Pagina 25 di 31 primaprima ... 152324252627 ... ultimoultimo
Visualizzazione dei risultati da 241 a 250 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #241
    Dec 2014
    Thank you Friend,
    All went well, now with working playstore.
    waiting for your Android 6.1 final version.
    Regards,
    Nov 2015
    Thank you for Manuelb Fixing the Imei problem.. but now it stands ( V17 ): " to place a call,first turn off Airplane mode"
    Im on WCDMA/LTE setting but that didnt solve the problem any tip for me ?
  4. #243
    Quote Originariamente inviato da ForeignDude Visualizza il messaggio
    the phone says this thing when you try to call ?
    It is the first time I hear of this problem
    you have tried to turn on and off the airplane mode ?
    which baseband version you have ? (try to flash the latest 3.65)
    Nubia Z7MAX
  5. #244
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Paolo, please add the type of network "LTE/WCDMA". I need the type of network where there is no option GSM. Very need!
    On YIOS ROM has this type of network.
    Thank you!
    PS I recently looked at by YIOS and the last I want to say that your firmware CM is still more stable and convenient! Good work!
    Ultima modifica di LiveMoto; 16-11-15 alle 09:25
    4PDA community from Russia
  6. #245
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    Thank you!
    but should already be there
    codice:
            <item>@string/preferred_network_mode_td_scdma_lte_gsm_wcdma_cdma_evdo_choice</item>
            <item>@string/preferred_network_mode_td_scdma_gsm_wcdma_cdma_evdo_choice</item>
            <item>@string/preferred_network_mode_td_scdma_gsm_wcdma_lte_choice</item>
            <item>@string/preferred_network_mode_td_scdma_wcdma_lte_choice</item>
            <item>@string/preferred_network_mode_td_scdma_gsm_wcdma_choice</item>
            <item>@string/preferred_network_mode_td_scdma_gsm_lte_choice</item>
            <item>@string/preferred_network_mode_td_scdma_gsm_choice</item>
            <item>@string/preferred_network_mode_td_scdma_lte_choice</item>
            <item>@string/preferred_network_mode_td_scdma_wcdma_choice</item>
            <item>@string/preferred_network_mode_td_scdma_only_choice</item>
            <item>@string/preferred_network_mode_lte_wcdma_choice</item>
            <item>@string/preferred_network_mode_lte_choice</item>
            <item>@string/preferred_network_mode_global_choice</item>
            <item>@string/preferred_network_mode_gsm_wcdma_lte_choice</item>
            <item>@string/preferred_network_mode_cdma_lte_evdo_choice</item>
            <item>@string/preferred_network_mode_cdma_evdo_gsm_wcdma_choice</item>
            <item>@string/preferred_network_mode_evdo_only_choice</item>
            <item>@string/preferred_network_mode_cdma_wo_evdo_choice</item>
            <item>@string/preferred_network_mode_cdma_evdo_auto_choice</item>
            <item>@string/preferred_network_mode_gsm_wcdma_auto_choice</item>
            <item>@string/preferred_network_mode_wcdma_only_choice</item>
            <item>@string/preferred_network_mode_gsm_only_choice</item>
            <item>@string/preferred_network_mode_gsm_wcdma_preferred_choice</item>
    Nubia Z7MAX
  7. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (16-11-15)
  8. #246
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    From the menu, I do not see this menu item.
    Paolo sorry!
    It turns out there is a scrolling ))
  9. Il seguente Utente ha ringraziato LiveMoto per il post:
    PaoloW8 (16-11-15)
  10. #247
    Paolo sorry!
    ahaha lol ok
    Nubia Z7MAX
  11. #248
    release V18 in first page
    Nubia Z7MAX
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (17-11-15)
  13. #249
    Nov 2015
    It does not reboot in to recovery.. something obviously misflashed by myself. :emo_im_frustate:
  14. #250
    for reboot recovery options you need to enable the advanced reboot in developer options
    Nubia Z7MAX
