Pagina 13 di 42 primaprima ... 3111213141523 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 418
[ROM] [ICS] [4.0.4] JellyBeanRom v.7 [7500 e 7510]
  1. #121
    Apr 2011
    2012/09/04 09:39:27,-778mA,98%,4.055V
    2012/09/04 09:39:31,-905mA,98%,4.055V
    2012/09/04 09:39:42,-707mA,98%,4.055V
    2012/09/04 09:39:43,-720mA,98%,4.055V
    2012/09/04 09:40:43,-593mA,98%,4.068V
    2012/09/04 09:41:43,-670mA,98%,4.071V
    2012/09/04 09:48:04,-158mA,98%,4.12V
    2012/09/04 09:49:52,-153mA,98%,4.128V
    2012/09/04 10:19:45,-140mA,98%,4.132V
    2012/09/04 10:20:55,-141mA,98%,4.131V
    2012/09/04 10:22:39,-155mA,98%,4.131V
    2012/09/04 10:23:39,-781mA,97%,4.065V
    2012/09/04 10:24:39,-675mA,97%,4.065V
    2012/09/04 10:25:40,-162mA,97%,4.117V
    2012/09/04 10:27:10,-141mA,97%,4.12V
    2012/09/04 10:30:14,-133mA,97%,4.124V
    2012/09/04 10:32:19,-140mA,97%,4.123V
    2012/09/04 10:34:24,-136mA,97%,4.123V
    2012/09/04 10:36:30,-95mA,97%,4.122V
    2012/09/04 10:38:10,-143mA,97%,4.125V
    2012/09/04 10:40:40,-147mA,97%,4.124V
    2012/09/04 10:42:45,-160mA,97%,4.122V
    2012/09/04 10:46:55,-145mA,97%,4.122V
    2012/09/04 10:49:00,-160mA,97%,4.124V
    2012/09/04 10:51:05,-131mA,97%,4.126V
    2012/09/04 10:53:10,-147mA,97%,4.126V
    2012/09/04 10:55:15,-163mA,97%,4.125V
    2012/09/04 10:57:20,-132mA,97%,4.127V
    2012/09/04 10:59:25,-175mA,97%,4.121V
    2012/09/04 11:01:30,-158mA,97%,4.125V
    2012/09/04 11:03:35,-152mA,97%,4.126V
    2012/09/04 11:05:41,-146mA,97%,4.127V
    2012/09/04 11:06:06,-658mA,97%,4.127V
    2012/09/04 11:07:06,-638mA,97%,4.059V
    2012/09/04 11:07:27,-632mA,97%,4.066V
    Questo è il mio log, praticamente in stand by ovviamente...
    Ultima modifica di netprince; 04-09-12 alle 12:13
    Sony Z1 - STOCK
    Samsung Galaxy S - Tiramisù SLIM 2.0 FINAL
    Galaxy Tab 10.1 - STOCK
    Galaxy Tab 2 7.0 - Cyano 10.1
    Apr 2011
    2012/09/04 11:08:27,-658mA,97%,4.018V
    2012/09/04 11:09:27,-730mA,96%,4.052V
    2012/09/04 11:10:27,-787mA,96%,4.054V
    2012/09/04 11:12:14,-142mA,96%,4.112V
    2012/09/04 11:14:19,-133mA,96%,4.114V
    2012/09/04 11:16:24,-193mA,96%,4.113V
    2012/09/04 11:18:29,-136mA,96%,4.117V
    2012/09/04 11:19:53,-129mA,96%,4.116V
    2012/09/04 11:22:39,-160mA,96%,4.115V
    2012/09/04 11:24:44,-148mA,96%,4.115V
    2012/09/04 11:25:58,-169mA,96%,4.112V
    2012/09/04 11:28:54,-134mA,96%,4.116V
    2012/09/04 11:30:01,-149mA,96%,4.114V
    2012/09/04 11:33:04,-155mA,96%,4.115V
    2012/09/04 11:35:10,-144mA,96%,4.116V
    2012/09/04 11:37:15,-142mA,96%,4.116V
    2012/09/04 11:38:18,-185mA,96%,4.112V
    2012/09/04 11:39:20,-145mA,96%,4.116V
    2012/09/04 11:40:27,-150mA,96%,4.114V
    2012/09/04 11:43:30,-165mA,96%,4.115V
    2012/09/04 11:45:35,-130mA,96%,4.117V
    2012/09/04 11:47:40,-146mA,96%,4.117V
    2012/09/04 11:49:45,-135mA,96%,4.116V
    2012/09/04 11:51:50,-135mA,96%,4.116V
    2012/09/04 11:53:55,-143mA,96%,4.118V
    2012/09/04 11:56:00,-132mA,96%,4.117V
    2012/09/04 11:58:05,-141mA,96%,4.116V
    2012/09/04 12:00:10,-158mA,96%,4.115V
    2012/09/04 12:02:15,-173mA,96%,4.115V
    2012/09/04 12:04:20,-150mA,96%,4.115V
    2012/09/04 12:06:25,-160mA,96%,4.113V
    2012/09/04 12:08:30,-130mA,96%,4.116V
    2012/09/04 12:10:35,-146mA,96%,4.12V
    2012/09/04 12:12:40,-164mA,96%,4.115V
    2012/09/04 12:14:46,-137mA,96%,4.115V
    2012/09/04 12:16:51,-138mA,96%,4.098V
    2012/09/04 12:18:56,-161mA,96%,4.114V
    2012/09/04 12:21:01,-140mA,96%,4.115V
    2012/09/04 12:22:24,-155mA,96%,4.115V
    2012/09/04 12:24:29,-145mA,96%,4.117V
    2012/09/04 12:27:16,-135mA,96%,4.118V
    2012/09/04 12:29:21,-135mA,96%,4.117V
    2012/09/04 12:31:19,-228mA,96%,4.107V
    2012/09/04 12:33:31,-150mA,96%,4.115V
