Pagina 35 di 93 primaprima ... 2533343536374585 ... ultimoultimo
Visualizzazione dei risultati da 341 a 350 su 929
Blocchi, Riavvii, Lag, Impuntamenti Anomali (Ace Plus)
  1. #341
    Samsung Galaxy Ace Plus
    ma non c'è nessuno che mi può aiutare????
    Sto provando a flashare da console ma con scarsi risultati.. Ma se provo a flashare continuamente solo la recovery (CWM) e metti che prima o poi funziona dici che riesco a entrarci per almeno fare i wipe e magari ripovare a flashare?.. Comunque ecco il log del flash.
    codice:
    longo@longo-imedia-S3712:~/Scrivania$ sudo heimdall flash --verbose --recovery recovery.img
    Heimdall v1.4 RC2
    Copyright (c) 2010-2012, Benjamin Dobell, Glass Echidna
    http://www.glassechidna.com.au/
    This software is provided free of charge. Copying and redistribution is
    encouraged.
    If you appreciate this software and you would like to support future
    development please consider donating:
    http://www.glassechidna.com.au/donate/
    Initialising connection...
    Detecting device...
          Manufacturer: "Sasmsung"
               Product: "MSM7x27"
                length: 18
          device class: 2
                   S/N: 0
               VID:PID: 04E8:685D
             bcdDevice: 0100
       iMan:iProd:iSer: 1:2:0
              nb confs: 1
    interface[0].altsetting[0]: num endpoints = 1
       Class.SubClass.Protocol: 02.02.01
           endpoint[0].address: 82
               max packet size: 0010
              polling interval: 09
    interface[1].altsetting[0]: num endpoints = 2
       Class.SubClass.Protocol: 0A.00.00
           endpoint[0].address: 81
               max packet size: 0200
              polling interval: 00
           endpoint[1].address: 01
    Claiming interface...
    Attempt failed. Detaching driver...
    Claiming interface again...
    Setting up interface...
    Checking if protocol is initialised...
    ERROR: libusb error -7 whilst receiving packet.
    Protocol is not initialised.
    Initialising protocol...
    WARNING: Control transfer #1 failed. Result: -9
    WARNING: Control transfer #2 failed. Result: -9
    WARNING: Control transfer #3 failed. Result: -9
    WARNING: Control transfer #4 failed. Result: -9
    WARNING: Control transfer #5 failed. Result: -9
    WARNING: Control transfer #6 failed. Result: -9
    Protocol initialisation successful.
    Beginning session...
    This device may take up to 2 minutes to respond.
    Please be patient!
    Session begun.
    Downloading device's PIT file...
    PIT file download successful.
    Uploading RECOVERY
    0%File Part #0... Response: 0  0  0  0  0  0  0  0
    11%
    File Part #1... Response: 0  0  0  0  1  0  0  0
    22%
    File Part #2... Response: 0  0  0  0  2  0  0  0
    34%
    File Part #3... Response: 0  0  0  0  3  0  0  0
    45%
    File Part #4... Response: 0  0  0  0  4  0  0  0
    57%
    File Part #5... Response: 0  0  0  0  5  0  0  0
    68%
    File Part #6... Response: 0  0  0  0  6  0  0  0
    80%
    File Part #7... Response: 0  0  0  0  7  0  0  0
    91%
    File Part #8... Response: 0  0  0  0  8  0  0  0
    100%
    ERROR: Failed to unpack received packet.
    ERROR: Failed to confirm end of file transfer sequence!
    ERROR: RECOVERY upload failed!
    Ending session...
    Rebooting device...
    Releasing device interface...
    Re-attaching kernel driver...
  4. #343
    Ringraziato 271 volte in 209 Posts
    Prova lo stesso ad andare in recovery... Sia mai che comunque la carica e il terminale non avvisa (è successo)... Comunque hai fatto i passaggio del mio post sopra?
    ROM: CyanogenMod 11 by DirtyDev
    KERNEL: 3.0.101 Dirty Kernel
    E se ti sono stato d'aiuto non dimenticare il tasto thanks
  5. #344
    Sisi.. Le librerie me le da gia installate e ho creato le regole in udev ma non è cambiato nulla.. E' normale quell'errore di libusb nel log?
  6. #345
    Rifacendo il flash ti da lo stesso errore? Comunque ho paura che visto che stai flashando la CWM tu abbia incrementato il counter e quindi invalidato la garanzia
    Prova ancora con
    codice:
    sudo heimdall flash --pit <path-al-file-pit> --recovery recovery.img
    Non so quanto possa cambiare, ma almeno non se lo deve scaricare dal telefono
  7. #346
    Angry
    Salve,
    al momento dell'acquisto del mio Samsung Ace Plus S-7500 ho notato che vi erano installate alcune applicazioni del gestore telefonico, ben 6!!!
    Supponendo che seguendo il seguente percorso:
    Impostazioni -> Applicazioni -> Seleziona applicazione -> Disinstalla
    avrebbe esaudito la mia volontà di disinstallare suddette applicazioni (ma così non è stato, perché dopo aver selezionato l'app che avrei voluto eliminare, non appariva il tasto "Disinstalla")
    vi chiedo gentilmente di illuminarmi sull' esistenza di un altro metodo efficace per disinstallare queste app(s) di default che ho trovato nel mio smartphone!
    Ringraziando anticipatamente Vi auguro un
    Buon pomeriggio!
    kimay
  8. #347
    Androidiano VIP L'avatar di Giugiu19
    Porto Torres
    Galaxy S5mini (SM-G800F)
    Ringraziato 698 volte in 354 Posts
    Non si possono togliere dovresti mettere una rom no brand trovi le guide nella sezione modding
    Inviato dal mio GT-S7500 usando Androidiani App
    Seguimi su Twitter per informazioni su nuove uscite e aggiornamenti!@Giugiu19
    per chi vuole donare per sostenere lo sviluppo
  9. #348
    Ciao! Vedo che sei appena iscritto Benvenuto!
    Innanzitutto, come nuovo utente dovresti fare prima 3 passaggi:
    - Dare il benvenuto alla comunità e presentarti qui (apri una nuova discussione)
    - Leggere il regolamento del forum (e memorizzarne le regole)
    - Leggere il regolamento di sezione (idem come sopra)
    Ora passiamo al tuo problema: quelle applicazioni che odi tanto non le puoi disinstallare perché risiedono in una zona di memoria protetta, pertanto nelle condizioni in cui è ora il tuo cellulare (settato dalla fabbrica non pensare male ) non hai le autorizzazioni necessarie per compiere l'azione che vorresti (disinstallare app di sistema)
    Per fare ciò dovresti ottenere i permessi di root e invalidare così la tua garanzia (processo reversibile in ogni caso ) oppure, senza invalidare la garanzia, puoi sbrandizzare il telefono con un firmware stock NO-Brand QUI puoi trovare tutte le info del caso (è un topic che puoi trovare tranquillamente nella prima pagina della sezione quindi anche se perdi il link non dovresti aver problemi a ritrovarlo )
  10. #349
    Nulla.. Non cambia niente.. Solito log di errore.
    Comunque ogni procedura l'ho provata minimo una decina di volte prima di postare ancora..
    In ogni caso non ho bisogno della garanzia che tanto lò'ho persa e non posso usufruirne.. Mi interessa resuscitare sto telefono!!
  11. #350
    Porta in assistenza, non so quanto te lo tengono e ti prenderanno qualcosa 25-50 euro da quanto hanno detto in altre discussioni... Mi dispiace non esserti stato d'aiuto
