Pagina 15 di 31 primaprima ... 5131415161725 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #141
    Sep 2015
    I flashed dalvik cache, cache and system from release 1 to 8. To perform the last two upgrades, I just wiped cache and dalvik cache.
    I will try a full and reinstall v10 "from scratch" then I'll let you know.
    Thanks for your concern.
    Regards.
    Jul 2015
    Quote Originariamente inviato da jadar Visualizza il messaggio
    Regards.
    Try Format system instead of wipe!
  4. Il seguente Utente ha ringraziato BaSch83 per il post:
    jadar (03-09-15)
  5. #143
    Sep 2015
    After complete reinstall (wipe dalvik cache, cache and system) I don't have any more issue. Hope it'll last
    Thanks everyone for your attention and concern
    Cheers
  6. #144
    Aug 2015
    [Resolved] Problem no IMEI; just runing Restore.exe from nubia-nx505j-updater-developer-edition and the IMEI was after reboot restored!!! Thanks for help! Alex
  7. #145
    Jul 2015
    Paolo, i noticed in your Mega folder two new Nubia cameras!
    Only in the italian thread is thomething written about it, but very hard to translate.
    One with 440dpi and one with 480dpi?
    Can you describe the difference between both?
    Any idea why the filesize is significantly smaler?
    Bye the way, will there be any further releases?
    What are you planning next?
    Thank you very much!!!
  8. #146
    Quote Originariamente inviato da BaSch83 Visualizza il messaggio
    yes, is the new version of nubia camera from stock firmware 3.55...the size is half compared to the previous version, I don't know why
    the difference from 440dpi and 480dpi is only cosmetic, in CM12.1 you can change the dpi in settings->display
    if you use 440dpi the camera preview window is not centered and is aligned to the left...so I created two versions of the app, one if you use the cm12.1 with 480dpi and another one if you use 440dpi
    for future versions, the cyano sources are constantly evolving, I wait a few days then I sync them and make a new version
    Nubia Z7MAX
  9. Il seguente Utente ha ringraziato PaoloW8 per il post:
    BaSch83 (04-09-15)
  10. #147
    link V11 and changelog in first page
    Nubia Z7MAX
  11. I seguenti 5 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (07-09-15),brooklyn2006 (07-09-15),jadar (08-09-15),LiveMoto (09-09-15),migel121 (07-09-15)
  12. #148
    I just finished right now the port of the latest Nubia IR control app (from firmware 3.56, app version 3.0.1.1011)
    if anyone want to try it just download and flash without any wipe: Nubia_IRcontrol_V3.0.1.1011.zip
    I hope everything works
    Nubia Z7MAX
  13. I seguenti 4 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (07-09-15),brooklyn2006 (07-09-15),jadar (09-09-15),LiveMoto (09-09-15)
  14. #149
    Aug 2015
    Hi I have a problem with my Nubia z7 MAX! I have in Germany O2 contract with LTE but I can`t setup the lte it appears only H+ and the speed is also HSPDA! Can I do somthing to setup the phone to lte? Thanks! Alex
  15. #150
    Jul 2015
    O2 LTE kannst du nicht nutzen, da O2 nur LTE 800Mhz (Band 20) nutzt, aber das unterstützt das Z7Max nicht.
    You can't use O2 LTE in Germany, because O2 only uses LTE 800Mhz (Band 20), but Z7Max doesn't support Band 20.
