Pagina 102 di 225 primaprima ... 25292100101102103104112152202 ... ultimoultimo
Visualizzazione dei risultati da 1,011 a 1,020 su 2250
[ROM] Djangomanouche X - Ice Cream mod
  1. #1011
    Senior Droid L'avatar di carburano
    Rimini, Italy
    Xperia Z3 Copper
    Ringraziato 476 volte in 163 Posts
    Uploading: DJANGOMANOUCHE X 1.5 - Emigration Road
    FEATURING PROJECT LARD...
    IMPORTANT: I Tested ROM installation with CWM 5.x, 6.x (the ones included in AIO Tool) and TWRP (provided by TonyP) and it works perfectly!
    New KingOfBirds kernel ver. 0.6
    Changelog:
    codice:
       - Disabled Tegra Hotplug and Conservative Governor when in standby (this should solve other BSOD) and introduced ARM Auto Hotplug by Pengus77
       - Dynamic Fsync by Faux123: Fsync is enabled when device sleeps, disabled when awake (fixed by Pengus77)
       - Frandom support and Havaged Optimizations
       - Compiled with Linaro 4.6.2 Toolchain and with CFLAG Optimizations
       - Lowmemorykiller auto adj
       - Activated many TCP congestion governor (default Westwood)
       - Dirty writeback only when screen is off (Thanks Francisco Franco)
       - Fixed the core max and min frequencies (now are both the same)
       - Now my kernel comes with TricksterMOD which IMHO is the best and you can customize everything (frequencies, voltgages, schedulers, governors, zram, fsync, fast charge, etc...)
       - Fast Charge Support
       - Fixed Governors setup for both cores
       - Removed all custom Governors
       - Other BSOD Fixes
    Updated Source HERE (finally I managed to apply patches properly )
    KingOfBirds KERNEL CUSTOMIZER IN AROMA INSTALLER:
    - 3 Led Brightness Settings
    codice:
    	- Superdimmed (2)
    	- Half Dimmed (10)
    	- Stock (20)
    - Dynamic Fsync
    codice:
    	- Enabled
    	- Disabled
    - USB FastCharge
    codice:
    	- Enabled
    	- Disabled
    - Haveged Optimizations
    codice:
    	- Enabled
    	- Disabled
    - 96 Mb Zram
    codice:
    	- Enabled
    	- Disabled
    2 Versions with Aroma installer: 30a and 30b!
    In each version you can choose:
    - CRT effect or stock
    - 30% transparent statusbar or stock
    - choose to install some LG craps:
    codice:
            - LG app manager, useful for LG UI themes
    	- LG SU660 RAM Widget
    	- LG Email + Widget
    	- LG OSP
    	- LG Smartshare
    	- LG Pcsync
    	- LG Music
    	- LG setup wizard
    - 3 Launchers
    codice:
    	- LG Home
    	- LG Weather Widget (installed to /data)
    	- Lg Home ported from JB ROMs ATT: this will install as system app and it needs 25 MB of your system partition (reduced because I removed some wallpapers)... be sure you have enough free space (you cannot install this togheter with stock one)
    	- LG Weather from JB Roms ATT: this will install as system app and it needs 50 MB of your system partition... be sure you have enough free space (you cannot install this togheter with stock one)
    	- Xperia Launcher
    - 3 Bootanimations
    codice:
    	- DjangoManouche Guitar
    	- DjangoManoucheX by IcyEye
     	- LG 4x
    - *new* 3 RAM Settings - ATT. Supercharger process use too much CPU
    codice:
    	- Stock (UN-Supercharged)
    	- Supercharged (for more free RAM)
            - Supercharged (balanced)
    - Enable or disable Fast Dormancy (thanks to jonasl from Optimus G thread for the tips)
    codice:
    	- Enabled
    	- Disabled
    - MMS app
    codice:
    	- Stock
    	- OptimusG
    - Gallery app
    codice:
    	- Stock
    	- OptimusG
    - Rils
    codice:
    	- 30A
    	- 30B
    	- 28G
    	- 30B from Germany ROM
    - Adblock
    codice:
    	- Active
    	- Inactive
    - Cronjobs
    codice:
    	- Active
    	- Inactive
    - AC!D Sound Mod
    codice:
    	- Active
    	- Inactive
    Kernels:
    LG Stock kernel - Features:
    codice:
       - noop scheduler as default
       - 96 Mb Swap
    KingOfBirds Kernel v0.6 - DEFAULT CHOICE IN AROMA INSTALLER Features:
    codice:
       - Dimmable Leds
       - Default Scheduler: ROW
       - Default Governor: Interactive
       - ARM Auto Hotplug
       - EXT4 tweaks
       - BSOD Fixed by Nvidia
       - SIO, BFQ5 and ROW Scheduler
       - No OC Version or 1.456 Mhz Max OC version and with OV/UV functionality.
       - Enable/Disable 96 Mb Zram
       - 32 Mb Ramhack or No RamHack Versions
       - Frandom support
    Kowalski Kernel 100p5 by Pengus77 - Features:
    codice:
    Really amazing kernel by a great developer (I think he's really one of the most competent person I ever seen on this forum and a very helpful man!)
