Pagina 14 di 31 primaprima ... 4121314151624 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #131
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I have also compiled the Carbon Rom
    Can compile BlissROM?
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Demelza has compiled the blissrom using my sources, you can find it on needrom
    Nubia Z7MAX
  4. #133
    Aug 2015
    I'm sorry but if you do not say more about what you've done is hard to help
    you mean you lost the IMEI ?
    Hi and thaks for replay! I flash my Z7 Max with CM 12.1 unofficial and it takes 36 hours befor starting! After that I don`t have IMEI and baseband is empty! I can`t go in Engineering Mode to write or chang IMEI and I have no solution to save my phone! Have you one? Thanks Alex
  5. #134
    Quote Originariamente inviato da shikip Visualizza il messaggio
    lol 36 hours is really long, first start is not longer than 5 minutes
    which rom you had before? you made a backup with recovery before flashing the cm12.1 ?
    Nubia Z7MAX
  6. #135
    Aug 2015
    I had a 3.54 official Rom! Unfortunatly no beckup!
  7. #136
    ok, I think you need to return back to firmware stock
    flash the 3.53 from recovery with a full wipe (you can find here: needrom 3.53)
    after that check if IMEI is correct, if not you can try with the last firmware 3.55 (flash from PC with nubia tools) (firmware: needrom 3.55, guide to flash: needrom guide)
    when you have the correct imei you can retry with cm12.1...but before make a full backup
    Nubia Z7MAX
  8. Il seguente Utente ha ringraziato PaoloW8 per il post:
    shikip (09-09-15)
  9. #137
    Sep 2015
    1. Clock app crashes consistently so I can't access clock to stopwatch, timer...
    2. Stock rom camera sometimes (sic) crashes after unlock
    Anyway, grazie mille for great great ROM and regular updates and improvements
  10. #138
    Jul 2015
    No crashes of Clock or Camera here.
    Everything is working perfektly until now.
    I am using v10 from relase on.
    Thanks Paolo for your very nice work, it feels like a new phone.
    You will receive a donation for your effort!
  11. Il seguente Utente ha ringraziato BaSch83 per il post:
    PaoloW8 (01-09-15)
  12. #139
    Quote Originariamente inviato da jadar Visualizza il messaggio
    I have no problem with clock app and stock camera
    you did a full wipe before flashing the rom ?
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    jadar (03-09-15)
  14. #140
    Quote Originariamente inviato da BaSch83 Visualizza il messaggio
    thanks !
    Nubia Z7MAX
