Pagina 1 di 41 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 409
[16.GENNAIO.2012][ROM/KERNEL][GSM] ♫ OVERCOME 7 SERIES v4.1.0 ♫
    Senior Droid L'avatar di anassagora
    Ringraziato 74 volte in 53 Posts
    [GUIDA][16.GENNAIO.2012][ROM/KERNEL][GSM] ♫ OVERCOME 7 SERIES v4.1.0 ♫
    ROM by team overcome 7 series v4.1.0 basata su android 2.3.6
    CARATTERISTICHE
    rom features
    p1000xwjq8 base rom - android 2.3.6
    overcome kernel 4.0.0 included
    no modem is included - due to a variety of personal preference i decided to leave that a la carte
    fully deodexed
    fully zipaligned
    rooted with busybox installed
    reboot/recovery/download options added to the power menu
    accurate battery mod
    blur removed across system (i.e. Behind power option menu) - significantly improves performance
    power off confirmation disabled
    screen off animation enabled
    overscroll glow effect enabled
    screen on animation enabled
    added appwidgetpicker
    csc set to xeu
    ads blocked
    updated market to 3.4.4
    updated maps to 6.0.3
    flash player removed due to compatibility issue - install from market and you'll be all set.
    Updated gmail to 2.3.5.2
    updated youtube to 2.2.16
    updated samsungapps to 2.6.046
    updated streetview to 1.6.0.6
    updated thinkfree office suite
    removed startup/shutdown sounds
    cool boot animation
    a2dp bluetooth connection fix integrated
    sip calling enabled over 3g and wifi
    fugutweaks integrated
    browser mods (enabled "default zoom" in settings, added "user agent" in settings, set plugins to "on demand" by default)
    kernel features
    support rfs/ext2/ext3/ext4
    oc/uv with these steps: 1.6ghz, 1.5ghz, 1.4ghz, 1.3ghz, 1.2ghz, 1ghz, 800mhz, 600mhz, 400mhz, 200mhz, 100mhz
    replaced kernel jhash2 with jhash3
    adjusted kernel hz value to improve smoothness
    optimized lowmemorykiller values
    optimized compiler flags
    voodoo sound v10 (courtesy of supercurio)
    voodoo lagfix (courtesy of supercurio)
    overcome cwm recovery v5.1.2.6 (custom built clockworkmod v5.0.2.6)
    full support of internal/external sd cards in recovery
    v(r) scheduler added and set as default
    kernel tweaks to vm and scheduler for better performance
    built in cifs/tun/slowwork support
    touchscreen undervolted (courtesy koxudaxi)
    ram undervolted
    stochastic fair blue (sfb) network scheduler
    autogroup scheduler
    asynchronous i/o enabled (aio)
    backlight notifications (thanks to neldar for the mod and koxudaxi for the patch)
    TROVATE I NUOVI LINK IN CALCE AL POST
    FILE DA SCARICARE:
    VERSION 5 of the Gingerbread-based stock-safe file (GB-stock-safe_v5.zip)
    Overcome Kernel 4.0.0 ODIN/TAR Version (Overcome_Kernel_v4.0.0.tar)
    Overcome 7 Series ROM 4.1.0 Wipe Edition (Overcome_7_Series_v4.1.0_Wipe.zip)
    RACCOMANDAZIONI
    Assicurarsi di avere i driver appropriati installati. A tal scopo è consigliabile avere il programma Samsung Kies installato ed aver collegato il nostro tab almeno una volta per essere sicuri che tutto funzioni correttamente.
    Eseguendo tale guida perderete tutte le applicazioni e tutti i dati. In alternative poteet farvi un back-up tramite programmi come Titanium backup.
    ACCERTARSI CHE IL TABLET SIA CARICO
    PREMESSA: LA GUIDA VA SEGUITA DAL PRIMO ALL'ULTIMO PUNTO IN UNICA TIRATA.
    Solo così si evitano la maggior parte di inconvenienti che possono verificarsi.
    VALE A DIRE BISOGNA SEMPRE PASSARE, COME IMPONE LA GUIDA, DA 2.3.6 STOCK.
    GUIDA PER L'INSTALLAZIONE
    POICHE' E' SEMPRE CONSIGLIABILE L'INSTALLAZIONE IN VERSIONE WIPE, AL FINE DI EVITARE PROBLEMI DI OGNI GENERE, LA GUIDA SI RIFERISCE PROPRIO A QUESTO TIPO DI INSTALLAZIONE.
    PRIMA FASE: RIPRISTINO DEL GALAXY TAB A GINGERBREAD 2.3.3 VERSIONE STOCK
    1. estrarre il file zip GB-stock-safe_v5.zip in una cartella a scelta.