    For changelog of this awesome beast see HERE...
    In DjangoManouche (and other stock-based rom) we have only one (not important IMHO) bug: LCD brightness regulation doesn't work but auto brightness works very well!! BTW I applied auto brightness by default in my rom so... don't worry!
    Other default choice in DMX:
       - 96 Mb Zram available
    ROMs Changelog:
    codice:
    - Updated SuperSU
    - Updated Google GMS
    - Updated Supercharger script
    - Added Haveged/Frandom support (Thanks idcrisis and his tool crossbreeder for the inspiration)
    - Added the possibility to enable/disable CronJobs and Ac!d audio mod in AROMA Installer
    - Updated Xperia Launcher with new version from XperiaZ
    - Updated Supersu
    - Updated Youtube HD
    - Added KoB Kernel Configurator in Aroma Installer
    - Added HTML Viewer by FreestyleCrafter
    - Tweaks fine tuning
    - Other little things
    Ps: Ciao amici, questa è per voi, tra un paio d'ore dovrebbe essere online! Il kernel è abbastanza sperimentale, fatemi sapere cosa ne pensate che nel caso ci lavriamo su insieme
    Ultima modifica di carburano; 13-03-13 alle 23:00
  2. I seguenti 18 Utenti hanno ringraziato carburano per il post:
    andredd (14-03-13),cecet23 (14-03-13),dominio74 (13-03-13),fats (13-03-13),gigi8703 (13-03-13),luporaro (13-09-13),MatVekk (14-03-13),mellagarga (13-03-13),NAKOLS (15-03-13),nio40057 (14-03-13),nyo88 (13-03-13),pedro978 (13-03-13),pnkpes (14-03-13),redefined (14-03-13),scrofalo (13-03-13),ska1983 (13-03-13),tonee (13-03-13),vismo (13-03-13)
    Firenze
    Ringraziato 39 volte in 31 Posts
    Abemus ROM!
    Il Kernel e' lo stesso KoB 0.6 che aveva messo Matvekk qualche post fa? Io attualmente sono con quella
    PS: Grazie ancoraaaaaaaaaaaaaaaaaaaaaaaa Carbuuuuuuuuuuuuuuuuuuuuuuuuuuu
  5. #1013
    Fumata bianca di Carburano !
  6. #1014
    Senior Droid L'avatar di vismo
    LG G3
    Ringraziato 166 volte in 146 Posts
    Grazie Francesco...........
  7. #1015
    Baby Droid L'avatar di andredd
    sei un grande!!
  8. #1016
    Androidiano VIP L'avatar di MatVekk
    Padova
    Xiaomi Mi5 - MiPad 2
    Ringraziato 197 volte in 159 Posts
    IN PRIMA PAGINA
    Xiaomi Mi5
    Xiaomi MiPad 2
    Xiaomi RedMi Pro
    Xiaomi RedMi Note 2
    Lg G4
    P990 - Guida ROM DjangoManouche X http://www.androidiani.com/forum/mod...carburano.html
  9. #1017
    LG G3
    Quote Originariamente inviato da MatVekk Visualizza il messaggio
    IN PRIMA PAGINA
    Cosa?
    Inviato dal mio LG-P990
  10. #1018
    Rimini, Italy
    Xperia Z3 Copper
    DjangoManoucheX 1.5 Online!!
    Versione 30a: Dev-Host - DjangoManoucheX1.5_30A.zip - The Ultimate Free File Hosting / File Sharing Service
    Versione 30b: Dev-Host - DjangoManoucheX1.5_30B.zip - The Ultimate Free File Hosting / File Sharing Service
    KingOfBirds 0.6 Kernel installer: Dev-Host - KingOfBirds_0.6_Installer.zip - The Ultimate Free File Hosting / File Sharing Service
    Se vi piace il mio lavoro potete supportarmi:
    con una donazione QUI
    o potete effettuare una donazione ad Emergency per aiutare le vittimi civili delle guerre QUI
    ps: non mettete i link su XDA... li ho nascosti per gli utonti
    Ultima modifica di carburano; 14-03-13 alle 06:46
  11. I seguenti 8 Utenti hanno ringraziato carburano per il post:
    480p (14-03-13),mellagarga (14-03-13),NAKOLS (15-03-13),nio40057 (14-03-13),pnkpes (14-03-13),ska1983 (14-03-13),sreeprajay (14-03-13),vismo (14-03-13)
  12. #1019
    Ringraziato 24 volte in 17 Posts
    Quote Originariamente inviato da carburano Visualizza il messaggio
    Preferisci una birra o emergency?
  13. #1020
    Androidiano L'avatar di ska1983
    Apr 2011
    OnePlus 5
    Ringraziato 28 volte in 26 Posts
    Scusate la domanda ma non ho ben capito, ma "KingOfBirds_0.6_Installer.zip" cos'è? il kernel KOB? Ma non è già dentro Aroma il 0.6?
    Eventualmente per un uso quotidiano e per un consumo basso della batteria quale kernel consigliate? Io ultimamente sono sempre stato fedele a Pengus...
