Pagina 6 di 277 primaprima ... 456781656106 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 2766
[MTCE][INFO][Autoradio Android] Rockchip PX5 2/4 GB RAM 32/64 GB ROM
  1. #51
    Oneplus 8T 12/256
    Ringraziato 3,599 volte in 2,650 Posts
    Quote Originariamente inviato da catalincata2101 Visualizza il messaggio
    Grazie... Probabilmente proverò, proprio perché mi attira un sacco avere Android in macchina, oltre al vantaggio che non servono cose aggiuntive per i comandi al volante..
    Guardavo con interesse questo prodotto
    https://m.it.aliexpress.com/s/item/3...5-61545e189743
    si e' una (tipo) xtrons (GS) e va benissimo. Tra l'altro gode di frequenti aggiornamenti MCU e FW ed e' molto supportata su xda.
    Oneplus 8T 12/256
    rilasciato l'aggiornamento alla versione 2.0 della rom custom Malaysk !!!
    Ecco il changelog:
    + Android platform from May 6, 2017
    + Completely new screensaver with GPS speed and Weather function.
    + Added new time values ​​in Settings - Screen - Start time of the screensaver 2 and 3 minutes.
    + Added to Settings -Ascreen - Weather on the screen (Weather settings in the screensaver .There can be turned on - Disable the weather display.
    Do not forget to enable Settings - Location - By All Sources !! For automatic weather display. (You need a connected internet in the device)
    + A new, remastered Launcher.
    + The application Bluetooth is redesigned. Now display the phone and the name of the contact in two lines.
    + Completely redesigned the application Music. A square picture.
    + Redesigned the Radio and Video application.
    + The launcher HA-GS has been added to the OEM promo. You can install it. Change launcher in Settings - Desktop and there choose the launcher that you want to use the default.
    + A new module for displaying the speed over GPS in the screensaver - gps-mtc-launcher.
    In the archive, along with the firmware, there is a folder called mtc-launcher, it must be copied to the root of the internal memory card (SDCARD) with using ES File Explorer.
    And you must activate the GPSMtcLauncher module in Xposed !!!!
    In the folder Copy_To_internal_sd (SDCARD) - From MPH - to display the speed in MPH (US and others)
    In the folder Copy_To_internal_sd (SDCARD) - From KM - to display the speed in KM / H (Russia, Europe and others)
    + Converted Factory Settings for more convenient display.
    + In the OEM application in the Factory app folder there are factory applications - not reworked. You can install them if you do not like my application. Delete them later in Settings - Applications - Delete update.
    + Other fixes and additions.
    link al thread su xda al primo post
  4. #53
    Jun 2014
    Per i comandi al volante non c'è bisogno di interfaccia canbus che si compra apparte?
  5. #54
    Baby Droid L'avatar di catalincata2101
    Jan 2015
    Meizu M3 Note
    Leggendo le caratteristiche del prodotto che ho postato io sembra compatibile con i comandi al volante senza interfaccia esterna
  6. #55
    Jun 2014
    Penso ci voglia sempre l'interfaccia canbus che sta intorno alle 100€
  7. #56
    Androidiano L'avatar di wolfymozart
    Apr 2010
    Quote Originariamente inviato da bluemask Visualizza il messaggio
    Puoi vedere per favore se la Geolocalizzazione una volta disattivata al riaccendersi della radio ritorna attiva? (spero di no)
    Anche a me ritorna attivo dopo la disattivazione e riavvio. In realtà lo voglio sempre attivo, quindi per me è ok...
  8. #57
    Oneplus 8T 12/256
    Quote Originariamente inviato da luigi1010 Visualizza il messaggio
    Non e' così. Sin dai tempi delle prime MTCB l'interfaccia CANBUS e' COMPRESA nella dotazione delle autoradio android.
    Ultima modifica di bluemask; 18-05-17 alle 08:02
  9. #58
    Ciao a tutti sarei interessato a prendere questa nuova xtrons x audi tt... Ho avuto in passato una dynavin ma venduta dopo poco...! Vorrei sapere per quanto riguarda il comparto radio se le stazioni vengono visualizzate e memorizzate come nome RDS come qualunque autoradio "normale" o se (come dynavin) vengono memorizzate nelle varie posizioni come frequenza numerica...
    Inviato dal mio SM-T325 utilizzando Tapatalk
  10. #59
    Jun 2014
    Quale sarebbe il cavo?
  11. #60
    Il cavo n. 9 a cui è collegata una scatoletta nera ovvero il can-bus..
  12. Il seguente Utente ha ringraziato ttalex per il post:
    luigi1010 (19-05-17)