    2. Mettere il tablet in download mode. Per far ciò bisogna spegenre il tablet. Una volta spento premiamo contemporaneamente i tasti POWER (quello per accendere il tab) e il tasto per abbassare il volume fino a quando non compare una immagine come questa:
    3. Andare nella cartella dove abbiamo estratto il file zip GB-Stock-Safe-v5.zip, aprire la cartella Odin3_v1.7 e lanciare Odin3 v1.7.exe ; Adesso colleghiamo il tablet al pc tramite il cavo USB. Dovremmo avere il riquadro che indica la porta com giallo
    4. cliccare sul pulsante PIT e selezionare tramite l'apposita finestra che si apre il file "gt-p1000_mr.pit" presente in quella cartella dove è stato estratto il tutto;
    Successivamente premere sul pulsante "PDA" e selezionare il file "GB_Stock_Safe_v5.tar";
    Dopo premere il pulsante "PHONE" e selezionare (se si sta usando un GT-P1000 Tab GSM (Asia / Europa / Medio Oriente / Oceania / Africa, resto del mondo, ecc), nella cartella "Modem JPZ" il file "modem.bin" .
    5. Cliccare sul tasto "START" E ATTENDEREO CON PAZIENZA che Odin porti a termine tutto il processo. Ci impiegherà un paio di minuti e quando avrà terminato ci sarà in Odin un stringa verde con la scritta "PASS". Non toccare nulla e aspettare che il tab si riavvii.
    Adesso il tab si accenderà con la JQ1 di Gingerbread, immettere il codice PIN (se la sim è protretta dal codice PIN) e portare a termine premendo "NEXT, senza preoccuparsene molto poichè dovrà eseguirsi un altro flash, gli step di cunfigurazione. A questo punto, è possibile scollegare il tablet e chiudere Odin.
    7. Una volta giunti nella home, recarsi in Impostazioni/ wirless e rete/ impostazioni USB/ e selezionare Archiviazione di massa; Collegare il tablet al pc, aprirlo come disco rimovibile e copiare il file zip Overcome_7_Series_v4.1.0_Wipe.zip, precedentemente scaricato, nella root.
    SECONDA FASE: CONVERSIONE DEL FILESYSTEM
    8. Spegnere il tablet e metterlo in download mode. Per far ciò, una volta spento il tablet, premiamo contemporaneamente i tasti POWER (quello per accendere il tab) e il tasto per abbassare il volume fino a quando non compare una immagine come questa:
    9. Avviare nuovamnte Odin (Andare nella cartella dove abbiamo estratto il file zip GB-Stock-Safe-v5.zip, aprire la cartella Odin3_v1.7 e lanciare Odin3 v1.7.exe ; Adesso colleghiamo il tablet al pc tramite il cavo USB. Dovremmo avere il riquadro che indica la porta com giallo); Cliccare il pulsante "PDA" e selezionare il file, precedentemente scaricato, Overcome_Kernel_v4.0.0.tar; Premere il pulsante "START". Questa volta si tratterà di un flash piuttosto breve ed il tablet si riavvierà da solo.
    Durante il processo, una voce robotica indica lo stato del processo di conversione del filesystem RFS al più robusto filesystem ext4.
    NON TOCCARE E FARE NULLA, lasciare che tutto finisca da solo. Si tratta di aspettare qualche minuto anche in questo caso. Al termine avremo il tab riavviato.
    TERZA FASE: FLASH DELLA ROM OVERCOME
    10. Per installare la rom del team Overcome, è necessario portare il tablet in "Recovery mode". Per far ciò, spegnere il Tablet ed una volta spento, premere contemporaneamente il tasto "power" (quello per accendere il tablet) e il tasto per mettere aumentare il volume fino a quando compare il logo "Galaxy TAB".
    11. Entrati nella recovery, bisogna sapere che si naviga attraverso i tasti del volume e si seleziona tramite il pulsante power. Portarsi, quindi, in "install menu" e poi in “choose zip from internal sdcard”. Selezionare il file, precedetemente copiato sul tablet, Overcome_7_Series_v4.1.0_Wipe.zip. Confermare la scelta ed attendere che tutto finisca da se. Anche qui ci vorranno un paio di minuti.
    12. portarsi in “+++++Go Back+++++”, confermare per tornare nella home della "recovery mode" e poter selezionare “reboot menu”, poi in “reboot system” e confermare. Il tablet si riavvierà normalmente e uscirete dalla recovery.
    13. BENVENUTI NELLA OVERCOME EXPERIENCE!!!
    NON MI ASSUMO ALCUNA RESPONSABILITA'. LA GUIDA VA SEGUITA A PROPRIO RISCHIO E PERICOLO E SOTTO LA PROPRIA RESPONSABILITA'.
    LA MIA E' SOLTANTO UNA TRADUZIONE DI QUELLA PRESENTE SUL SITO UFFICIALE DELLA OVERCOME ADATTATA SECONDO LA MIA ESPERIENZA.
