)
  7. #235
    Google Search application should be installed as a system (system / app /).
    Try.
    ah ok, I installed google search from market
    ok, I will try with your gapps
  8. #236
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Red face
    Please note, I was wrong: Google Search application should be installed as a system (system/priv-app/Velvet/Velvet.apk).
    If you put my GAPPS, it will set this way. This is the right path.
    Ultima modifica di LiveMoto; 15-07-15 alle 19:21
  9. #237
    ok now I do a full wipe, install last YIOS (24062015) and your gapps and I try
  10. #238
    Senior Droid L'avatar di nipponiko
    Ringraziato 120 volte in 95 Posts
    scusate...non per rompere...ma siamo un forum italiano o inglese?
  11. #239
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Quote Originariamente inviato da nipponiko Visualizza il messaggio
    We could hardly understand each other in English. If I write in Italian, it is likely that we do not understand each other.
    English is the international language.
    In any case, we do a common cause, please take this with understanding.
    Have a nice day!
  12. I seguenti 2 Utenti hanno ringraziato LiveMoto per il post:
    luiseteyo (15-07-15),mai62 (15-07-15)
  13. #240
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Hi Paolo.
    I've found the same bug that I've experienced with YIOS in the past.
    - CM11.2, beta2
    - Double tap to wake ENABLED
    Sometimes, after speaking by phone for a while and after finish conversation, screen get locked. Physical buttons works (power, vol up and vol down), but screen does not response at all.
    You have two possibilities here: connect via ADB and reboot the phone or press for several seconds power and force shutdown.
    This bug appear also in YIOS and I think it could be kernel related. I don't know if it was fixed in latest YIOS release because I did't find a changelog.