    2012/09/04 12:34:49,-148mA,96%,4.116V
    2012/09/04 12:37:41,-128mA,96%,4.116V
    2012/09/04 12:39:46,-136mA,96%,4.117V
    2012/09/04 12:41:51,-146mA,96%,4.117V
    2012/09/04 12:43:56,-307mA,96%,4.114V
    2012/09/04 12:46:02,-143mA,96%,4.116V
    2012/09/04 12:48:06,-148mA,96%,4.116V
    2012/09/04 12:49:19,-142mA,96%,4.115V
    2012/09/04 12:52:13,-156mA,96%,4.114V
    Sony Z1 - STOCK
  4. #123
    Androidiani Power User
    Dec 2009
    Rimini
    Mi pare che vai bene in stand by se eri sotto rete wifi attiva
    Se hai un 7500 devi anche provare sotto rete 3g dove i consumi possono salire anche molto se non è gestito bene dal sistema
  5. #124
    Apr 2011
    Ma a me il problema si pone principalmente in modalità aereo paradossalmente! Palesemente aumentato rispetto al passato dove stava giorni in modalità aereo senza problemi. Ora non mi dura neanche 3 giorni....
    Sony Z1 - STOCK
  6. #125
    com'è che dici che questa è la migliore ROM ICS fin'ora uscita?
    ho letto qui nei post che molti hanno avuto problemi con i consumi per via del kernel modificato...sono stati sitemati?
    EDIT sul sito linkato in prima pagina parlano già di v6 uscita ieri installo quella?
    io ho HC con root e recovery ma sul sito dicono di installare prima l'aggiornamento a ICS e poi la rom confermate?
    Ultima modifica di BkSwan; 04-09-12 alle 18:47
  7. #126
    Dec 2009
    Rimini
    Quote Originariamente inviato da BkSwan Visualizza il messaggio
    la questione dei consumi è tutta da valutare ,e va' considerato caso per caso
    si deve anche distinguere tra 7500 e 7510 per ovvi motivi
    bisogna anche essere precisi nel dire cosa si intende per consumi elevati ,in quali condizioni e con quale termine di confronto....
    io per esempio ho il 7510 e non ho riscontrato nessun problema particolare nei consumi fino alla 5.1
    la 6.0 non l'ho installata quindi non posso dire niente...
    va detto che lo stesso autore della rom ha problemi di consumi(7500) di cui non conosce ancora la causa
    mentre altri utenti dicono di non avere nessun problema di consumi....
    il consumo anomalo si manifesta normalmente in due modi
    in stand by con consumi di oltre il 2% l'ora mentre dovrebbe state dentro lo 0.5% massimo
    oppure nell'utilizzo si nota un certo surriscaldamento che si pensa possa incidere sul maggiore consumo
    penso che comunque questo problema (per chi ce l'ha) riguardi piu il 7500 che il 7510
  8. #127
    ok io ho il 7510 come il tuo, che faccio installo non frills e abbsso la freq min a 150 Mhz?
    per quanto riguarda l'update da HC a ICS sono costretto a farlo o vado diretto col flash?
    e scusa le domande (mi bastano anche risposte super dirette xD), ma cosa è la Delvik cache? è presente nel menu di Titanium Backup la scelta della pulizia o dellintegrazione e vorrei sape che fare, o basta fare il wipe factory reset della recovery custom(CWM)?
  9. #128
    Dec 2009
    Rimini
    se hai gia root assolutamente no
    su titanium è assolutamente importante lasciar perdere tutte quelle funzioni che non conosci
    per il resto non si sono risposte flasch che si possono dare
    a questo proposito ti devi solo attenete a cio che è scritto in prima pagina sulle modalita di installazione della rom
    per gli approfondimenti leggi il materiale in evidenza dove troverai tutte le spiegazioni a cominciare da qui
    https://www.androidiani.com/forum/sa...are-danni.html
  10. #129
    ok ho letto tutto mo parto con l'installazione della 6.0 che dovrebbe avere alcuni miglioramenti e vi faccio sapere come va
  11. #130
    o.t
    ho installato face unlock, lo sviluppatore di questa rom lo ha messo come addon da flashare via recovery...
    che figata!!
    fine o.t.
