Pagina 24 di 31 primaprima ... 142223242526 ... ultimoultimo
Visualizzazione dei risultati da 231 a 240 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #231
    Nubia Z7MAX
  2. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    mai62 (06-11-15),no1chan (07-11-15),Pstelios (06-11-15)
    Dec 2014
    Hi,
    Could you please help for installation, I have change Z7 Motherboard & it has come with Lollipop 5.1.1 V3.60.
    No idea how to Root and procedure, I am familiar with 4.4 version but for 5 no idea.
    Dont want to brick again.
    Please guide me.
    Regards,
  5. #233
    Quote Originariamente inviato da mehfil Visualizza il messaggio
    Hi,
    Please guide me.
    Regards,
    you don't need to root etc, just install the twrp 2.8.7.0 recovery
    you can download here (guide inside): ROM Z7 Max All In One Tool v1.2.0 | [Custom]-[Updated] add the 06/29/2015 on Needrom
    Nubia Z7MAX
  6. #234
    Dec 2014
    Thank you Friend for prompt response.
    Could you please clarify below points,
    If i got it right from guide then with All in one tool I will be first enter 1= for USB drivers,
    & then directly 3= for TWRP Recover, no need for Number 2 & 4.
    I can then install Super user using TWRP.
    I can then even install CM 12.1 as a TWRP normal installtion.
    Have a nice time.
  7. #235
    Have a nice time.
    yes right
    but superuser is not necessary if you want to install the cm12.1
    Nubia Z7MAX
  8. #236
    Dec 2014
    Thank You once again & nice to talk with you.
  9. #237
    Dec 2014
    Hi,
    I am getting error "internal error cannot find utcompiledcode record for this version of the uninstaller" while trying to install drivers with option 1.
    Any idea how to resolve the same.
    Thanks & Regards,
  10. #238
    Hi,
    Thanks & Regards,
    for driver download and install this exe: zte_driver.exe
    Nubia Z7MAX
  11. #239
    Dec 2014
    Thanks for your kind help, really appreciate the efforts and time.
    I know its irritating to have too many questions but I promise this will be last.
    Actually I am happy with Stock Lollipop Rom 3.60 version just wanted to install Play store.
    Is it enough if I just install TWRP Recover followed by Root and Gapp's.
    I believe i would be able to use existing stock Rom with Gapp's.
    Thanks.
  12. #240
    Thanks.
    yes is enough
    or just try with a rom based on firmware stock like https://www.androidiani.com/forum/mo...-thx-bb72.html
    Nubia Z7MAX
