Pagina 14 di 42 primaprima ... 4121314151624 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 418
[ROM] [ICS] [4.0.4] JellyBeanRom v.7 [7500 e 7510]
  1. #131
    Apr 2011
    Durante la notte ho rifatto il log, modalità aereo, e oggi non ho avuto sorprese. Bah, inizio a non capire più, non vorrei si fosse "bevuto" il conto batteria... e che poi abbia solo avuto strascichi. Vi riallego il mio log di stanotte:
    2012/09/04 19:15:49,-903mA,91%,4.009V
    2012/09/04 19:16:36,-703mA,91%,4.006V
    2012/09/04 19:17:36,-660mA,90%,4.003V
    2012/09/04 19:18:36,-695mA,90%,3.999V
    2012/09/04 19:19:58,-169mA,90%,4.061V
    2012/09/04 19:49:50,-135mA,90%,4.071V
    2012/09/04 20:07:36,-163mA,90%,4.069V
    2012/09/04 20:19:22,-150mA,90%,4.069V
    2012/09/04 20:49:51,-139mA,90%,4.07V
    2012/09/04 21:19:51,-163mA,90%,4.071V
    2012/09/04 21:49:52,-290mA,90%,4.073V
    2012/09/04 22:19:52,-160mA,90%,4.07V
    2012/09/04 22:49:52,-158mA,90%,4.07V
    2012/09/04 23:19:53,-141mA,90%,4.07V
    2012/09/04 23:49:53,-149mA,90%,4.072V
    2012/09/05 00:19:53,-148mA,90%,4.071V
    2012/09/05 00:49:53,-163mA,90%,4.07V
    2012/09/05 00:49:54,-124mA,90%,4.07V
    2012/09/05 01:19:54,-129mA,89%,4.074V
    2012/09/05 01:49:54,-163mA,89%,4.07V
    2012/09/05 02:19:54,-159mA,89%,4.07V
    2012/09/05 02:49:54,-145mA,89%,4.072V
    2012/09/05 02:49:55,-137mA,89%,4.071V
    2012/09/05 03:19:55,-143mA,89%,4.071V
    2012/09/05 03:49:55,-163mA,89%,4.07V
    2012/09/05 04:19:56,-133mA,89%,4.072V
    2012/09/05 04:49:56,-159mA,89%,4.069V
    2012/09/05 05:19:56,-133mA,89%,4.072V
    2012/09/05 05:19:56,-282mA,89%,4.072V
    2012/09/05 05:49:56,-146mA,89%,4.069V
    2012/09/05 06:19:56,-149mA,89%,4.072V
    2012/09/05 06:49:57,-145mA,89%,4.07V
    2012/09/05 07:19:57,-150mA,89%,4.067V
    2012/09/05 07:19:58,-108mA,89%,4.069V
    2012/09/05 07:49:57,-142mA,89%,4.072V
    2012/09/05 08:19:58,-139mA,89%,4.067V
    2012/09/05 08:24:31,-160mA,89%,4.072V
    2012/09/05 08:50:06,-141mA,89%,4.069V
    2012/09/05 09:19:59,-148mA,89%,4.068V
    2012/09/05 09:49:59,-140mA,89%,4.07V
    2012/09/05 09:50:00,-292mA,89%,4.07V
    2012/09/05 10:08:41,-156mA,89%,4.069V
    Sony Z1 - STOCK
    Samsung Galaxy S - Tiramisù SLIM 2.0 FINAL
    Galaxy Tab 10.1 - STOCK
    Galaxy Tab 2 7.0 - Cyano 10.1
    Androidiano L'avatar di talaban
    Muggiò,Genova,Pasturo,Cuneo
    Lumia 925, Samsung s2 mini
    scusate, ma ho seguito tutta la guida, solo che quando faccio il riavvio il tab si blocca alla schermata " samsung galxy tab 10.1 " e da li non si schioda.
    Ho già provato diverse volte a rifarlo, qualcuno ha qualche dritta?
  4. #133
    Androidiani Power User
    Dec 2009
    Rimini
    Sta di fatto che in stand by hai una situazione ottimale e non poteva essere diversamente. dato che nel precedente rilievo andavi già bene e non eri in modalità aereo, la situazione non poteva che migliorare......è la prova che il tuo sistema è a posto
    Manca un test sotto rete 3g in stand by che puo essere sicuramente la condizione più dispendiosa per la batteria se qualcosa non va
    Ultima modifica di linux33it; 05-09-12 alle 16:27
  5. #134
    Dec 2009
    Rimini
    Quote Originariamente inviato da talaban Visualizza il messaggio
    Devi anche dire che modello hai di tab, il nome esatto della rom che stai installando e la recovery che usi
  6. #135
    Allora ho un galaxy tab 10.1 gt-p7500, installata la cwm 5.5.0.4 e sto tentando di installare la rom che nel topic di xda è sotto il nome: GT-P7500 http://www.mediafire.com/?4lbe9q9tda6ncs8
    Ho ancora su honeycomb originale, le uniche modifiche fatte sono state quelle di ottenere i permessi root e installare la recovery, così come consigliato nella guida
  7. #136
    Dec 2009
    Rimini
    Allora ho un galaxy tab 10.1 gt-p7500, installata la cwm 5.5.0.4 e sto tentando di installare la rom che nel topic di xda è sotto il nome: GT-P7500 JellyBeanRomICS_deleted.7z
    A meno che non ti sei sbagliato a scrivere quella citata nel tuo link non è una Rom, quel file non è installabile quindi la recovery non dovrebbe nemmeno accettarlo
    controlla meglio il link che hai scritto e verifica
    In ogni caso la rom è questa
    https://hotfile.com/dl/170490078/3aa...P7500.zip.html
  8. #137
    Apr 2011
    PEr ora in effetti il problema non mi pone. Da quando ho messo su il kernel consigliato (sarà un caso) vedo un consumo ottimale. L'ultima volta è partito bene per i primi 20% per poi precipitare in 48 ore a zero, con un utilizzo come quello che vi ho postato. C'è da dire che questa volta il tab si è completamente scaricato spegnendosi e facendolo ricaricare al 100%. Anche questo potrebbe incidere ovviamente nella visualizzazione della batteria.....
    Sony Z1 - STOCK
  9. #138
    per chi proveniva dalla cm9, avevete installato la stock samsung prima di installare questa rom (come consigliato su xda)?
    che versione mi consigliate tra le varie proposte per p7500?
  10. #139
    Dec 2009
    Rimini
    Quote Originariamente inviato da calrino Visualizza il messaggio
    e perchè mai si dovrebbe installare il firmware se si viene dalla cm9? forse si riferiscono a chi ha problemi precisi... altrimenti non si spiega....
  11. #140
    ma io sono l'unico ad aver problemi con il flash player ??? sul browser mi compare un mattocino lego con i punti interrogativi .....
    Ho provato a reinstallare il flash dagli apk forniti ma niente da fare . Idee ?
