Pagina 6 di 31 primaprima ... 4567816 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #51
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    zram is already present in codeaurora kernel, I added the lz4 support (for better compress/uncompress speed) and enabled
    The zram code has a lot of upgrade after kernel 3.4, in the codeaurora the code for the MSM89X4 TAG is stopped at 2013-11-20.
    The TAG list
    But the zram driver has been upgrade much since it has been promoted out of staging. more stable I think. If you can backport that part I think we can get better porformance and gain more stablity while using the zram in the next release.
    so far I have tested the zram kernel for several hours now, it looks fine, no reboot or crash issues.
    Jul 2015
    I replied a long post , why it has been deleted?
  4. #53
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    maybe it's in moderation because of the link inside
    I read the message in the mail notification that I received
  5. #54
    Jul 2015
    so did you read my reply or you just only get the notification?
  6. #55
    I read your reply
  7. #56
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Thanks Paolo! Your last firmware is very stable!
    Can you add to firmware auto call recording, the same as in YIOS?
  8. #57
    Jul 2015
    if you want to try the kernel with zram support download and flash this zip (without wipe)
    cm12.1_zramkernel.zip
    zram is disabled by default but you can enable with trickster mod app
    after 24 hours running, the zram kernel looks good, no problem has been found until now.
    I added a file to enable the zram : /system/etc/init.d/65zram
    #!/system/bin/sh
    # script made by securecrt
    # resetting zram
    echo 1 > /sys/block/zram0/reset
    # setting zram size to 384 mb
    echo 402653184 > /sys/block/zram0/disksize
    # making zram swapable
    mkswap /dev/block/zram0
    # starting swap on zram
    swapon /dev/block/zram0
    # setting swappiness to 60
    #echo 60 > /proc/sys/vm/swappiness
    # done
    Ultima modifica di securecrt; 05-08-15 alle 07:03
  9. Il seguente Utente ha ringraziato securecrt per il post:
    PaoloW8 (06-08-15)
  10. #58
    Jul 2015
    #!/system/bin/sh
    # resetting zram
    # done
    more updates, I have kept the phone running for 55 hours until now, so far it works well, thanks for your great job.
  11. Il seguente Utente ha ringraziato securecrt per il post:
    PaoloW8 (06-08-15)
  12. #59
    nice
    I'm working to update the kernel to 3.4.108 version and (maybe) zram from 3.10 kernel
    edit:
    done
    now in testing...
    Ultima modifica di PaoloW8; 06-08-15 alle 15:57
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    securecrt (07-08-15)
  14. #60
    Jul 2015
    nice
    edit:
    done
    now in testing...
    wow , nice ...... can't wait to test the new kernel...
