Pagina 10 di 29 primaprima ... 8910111220 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 281
Onda Andy Rom Cyanogenmod
  1. #91
    Androidiano L'avatar di ssdavid
    onda andy n401
    Quote Originariamente inviato da gokur20 Visualizza il messaggio
    il file ACPUCTL.c non c'è, piuttosto ci sono due file acpuclock.c, uno in /arch/arm/match-msm:
    codice:
    /* 7x27 normal with GSM capable modem */
    static struct clkctl_acpu_speed pll0_245_pll1_960_pll2_1200[] = {
    	{ 0, 19200, ACPU_PLL_TCXO, 0, 0, 19200, 0, 0, 30720 },
    	{ 0, 120000, ACPU_PLL_1, 1, 7,  60000, 1, 3,  61440 },
    	{ 1, 122880, ACPU_PLL_0, 4, 1,  61440, 1, 3,  61440 },
    	{ 0, 200000, ACPU_PLL_2, 2, 5,  66667, 2, 4,  61440 },
    	{ 1, 245760, ACPU_PLL_0, 4, 0, 122880, 1, 4,  61440 },
    	{ 1, 320000, ACPU_PLL_1, 1, 2, 160000, 1, 5, 122880 },
    	{ 0, 400000, ACPU_PLL_2, 2, 2, 133333, 2, 5, 122880 },
    	{ 1, 480000, ACPU_PLL_1, 1, 1, 160000, 2, 6, 122880 },
    	{ 1, 600000, ACPU_PLL_2, 2, 1, 200000, 2, 7, 122880 },
    	{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, {0, 0, 0}, {0, 0, 0} }
    /* 7x27 normal with CDMA-only modem */
    static struct clkctl_acpu_speed pll0_196_pll1_960_pll2_1200[] = {
    	{ 0, 19200, ACPU_PLL_TCXO, 0, 0, 19200, 0, 0, 24576 },
    	{ 1,  98304, ACPU_PLL_0, 4, 1,  98304, 0, 3,  49152 },
    	{ 0, 120000, ACPU_PLL_1, 1, 7,  60000, 1, 3,  49152 },
    	{ 1, 196608, ACPU_PLL_0, 4, 0,  65536, 2, 4,  98304 },
    	{ 0, 200000, ACPU_PLL_2, 2, 5,  66667, 2, 4,  98304 },
    	{ 1, 320000, ACPU_PLL_1, 1, 2, 160000, 1, 5, 120000 },
    	{ 0, 400000, ACPU_PLL_2, 2, 2, 133333, 2, 5, 120000 },
    	{ 1, 480000, ACPU_PLL_1, 1, 1, 160000, 2, 6, 120000 },
    	{ 1, 600000, ACPU_PLL_2, 2, 1, 200000, 2, 7, 120000 },
    e l'altro in /arch/arm/match-fsm:
    codice:
    /* 7x27 normal with GSM capable modem - PLL0 and PLL1 swapped and pll2 @ 800 */
    static struct clkctl_acpu_speed pll0_960_pll1_245_pll2_800[] = {
    	{ 0, 120000, ACPU_PLL_0, 4, 7,  60000, 1, 3,  61440 },
    	{ 1, 122880, ACPU_PLL_1, 1, 1,  61440, 1, 3,  61440 },
    	{ 0, 200000, ACPU_PLL_2, 2, 3,  66667, 2, 4,  61440 },
    	{ 1, 245760, ACPU_PLL_1, 1, 0, 122880, 1, 4,  61440 },
    	{ 1, 320000, ACPU_PLL_0, 4, 2, 160000, 1, 5, 122880 },
    	{ 0, 400000, ACPU_PLL_2, 2, 1, 133333, 2, 5, 122880 },
    	{ 1, 480000, ACPU_PLL_0, 4, 1, 160000, 2, 6, 122880 },
    	{ 1, 800000, ACPU_PLL_2, 2, 0, 200000, 3, 7, 122880 },
    /* 7x27 normal with CDMA-only modem - PLL0 and PLL1 swapped and pll2 @ 800 */
    static struct clkctl_acpu_speed pll0_960_pll1_196_pll2_800[] = {
    	{ 1,  98304, ACPU_PLL_1, 1, 1,  98304, 0, 3,  49152 },
    	{ 0, 120000, ACPU_PLL_0, 4, 7,  60000, 1, 3,  49152 },
    	{ 1, 196608, ACPU_PLL_1, 1, 0,  65536, 2, 4,  98304 },
    	{ 0, 200000, ACPU_PLL_2, 2, 3,  66667, 2, 4,  98304 },
    	{ 1, 320000, ACPU_PLL_0, 4, 2, 160000, 1, 5, 120000 },
    	{ 0, 400000, ACPU_PLL_2, 2, 1, 133333, 2, 5, 120000 },
    	{ 1, 480000, ACPU_PLL_0, 4, 1, 160000, 2, 6, 120000 },
    	{ 1, 800000, ACPU_PLL_2, 2, 0, 200000, 3, 7, 120000 },
    credo sia il primo, anche perchè il secondo dovrebbe già avere il supporto a 800Mhz.
