Pagina 5 di 277 primaprima ... 345671555105 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 2766
[MTCE][INFO][Autoradio Android] Rockchip PX5 2/4 GB RAM 32/64 GB ROM
  1. #41
    Jun 2014
    Ma cosa cambia dalla rom originale Xtrons a quella custom di Malasyk?
    Ultima modifica di luigi1010; 13-05-17 alle 02:58
    Oneplus 8T 12/256
    Ringraziato 3,599 volte in 2,650 Posts
    Quote Originariamente inviato da luigi1010 Visualizza il messaggio
    la malaysk e' basata sulla xtrons , queste sono le customizzazioni
    Built-in Root latest SuperSU (hidden root access).
    + Built-in Xposed
    + Application signature check disabled
    + Removed garbage (Chinese keyboards, Maps and more)
    + Added programs - Root Explorer, ES File Explorer, TitaniumBackup
    + Slightly adjusted launcher.
    + BusyBox
    + Added screensaver. Disable in Settings - Screen- Screensaver (Default is 5 minutes)
    + Settings - corrected Russian translation.
    + New item in Settings - System and Screen (here all new added items are located)
    - Date and Time in the status bar
    - Screen Density
    - Speed ​​of outgoing and incoming Internet in the status bar
    - Change font and its system size
    - Block all advertising from the Internet
    + Settings for the developer are displayed in Settings
    + Redesigned appearance of the equalizer
    + Added a reboot button and reboot in the recovery in StatusBar
    + New Settings item - Display - Bar Status Settings - Gradient status bar. You can make a transparent StatusBar there or add any color.
    + There are many programs in the OEM application. Install as normal applications. Delete them afterwards - go to Settings - Applications - Delete the update.
    + Added settings - flight mode, mobile data transfer, setting up APN
    + Added settings - Ethernet
    + New Settings - System - Auto Backup
    + Decreased the height of the StatusBar
    + Added support for Init.d
    + Added PCRadio (Internet radio) (can be deleted in Settings - Applications)
    + Redone the standard audio control
    + Redesigned graphic design of pop-up messages.
    + Added module for Xposed - Xposed VolumeBar (completely changes the volume control)
    + Added module for Xposed - Disable Fullscreen Keyboard - http://repo.xposed.info/module/com.s...screenkeyboard
    + Added new Settings. Now you can completely customize the icons in StatusBar. Are in Settings - Display-Settings Bar Status - Hide - Show Icons in StatusBar
    And there we include what you need.
    trovi tutto qui
    https://forum.xda-developers.com/and...evice-t3598908
  4. Il seguente Utente ha ringraziato bluemask per il post:
    Cesco67 (13-05-17)
  5. #43
    Jun 2014
    Quote Originariamente inviato da bluemask Visualizza il messaggio
    + Built-in Xposed
    + BusyBox
    - Screen Density
    trovi tutto qui
    Ma è italiana? Ci vuole il root per metterla?
  6. #44
    Oneplus 8T 12/256
    si installa come aggiornamento da microsd , se leggi il primo post di malaysk nel thread di xda che ti ho suggerito dopo la schermata c'e' scritto Installation . E' una rom multilingua quindi anche ITA.
  7. #45
    Oneplus 8T 12/256
    aggiunta in prima pagina l'ultima rom HotAudio Dasaita
  8. #46
    Baby Droid L'avatar di catalincata2101
    Jan 2015
    Meizu M3 Note
    per chi c'è l'ha...la qualità audio...? com'è ? rispetto ad una sorgente di serie ad esempio...
  9. #47
    Oneplus 8T 12/256
    Quote Originariamente inviato da catalincata2101 Visualizza il messaggio
    https://www.androidiani.com/forum/au...ml#post7840391
    non siamo a livello di Blaupunkt o Becker, ma rispetto al passato (MTCB e MTCD PX3) il nuovo chip di amplificazione integrato ha portato un netto miglioramento della qualita' audio, i risultati sono molto buoni .
  10. #48
    Jan 2015
    Meizu M3 Note
    Questa è la cosa che più di tutte mi frena dall'acquistarla, attualmente monto una clarion che, con il bose, rispetto all'autoradio originale suona molto molto meglio...non vorrei trovarmi poi con una qualità o potenza audio non soddisfacente
  11. #49
    Oneplus 8T 12/256
    Te lo dico chiaramente , se sei un audiofilo "dall'orecchio fino" e vuoi in auto l'esaltazione di ogni sfumatura sonora l'autoradio android non fa per te.
    Per la mia Audi A3 con impianto Bose e autoradio Blaupunkt Symphony di serie 3 anni fa ho dovuto accettare un compromesso per poter avere la liberta' di android...tuttavia non me ne sono pentito, anzi ne sono piu' che soddisfatto considerando i vantaggi che ho ottenuto nell'utilizzo in generale. A lungo andare mi sono certamente abituato al tipo di riproduzione audio delle autoradio android.
    Seguendo l'evoluzione ormai da diversi anni di queste radio android sono fiducioso che si arrivera' col tempo ad un livello di riproduzione audio qualitativamente molto alto, gia' con le PX5 il salto di qualita' e' stato notevole.
    Ultima modifica di bluemask; 17-05-17 alle 09:45
  12. Il seguente Utente ha ringraziato bluemask per il post:
    catalincata2101 (17-05-17)
  13. #50
    Jan 2015
    Meizu M3 Note
    Grazie... Probabilmente proverò, proprio perché mi attira un sacco avere Android in macchina, oltre al vantaggio che non servono cose aggiuntive per i comandi al volante..
    Guardavo con interesse questo prodotto
    https://m.it.aliexpress.com/s/item/3...5-61545e189743
