Pagina 26 di 31 primaprima ... 162425262728 ... ultimoultimo
Visualizzazione dei risultati da 251 a 260 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #251
    Nov 2015
    Still wont work, something very strange..
    install quick reboot and reboot in recovery with this app
    Nubia Z7MAX
  4. #253
    Nov 2015
    Nope still wont work.. gotta give it up for today.
  5. #254
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    release V18 in first page
    Hey Paolo, thanks so much for your work!!! Just wanted to know if there is a 400ppi version of nubia camera app?
  6. #255
    Quote Originariamente inviato da evitself Visualizza il messaggio
    NubiaCamera_5.2_V5.2.7_400dpi.apk
    Nubia Z7MAX
  7. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (18-11-15),LiveMoto (19-11-15)
  8. #256
    Nov 2015
    Cool! Tried it, works perfectly with lcd_density 400dpi configuration. Thanks!
  9. #257
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Paolo, you can try to add support multibutton headsets?
    There Headset Xiaomi Piston with three buttons.
    This proprietary headset Xiaomi.
    The type sine firmware 4.4 are two of the three buttons. On the CM12 operates only the center.
    I use an application KeyTest that would determine which buttons sees the system.
    Concludes that the problem of soft or in the kernel.
    Have a nice day!
    4PDA community from Russia
  10. #258
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    Have a nice day!
    if you use an app like jays headset control you can use all button or still only one ?
    Nubia Z7MAX
  11. #259
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    I will check...
    Paolo view this please: https://github.com/M1cha/android_dev...mment-54744916
    I think I see why Xiaomi headset buttons don't work - they use different resistance values for buttons compared to what the kernel in @M1cha build expects.
    I've compared "sound/soc/msm/apq8064.c" in kernel source between @M1cha version and official (at least that's what I found) version from Xiaomi (https://github.com/MiCode/mi2_kernel), and they differ in the function that I understand as setting button resistances: at
    static void *def_tabla_mbhc_cal(void)
    somewhere in its code there is this:
    Xiaomi M1cha
    btn_low[0] = -75; btn_low[0] = -50;
    btn_high[0] = 150; btn_high[0] = 10;
    btn_low[1] = 151; btn_low[1] = 11;
    btn_high[1] = 330; btn_high[1] = 52;
    btn_low[2] = 331; btn_low[2] = 53;
    btn_high[2] = 655; btn_high[2] = 94;
    btn_low[3] = 21; btn_low[3] = 95;
    btn_high[3] = 62; btn_high[3] = 133;
    btn_low[4] = 154; btn_low[4] = 134;
    btn_high[4] = 181; btn_high[4] = 171;
    btn_low[5] = 182; btn_low[5] = 172;
    btn_high[5] = 218; btn_high[5] = 208;
    btn_low[6] = 219; btn_low[6] = 209;
    btn_high[6] = 254; btn_high[6] = 244;
    btn_low[7] = 63; btn_low[7] = 245;
    btn_high[7] = 104; btn_high[7] = 330;
    I've fixed (at least on my device) both Xiaomi Pistons (gold, v.2) and MiKey with CM11 m8.
    I had to re-compile the kernel (with some changes) and to change keylayout file.
    Pull requests are:
    https://github.com/M1cha/android_ker...i_aries/pull/2
    there's even a patch for a different device to Cm11: https://github.com/M1cha/android_dev...mment-54800092
    Please, pls!!)
    Ultima modifica di LiveMoto; 19-11-15 alle 15:48
  12. #260
    with the apk keytest you see the scancode of all button or only one ?
    Nubia Z7MAX