    Supponendo che sia il primo, cerchiamo di capire cosa aggiungere.
    si è il primo quello che si trova in mach-msm purtroppo non mi ricordo tutto a memoria si deve aggiungere tipo questa riga
    { 1, 768000, ACPU_PLL_2, 2, 0, 200000, 3, 7, 120000 },
    piu giu c'è una riga remmata tipo
    initial 768
    poi fare la modifica nel menuconfig che ti avevo detto prima
    adesso un aiuto da qualcuno piu esperto era una manna dal cielo
    cmq anche il primo ha il supporto a 800
    Androidiano L'avatar di gokur20
    Si ma questa modifica è un di più.
    Senza questa modifica, compilando il kernel con il .config estratto, make menuconfig, e reimpastando il boot.img il device non funziona; quindi se non risolviamo prima questo problema, è inutile cercare di modificare la frequenza.
    Nel frattempo, potremmo provare a fare il porting della Cyano del Cosmo duo.
    Io nn riesco a trovare la cyano del Cosmo duo, solo l'update del Cosmo, hai qualche link?
    Ultima modifica di gokur20; 21-02-13 alle 18:39
  4. #93
    onda andy n401
    se vuoi fare l'overclock del cel questo è l'unico modo
    per il cosmo duo mi sa che non c'è la cyano
    al momento nessun link
  5. #94
    da quello che ho letto il kernel dell'highscreen Cosmo è un porting dall'acer liquid mini.
    Dobbiamo lavorare in due direzioni:
    - trovare un sorgente del kernel che ,con il. config dell'andy, compilato funzioni; le modifiche si possono apportare successivamente.
    - trovare una cyano mod che può essere portata al nostro andy
    Certo che se l'onda rilasciasse almeno i sorgenti del kernel sarebbe un garande passo avanti..
    A prop
  6. #95
    onda andy n401
    A prop
    qui ci sono i link per il liquid mini
    http:// 4pda.ru/forum/index.php?showtopic=288621
    ultimo post della pagina
    vedi tu cosa fare
    ma con lo script per scompattare quello del cel cosa hai fatto???
    Ultima modifica di ssdavid; 21-02-13 alle 22:09
  7. #96
    Sta ancora lavorando .. ma se x domani mattina non finisce devo stopparlo
    quei file già li avevo scaricati, ma ci sono troppi errori di compilazione..
    Inviato dal mio U8160 usando Androidiani App
    Ultima modifica di gokur20; 22-02-13 alle 00:08
  8. #97
    onda andy n401
    oggi ho provato a compilare il kernel del duo grazie ad un amico il risultato è lo stesso del tuo il cel rimane sulla schermata iniziale
    ora dobbiamo capire il perche faccio un giro su san google
  9. #98
    io ho provato a compilarlo da un altro pc, preparando un ambiente di compilazione nuovo di zecca, ma il risultato è stato lo stesso. Forse dovremmo provare ad utilizzare altri toolchain.
    Ultima modifica di gokur20; 22-02-13 alle 23:25
  10. #99
    onda andy n401
    io ho provato con ndk di google
    ma il problema principale è cosa bisogna modificare nel config?????? nessuno lo dice nelle varie guide
  11. #100
    trovato il file mancante cci_vars.mk e il file di default per il penguin (così come dice il nostro init.rc),
    nel ftp://ftp.vobis.ru/ c'è il file ftp:// hsfirmware:hsfirmware@ftp.vobis.ru/cosmo-kernel-20111226174758.tar.gz con data successiva
    sia al rilascio del kernel Cosmo che Cosmo duo, ma la versione del kernel è inferiore e sembra essere fatta x gingerbread, ci sono inoltre vari file da dove prendere spunto:
    - penguin_defconfig (configurazione standard per il dispositivo denominato penguin)
    - cci_vars.mk (sembrerebbe faccia fare uno shift di memoria, nell'ipotesi che fosse vero, è normale che compilandolo normalmente il kernel, questi non funzioni)
    - il file envsetup.sh (imposta l'ambiente di compilazione, qui bisogna impostare il proprio toolchain, inoltre inizializza una nuova variabile CCI_MEM_MAPPING che sembrerebbe mappare la memoria e ad occhio è collegata a cci_vars)
    - build_instructions.txt che riepiloga cosa fare x la compilazione
    personalmente proverei a compilare direttamente questo, poi ad adattare con questi file la versione che abbiamo già scaricato