    ----------> Aggiunto dal Moderatore di Sezione<----------
    Ho riuppato i file perchè non vanno piu i collegamenti......
    Sono file .rar autoestraenti, trovate tutto cio che serve comprese le istruzioni...
    Spero di aver fatto cosa gradita
    Si raccomanda di scaricare tutti e 4 i file Zip.... altrimenti non potrete usarli.
    Noto che molta gente ha scaricato solo i file 1 sia di un tipo che dell'altro.... ma cosi sono inutilizzabili!
    GB_Stock_Safe_v5.part1.exe
    GB_Stock_Safe_v5.part2.rar
    http://www.mediafire.com/file/rf6y6n...come.part1.exe
    http://www.mediafire.com/file/3xnx4l...come.part2.rar
    E' sufficiente scaricare i file e inserirli insieme in una cartella dove poi estrarli.....
    Si uniranno in unico file..... da soli!
    Ho dovuto upparli divisi in quanto il sito non permette file superiori ai 200 mb.....
    DROPBOX ORSOGE CON I FILES NECESSARI
    QUI
    Ultima modifica di ZiCkY; 28-02-13 alle 12:45
  2. I seguenti 21 Utenti hanno ringraziato anassagora per il post:
    Albert0 (30-03-13),alessandroprato (18-04-13),andrealenzi (27-03-13),antonik62 (04-09-12),azazelxu (30-07-12),flip971 (27-05-13),galaxy77 (16-11-12),kikocuriosi (15-02-16),marcoted (21-05-12),marfas51 (10-04-12),mauroby1974 (20-06-13),miki10 (27-05-12),mousequarzo (23-08-13),neoxyty (24-05-13),radumacovei (15-03-13),ricsco (29-03-19),riodda77 (11-11-12),sincera73 (09-05-13),skater91 (11-03-12),VTB_Sergio (12-03-12),xAlexbestx (26-03-13)
    Meravigliosa guida, finalmente una guida che fa capire cosa succede durante tutto il processo.
    Paolo
    Inviato dal mio GT-P1000 usando Androidiani App
  5. #3
    Senior Droid L'avatar di balordo80
    Oct 2010
    Ringraziato 44 volte in 32 Posts
    scusa sul sito della OVERCOME c'è un file per il tema stock, io l'ho installato, ma adesso vorrei ritornare al tema Overcome originale come posso fare senza cancellare tutto (Applicazione e altri dati?????
    Basta flashare la No Wipe????
    Grazie in anticipo
    *Samsung Galaxy SIII GT-I9300:
    ROM Fantasy HD by Ragz
    *Samsung Galaxy TAB 7 P1000
    [JB ROM] Touchwiz Rom 4.2.2
    Kernel e Modem Stock
    Se vuoi ringraziarmi usa il tasto
  6. #4
    Dovrebbe bastare nel tuo caso.
  7. #5
    Baby Droid L'avatar di corracai
    bellissima guida complimenti.... e grazie.
  8. #6
    Grazie mille per i complimenti!
  9. Il seguente Utente ha ringraziato anassagora per il post:
  10. #7
    Redmi Note 4 Global 4/64
    Ringraziato 86 volte in 72 Posts
    Ciao anassagora e grazie per la guida.
    Quello che volevo chiederti è questo: ho attualmente la 2.3.6 cromed e rooted ma senza cwm. Da quello che ho capito, mettendo la stock 2.3.3 e poi il kernel 4.0 avrei la cwm necessaria per aggiornare poi la rom alla overcome.
    In pratica nel mio caso basta solo seguire la guida giusto ? E per quanto concerne il bootloader ?
    Ma con i consumi di batteria come siamo messi, sono allineati alla 2.3.6 o peggiori ?
    Ultima modifica di intelinside; 31-01-12 alle 14:31
  11. #8
    lupoalba
    Quote Originariamente inviato da intelinside Visualizza il messaggio
    In configurazione stock2.3.6 e kernel overcome 4 i consumi sono un pelino piu alti che con il kernel stock ma migliori della stock 2.3.3.
    Le prestazioni sono un pelino superiori alla stock 2.3.6, come anche la fluidita' e la possibilita' di over under volt.
  12. #9
    si se segui la guida dal primo all'ultimo punto ti ritrovi la Rom overcome con il fily sistem più robusto e recovery. Riguardo ai bootloader cosa vuoi sapere?
    i consumi sono in linea con la 2.3.6 ma qui si ha una maggiore reattività.
  13. #10
    Grazie per avermi risposto.
    Ti chiedo del bootloader in quanto quando vado in recovery (quella della stock) il device mi da un errore di checksum (E:MBR Checksum Error, internal MMC checksum verify failed).
    Quote Originariamente inviato da anassagora Visualizza il messaggio
